Interaction between timer and saadc
I'm writing software for nRF52832 using nRF5 SDK v17.0.2
I'm using a timer to create a buzz/tone using timer 3.    This works as expected.
I'm also using the SAADC to measure the voltage on input pin AIN3.   Since I only need this value occasionally, I only call the ADC conversion when needed.   Here is the code:
// ADC for voltage measurement
void saadc_callback(nrfx_saadc_evt_t const * p_event) {
  NRF_LOG_INFO("ADC event");
void
saadc_init(void) {
  ret_code_t err_code;
  //err_code = nrf_drv_saadc_init(NULL, saadc_callback);
  //APP_ERROR_CHECK(err_code);
  nrfx_saadc_config_t adcConfig;
  adcConfig.low_power_mode     = true;
  adcConfig.resolution         = NRF_SAADC_RESOLUTION_12BIT;
  adcConfig.oversample         = NRFX_SAADC_CONFIG_OVERSAMPLE;
  adcConfig.interrupt_priority = APP_IRQ_PRIORITY_LOW;
  err_code = nrfx_saadc_init(&adcConfig, saadc_callback);
  // Configure channel 0
  nrf_saadc_channel_config_t channelConfig0;
  channelConfig0.reference     = NRF_SAADC_REFERENCE_INTERNAL;
  channelConfig0.gain          = NRF_SAADC_GAIN1_6;
  channelConfig0.acq_time      = NRF_SAADC_ACQTIME_10US;
  channelConfig0.mode          = NRF_SAADC_MODE_SINGLE_ENDED;
  channelConfig0.burst         = NRF_SAADC_BURST_DISABLED;
  channelConfig0.pin_p         = VBATT_PIN;   // AIN3 = P0.05
  channelConfig0.pin_n         = NRF_SAADC_INPUT_DISABLED;
  channelConfig0.resistor_p    = NRF_SAADC_RESISTOR_DISABLED;
  channelConfig0.resistor_n    = NRF_SAADC_RESISTOR_DISABLED;
  // Configure Channel 0
  err_code = nrfx_saadc_channel_init(0, &channelConfig0);
nrf_saadc_value_t
getBattVoltage(void) {
  nrf_saadc_value_t sample;
  // Sample channel 0
  err_code =nrfx_saadc_sample_convert(0, &sample);
  return sample;
Since I'm not continuously sampling the ADC, no timer was set up for it.   Is the ADC set up and being used properly?
When the "saadc_init" function executes, the tone generation no longer works.    If I comment out the call to "saadc_init" (obviously the ADC can't be used), the tone generator works.
I didn't see anything in the documentation that mentions any interaction/dependency between the saadc and timer 3.
Did I miss something?
Thanks!
