Merging nRF52 blinky into uart for peripheral as well as central role.
I'm merging nRF5_SDK_17.0.2_d674dde\examples\ble_peripheral\ble_app_blinky\pca10040\s132\ses to nRF5_SDK_17.0.2_d674dde\examples\ble_peripheral\ble_app_uart\pca10040\s132\ses, but getting error. Also, I want to merge nRF5_SDK_17.0.2_d674dde\examples\ble_central\ble_app_blinky_c\pca10056\s140\ses to nRF5_SDK_17.0.2_d674dde\examples\ble_central\ble_app_uart_c\pca10056\s140\ses. Can anybody help me? or If their already merged then it will be benefit.
Please find below error screenshot,
    I took a look at the ble_app_uart. In services_init(), you need to init the LBS service, and add the led_write_handler().
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
    static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
        if (led_state)
            bsp_board_led_on(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED ON!");
            bsp_board_led_off(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED OFF!");
    /**@snippet [Handling the data received over BLE] */
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        ble_lbs_init_t     init     = {0};
        // Initialize NUS.
        // Initialize LBS.
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
    Since you are adding a second custom service, you need to increase the value of NRF_SDH_BLE_VS_UUID_COUNT in sdk_config.h to 2
    If you are having trouble viewing the RTT log inside SES, then set NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED in sdk_config.h to 0
    After adding the 2nd service, you need to allocate more RAM to the SoftDevice. You typically will get something like this printed in the log when this is needed:
    <warning> nrf_sdh_ble: Insufficient RAM allocated for the SoftDevice.
    <warning> nrf_sdh_ble: Change the RAM start location from 0x20002AD8 to 0x20002AE8.
    <warning> nrf_sdh_ble: Maximum RAM size for application is 0xD518.
    <error> nrf_sdh_ble: sd_ble_enable() returned NRF_ERROR_NO_MEM.
    You then need to adjust this values, like this:
    If you connect with a phone, using e.g. nRF Connect for Mobile app, you should see that the LBS Service has been added.
    Let me know if you need more help with this.
    I have checked your suggestion.
    Added led_write_handler() & init LBS service. Also, change in sdk_config.h as  NRF_SDH_BLE_VS_UUID_COUNT in sdk_config.h to 2
    Now, I'm unable to see it on nRF toolbox also.
    Before adding these changes atleast I'm able to see it in nRF toolbox.
    Checked in debug mode, both continuously goes into NRF_BREAKPOINT_COND;
    Please find below link of updated sdk:
    https://smetgroup-my.sharepoint.com/:u:/g/personal/megha_choudhari_mysmindia_com/Ef_06NnNAFhKjzGPNLRt8s0Bn7x9q9FgYLiibla92wL_IA?e=7VSmin
    Kindly suggested what is wrong in this.
    Megha Choudhari
    After setting
    NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED to 0
    I get this in the log window:
    I right click on "ble_app_uart_pca10040_s132" -> Options, and find the RAM size the linker uses:
    I changed the RAM values so it matches what the log said, and after that it worked fine.
    Checked by doing this changes in peripheral code. Now able discover on nRF tool box. But not connects with Central ble_app_uart_c(nRF52840)
    What will be the changes required in central side. Can you just check in same sdk & let me know.
     For the central, the first steps to get it to connect is:
    in sdk_config.h set these:
    NRF_BLE_SCAN_NAME_CNT to 1
    NRF_SDH_BLE_VS_UUID_COUNT to 2
    You then will get this in the log:
    <warning> nrf_sdh_ble: Change the RAM start location from 0x20002A38 to 0x20002A48.
    <warning> nrf_sdh_ble: Maximum RAM size for application is 0x3D5B8.
    So you need to set these values for the linker:
    RAM_START=0x20002A48
    RAM_SIZE=0x3D5B8
