mqtts reported an error when creating a socket: Operation not supported on socket.
I want nRF9160 to do mqtts connection without certificate.
Modem FW:1.2.3
Here is my mqtt client_init:
static int client_init(struct mqtt_client *client)
	int err;
	mqtt_client_init(client);
	err = broker_init();
	if (err) {
		LOG_ERR("Failed to initialize broker connection");
		return err;
	/* MQTT client configuration */
	client->broker = &broker;
	client->evt_cb = mqtt_evt_handler;
	client->client_id.utf8 = (uint8_t *)CONFIG_MQTT_CLIENT_ID;
	client->client_id.size = strlen(CONFIG_MQTT_CLIENT_ID);
	client->password = NULL;
	client->user_name = NULL;
	client->protocol_version = MQTT_VERSION_3_1_1;
	/* MQTT buffers configuration */
	client->rx_buf = rx_buffer;
	client->rx_buf_size = sizeof(rx_buffer);
	client->tx_buf = tx_buffer;
	client->tx_buf_size = sizeof(tx_buffer);
	/* MQTT transport configuration */
	struct mqtt_sec_config *tls_cfg = &(client->transport).tls.config;
	static sec_tag_t sec_tag_list[] = { CONFIG_MQTT_TLS_SEC_TAG };
	LOG_INF("TLS enabled");
	client->transport.type = MQTT_TRANSPORT_SECURE;
	tls_cfg->peer_verify = TLS_PEER_VERIFY_NONE;
	tls_cfg->cipher_count = 0;
	tls_cfg->cipher_list = NULL;
	tls_cfg->sec_tag_count = 0;
	tls_cfg->sec_tag_list = NULL;
	tls_cfg->hostname = CONFIG_MQTT_BROKER_HOSTNAME;
	tls_cfg->session_cache = IS_ENABLED(CONFIG_MQTT_TLS_SESSION_CACHING) ?
					    TLS_SESSION_CACHE_ENABLED :
					    TLS_SESSION_CACHE_DISABLED;
	return err;
When I use 9160DK, mqtts is connected normally. But when using the 9160 chip, there is an error in the connection. Here is my log:
[00:00:00.243,316] <inf> main: Connecting to LTE network.
[00:00:00.243,316] <inf> main: This may take several minutes.
[00:00:00.243,377] <inf> flash_control: No apn found, use default apn
[00:00:00.249,908] <inf> main: Set to the default APN CMNBIOT2.
[00:00:00.258,087] <inf> lte_lc: Using legacy LTE PCO mode...
[00:00:02.258,117] <inf> main: CSCON : 1
[18:48:50.833]收←◆[00:00:04.283,386] <inf> main: Connected to LTE network.
[00:00:04.286,163] <inf> mqtt_engine: IPv4 Address found 47.106.164.80
[00:00:04.286,193] <inf> mqtt_engine: TLS enabled
[00:00:04.286,468] <dbg> net_mqtt_sock_tls.mqtt_client_tls_connect: (0x20015220): Created socket 1
[00:00:04.660,552] <err> mqtt_engine: mqtt_connect -45
[00:00:04.660,583] <err> mqtt_engine: ERROR: mqtt_disconnect -57
-45 is EOPNOTSUPP, and typically indicates that you have written wrong certificates to the device. But I had peer_verify set to 0. Why is there a -45 error?
  • I wrote the root certificate in sec_tag 1 of the problematic DK, and the mqtt connection succeeded. I really appreciate your help.
    But I still have a question. Normal DK does not have a root certificate stored in seg 1. Why can this normal DK connect successfully?
    Like this
    Unfortunately, my custom board still reported -45 error after writing the root certificate in sec_tag 1.  After setting peer_verify to 0, will the sec_tag used by each board be different?
    I don't know where to write the root certificate of the custom board to ensure a successful connection. Can you help me analyze the modem info of the custom board?trace-2021-05-06T03-31-54.133Z.bin
    trace-2021-05-07T11-27-12.676Z.bin
  • Hi!
     My guess is there's some subtle difference in the set-up or app running on this DK. What's the return of %CMNG in the "normal" DK?
    From the trace, I can see that the TLS connection is trying to open using the root certificate in sec_tag 1. Try to run %CMNG to see if the certificate actually gets written.
    In the meantime, I'll have our modem experts take a look at the trace as well.
    Heidi
  • Hi!
    This is the certificate stored in the "normal" DK and trace. It can connect to tls normally.trace-2021-05-12T01-59-10.472Z.bin
    *** Booting Zephyr OS build v2.4.99-ncs1  ***
    The AT host sample started
    AT+CGMR
    mfw_nrf9160_1.3.0
    OK
    AT%CMNG=1
    %CMNG: 0,3,"0303030303030303030303030303030303030303030303030303030303030303"
    %CMNG: 0,4,"0404040404040404040404040404040404040404040404040404040404040404"
    %CMNG: 0,6,"0606060606060606060606060606060606060606060606060606060606060606"
    %CMNG: 6123,4,"0404040404040404040404040404040404040404040404040404040404040404"
    %CMNG: 16842753,0,"0000000000000000000000000000000000000000000000000000000000000000"
    %CMNG: 16842753,1,"0101010101010101010101010101010101010101010101010101010101010101"
    %CMNG: 16842753,2,"0202020202020202020202020202020202020202020202020202020202020202"
    %CMNG: 16842754,0,"0000000000000000000000000000000000000000000000000000000000000000"
    %CMNG: 16842754,1,"0101010101010101010101010101010101010101010101010101010101010101"
    %CMNG: 16842754,2,"0202020202020202020202020202020202020202020202020202020202020202"
    %CMNG: 35724859,3,"0303030303030303030303030303030303030303030303030303030303030303"
    %CMNG: 35724859,4,"0404040404040404040404040404040404040404040404040404040404040404"
    %CMNG: 35724861,3,"0303030303030303030303030303030303030303030303030303030303030303"
    %CMNG: 35724861,4,"0404040404040404040404040404040404040404040404040404040404040404"
    %CMNG: 35724862,3,"0303030303030303030303030303030303030303030303030303030303030303"
    %CMNG: 35724862,4,"0404040404040404040404040404040404040404040404040404040404040404"
    %CMNG: 4294967293,10,"0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A"
    %CMNG: 4294967292,11,"0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B0B"
    OK
    AT%CMNG=1,1
    OK
    This is the certificate stored in the custom board. I have a certificate written in sec_tag 1 and I am currently in trouble.
    [10:05:37.543]收←◆*** Booting Zephyr OS build v2.4
    [10:05:37.574]收←◆.99-ncs1  ***
    [10:05:58.792]发→◇AT%CMNG=1
    [10:05:58.804]收←◆%CMNG: 0,6,"0606060606060606060606060606060606060606060606060606060606060606"
    %CMNG: 1,0,"0000000000000000000000000000000000000000000000000000000000000000"
    %CMNG: 1,1,"0101010101010101010101010101010101010101010101010101010101010101"
    %CMNG: 1,2,"0202020202020202020202020202020202020202020202020202020202020202"
    %CMNG: 24,0,"0000000000000000000000000000000000000000000000000000000000000000"
    OK
    [10:06:23.139]发→◇AT%CMNG=1,1
    [10:06:23.160]收←◆%CMNG: 1,0,"0000000000000000000000000000000000000000000000000000000000000000"
    OK
    [10:06:51.981]发→◇AT%CMNG=2,1,0
    [10:06:52.004]收←◆%CMNG: 1,0,"0000000000000000000000000000000000000000000000000000000000000000","-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----"
    OK
    [10:06:56.235]发→◇AT%CMNG=2,1,1
    [10:06:56.250]收←◆ERROR
    [10:07:12.214]发→◇AT%CMNG=2,1,2
    [10:07:12.233]收←◆ERROR
  • Hi!
    So after looking at the modem trace, we can see that the modem returns error code 102 which means "Certification parse error".
    In this case, you are using the certificate in sec_tag = 1 to open the TLS session, but it looks like certificate type 1 (i.e client certificate) is tried to load instead of root CA.
    You need to make sure that the correct type of certificates are stored in the modem filesystem.
    And make sure that the certificate is valid and stored in the correct format in the modem. I.e check that there isn't a client certificated stored with type "Root CA Certificate".
    Heidi
  • Which modem trace? "normal" DK trace?
    "Normal" DK does not store certificates in sec_tag 1, why can it do TLS connection?
    Do you mean to store Root CA in certificate type 1 and sec_tag 1?
    I followed this method, but it didn’t solve the problem .
