Hi!
My apologies for the late reply.
I currently don't know what the issue is. From the log it looks like it could be a DNS failure, which we've seen a few times in certain NB-IoT networks. However, you're connecting over LTE-M so that doesn't explain it in your case.
If you could take a modem trace when the device is connecting, that would be great. See the nRF Connect Trace Collector User Guide for instructions on how to collect a modem trace for the Nordic Thingy:91.
Heidi
trace-2021-05-19T16-34-13.028Z.bin
Despite the delay, thank you first! I thought I was forgotten :-)
I captured the modem trace acc. 5.3 of nRF Trace Collector - assuming that there was no need to actualize the firmware. I then let it run for 15 minutes -> the file size is very manageable - 38 B no more :-(
Well, then I'll be curious what the experts say about it ...
Best Regards and stay healthy
Andreas
Hi!
The trace is unfortunately empty. When you were taking the trace did you see the file size increase in the Trace Collector application?
Did you follow the instructions I linked? Like setting the correct configurations in your application?
Here is a binary with the Asset Tracker application with the Trace configuration enabled if that helps. To be used when updating over MCUboot with the Programmer application.
Hi!
I followed the instructions given in nRF Connect Trace Collector v 1.0.7 starting with Pt 5.3 cause FW was already actualized ( thingy91_ltem_2021-03-04_8e8c6089.hex ... see first message). I haven't done any apllication myself and Auto device/port filter was disabeld and #01 port was used. I saw a file increase from 0 to 38 bits :-) and wondered. So now I uploaded your hex- file ( Item-trace-enabeld_ 2021-05_20) over MCUboot and pressing SW3 with the programmer app.
--> result : nothing happend - blue light isn't working when I switch an the Thingy / LTE Link Monitor shows no reaction and no wonder - if I start the Trace Collector - no movement --> will stay at 0 :-(
So anything got wrong with this hex-file. Your proposal ??? Updating again with Zip file 2021-03-04 the Modem firmware and the Asset Tracker - Hex (thingy91_ltem_2021-03-04_8e8c6089.hex) to get the Thingy at minimum working again ?
As I mentioned before - it might be easier if we start a short teams session to solve the problem . Might be a sensful approach for problem solving .
Best regards....
All- clear :-)
Today came the replacement SIM card for the outdated SIM card from IBasis . And all worked fine, after reupdating the hex-file - Thingy connected without problems to nrf-cloud. I will discuss the problem with the TELEKOM-SIMCard with their agents.
Thank you for your support - stay healthy!
