Based on s110 v5.2 release note, nRF51822 will have future hardware revision.
What is the change for future hardware revision? Do we need to modify our circuit design for nRF51822 when new hardware revision is released?
I've been allowed to share the most important changes in the new revision, which is:
Your sales representative will be able to give further information, and there will also be updated documents on the web when the new revision is officially released. That should happen some time this summer.
This future hardware revision should not require any hardware design changes.
Thanks for the information.:)
Anyone want to buy 4,000 lightly used nRF58122 QFAAs?? ;)
Hi Ole, can you give a little bit more information regarding:
What does it do differently from the current IC revision? Thanks
This would probably have worked better as a new question, but anyway: The point is that this comes in addition to the existing concept of code region 0 and code region 1. This means that the softdevice will still occupy code region 0, but using this new feature, you'll be able to mark some parts of code region 1 as read-only, and hence protect for example a bootloader. This will be further explained in an updated Reference Manual, so if you need further details, I'd recommend you wait for this.
