I saw something in the list that might help but I have learned that if I go there I lose all the work I did to get here
I am having major problems with Segger Embedded Studio
- NRF_LOG_x does not print either through the UART and putty OR RTT in SES [Manually set in the sdk_config.h file] since CMSIS Wizard is not present
- The CMSIS Configuration Wizard is NOT present in my Tools.xml
- Debug breakpoints are not hit unless it is in the main() part of main.c and when hit not in the code, only if a debug window to the left of the code
- I can step line by line if I start and use F10/F11 from the start (do not use F5 and a break point) but never once I use F5 and a break point.
The only thing I can think of is that somehow the installation of SES got really corrupted or I am missing a major step. I have no idea how to fix.
Yet the code I have does partially run - it advertises, gets connected to, responds to service discovery, gets two characteristic descriptors enabled but then when I try and write from the client the write times out. I am not surprised that there are issues with the code as I have ported a SoftDevice only project from nRF51 and Keil.
But being unable to debug or even print to RTT (this is new for me) or via the UART and putty (the latter worked fine in the Keil project) is not helping.
Any help would be great. (Yes I have seen the debugging video and that's how I know my Tools.xml is corrupt).
