NRF_LOG_INFO lost lines
After long time(around 5 years) Im try developing ble things on my nrf52840 DK Preview board and found some issues with NRF_LOG functions...
I use latest SEGGER Studio(5.42a) and latest fw(Feb  2 2021 16:47:20) on JLINK. Im try update dll in SEGGER Studio from 6.98e to 7.00 but doesnt help. Im using latest nrf5 SDK  17.0.2
What is problem? For example if there is a lot of lines of log they are lost. For example it print 9 lines and all next lines are lost.
I call logging like this(no variable only fixed string):
NRF_LOG_INFO("App Control started.");
NRF_LOG_FLUSH();
Same happen also with one demo which print around 100 lines and if remember right it print only around 60 lines...
Im try call NRF_LOG_FLUSH after every NRF_LOG_INFO call but do not help...
Im try change different settings for buffer, rtt buffers, to block rtt if fifo is full but log data are still lost...
Im increase SEGGER_RTT_CONFIG_BUFFER_SIZE_UP, SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS, SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN, SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS.
Im set SEGGER_RTT_CONFIG_DEFAULT_MODE to 2(BLOCK_IF_FIFO_FULL).
I have enabled(1) NRF_LOG_BACKEND_RTT_ENABLED
Im increase NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE
I have disabled(0) NRF_LOG_BACKEND_UART_ENABLED.
I have enabled(1) NRF_LOG_ENABLED
Im increase NRF_LOG_BUFSIZE
Im try NRF_LOG_DEFERRED set to 0 and 1.
Im try increase NRF_LOG_STR_PUSH_BUFFER_SIZE
Any idea what I can try or how to log data without lost lines of log? Currently I don't care if logging slow down application, and it need more time/power to do work...
Thanks for any help.
    What are you using to monitor your logs? If you are using a debug session in Segger Embedded Studio, try to set the NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED to 0 in sdk_config.h.
     So you do see some lines? After this, do you see anything like "Fatal error." in the log? Or does it just stop?
    What project are you running? A completely custom project? Have you tried debugging to check that the app is still running, and that it didn't stop by some error handler or hardfault handler? Are you using the softdevice?
    Have you tried one of the examples from the SDK, such as the ble_app_uart example? Does the logging work if you don't modify it too much? Try this sample, and set NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED to 0 if you are monitoring the log through a debug session:
    If that doesn't work, I see you are using a PDK? What version is that? Do you have a regular DK, and if so, can you please test that one?
    Edvin
  • Hi Edvin,
    Thanks for reply and help. I use nRF52840 Preview DK board version 0.9.0 which Im buy around 5 years ago when Im start learning developing on microcontrollers and then I didn't need it and put it on box for all that time... This is my only Nordic device so I don't have normal DK... I know that 5 years ago I had similar problem with KEIL but don't remember how Im fix it. I have same problem with Segger Debug window and with J-Link RTT Viewer.
    Im try set NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED to 0 but didn't help. Im found that on one post somewhere here...
    I see some log lines I see for example first 9 lines then some lines are missing and then I see again some lines ... This happen only if lines are written very fast for example when I init "modules"... For example if I enable power management logging for CPU usage it normaly print line every second. I call NRF_LOG_FLUSH after every NRF_LOG_INFO/NRF_LOG_DEBUG call but log messages are still lost. There is no errors also debugging do not break, just debug viewer or RTT viewer do not get log data... I run custom project with softdevice S140 7.2.0 and app normaly work when lines are lost. Also code after log line which missing is executed.
    If I use simple example "examples\ble_peripheral\ble_app_blinky\pca10056\s140\ses"
    And set
    NRF_LOG_BACKEND_RTT_ENABLED 1
    NRF_LOG_BACKEND_UART_ENABLED 0
    And modify main to:
        // Initialize.
        log_init();
      /*  leds_init();
        timers_init();
        buttons_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        NRF_LOG_INFO("Blinky example started.");
        advertising_start();*/
        int i=0;
        // Enter main loop.
        while(true)
          NRF_LOG_INFO("Blinky example i=%d", i);
          NRF_LOG_FLUSH();
          i++;
            //idle_state_handle();
    Then I get in log:
    <info> app: Blinky example i=22790
    <info> app: Blinky example i=22791
    <info> app: Blinky example i=22854
    <info> app: Blinky example i=22855
    <info> app: Blinky example i=22856
    <info> app: Blinky example i=22857
    <info> app: Blinky example i=22858
    <info> app: Blinky example i=22859
    <info> app: Blinky example i=22860
    <info> app: Blinky example i=22861
    <info> app: Blinky example i=22862
    <info> app: Blinky example i=22863
    <info> app: Blinky example i=22864
    <info> app: Blinky example i=22865
    <info> app: Blinky example i=22866
    <info> app: Blinky example i=22925
    <info> app: Blinky example i=22926
    <info> app: Blinky example i=22927
    Im found that right now it work normaly if I have set SEGGER_RTT_CONFIG_DEFAULT_MODE 2. Now with BLOCK_IF_FIFO_FULL mode I must have connected RTT Viewer otherwise application on board stop working but I get all log lines...
    Right now I use this settings:
    SEGGER_RTT_CONFIG_BUFFER_SIZE_UP 512
    SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS 2
    SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN 16
    SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS 2
    NRF_FPRINTF_ENABLED 1
    NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 1
    NRF_FPRINTF_DOUBLE_ENABLED 0
    NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE 64
    NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS 1
    NRF_LOG_BACKEND_RTT_TX_RETRY_CNT 3
    NRF_LOG_BACKEND_UART_TX_PIN 6
    NRF_LOG_BACKEND_UART_BAUDRATE 30801920
    NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE 64
    NRF_LOG_ENABLED 1
    NRF_LOG_MSGPOOL_ELEMENT_SIZE 20
    NRF_LOG_MSGPOOL_ELEMENT_COUNT 16
    NRF_LOG_ALLOW_OVERFLOW 1
    NRF_LOG_BUFSIZE 1024
    NRF_LOG_CLI_CMDS 0
    NRF_LOG_DEFAULT_LEVEL 4
    NRF_LOG_DEFERRED 1
    NRF_LOG_FILTERS_ENABLED 0
    NRF_LOG_NON_DEFFERED_CRITICAL_REGION_ENABLED 0
    NRF_LOG_STR_PUSH_BUFFER_SIZE 128
    Probably when Im test first time with SEGGER_RTT_CONFIG_DEFAULT_MODE 2 Im made something else wrong that logging didn't work...
    I have only one question: Is there settings that when I use BLOCK_IF_FIFO_FULL mode to skip RTT logging if RTT debugger is not connected?
    Thanks for your time and help.
  • You are using SDK17.0.2, right? I can't find BLOCK_IF_FIFO_FULL in SDK17.0.2, but perhaps it is used in some examples. Did you try to set it to 0?
    If you set NRF_LOG_DEFERRED to 0, then you shouldn't need the NRF_LOG_FLUSH().
    I have seen something like "LOGS SKIPPED" before in the log, which I believe is printed if log is deferred, but printed too fast.
    Is there some way for me to reproduce what you are seeing? Can you please zip the project folder, and I can check whether it reproduces on a non-preview DK.
    Edvin
  • Yes Im using SDK17.0.2. There is no BLOCK_IF_FIFO_FULL "definition" but BLOCK_IF_FIFO_FULL you get when you set SEGGER_RTT_CONFIG_DEFAULT_MODE 2 by default is 0(SKIP mode). I understand that in mode SKIP I will lose log lines if I will not flush logs. If I understand documentation NRF_LOG_FLUSH() must block untill all is processed from buffer...
    Documentation:
    Macro for processing all log entries from the buffer. It blocks until all buffered entries are processed by the backend.
    But because I call NRF_LOG_FLUSH()after every NRF_LOG_INFO/NRF_LOG_DEBUG call there can't happen that log lines can be skipped from buffer if I use skip mode...
    If I set NRF_LOG_DEFERRED to 0 and SEGGER_RTT_CONFIG_DEFAULT_MODE is 0 it also SKIP log lines. By quick test there is no difference if I call NRF_LOG_FLUSH() or not.
    Here is simple example(modified ble_app_blinky). After run press pause and check i numbers in log and you will see something like that(missing lines):
    <info> app: Blinky example i=12423
    <info> app: Blinky example i=12424
    <info> app: Blinky example i=12425
    <info> app: Blinky example i=12486
    <info> app: Blinky example i=12487
    <info> app: Blinky example i=12488
    ble_app_blinky.rar
  • Try the attached project:
    ble_app_blinky_cust.zip
    How do you monitor your log? Can you plaese share a screenshot?
    Do you see more than 9 lines in the attached project?
    BR,
    Edvin
