I2C SDA Ack half voltage
Im using a NRF52840 custom made board and im having some issue with the I2C communication. There are 3 units on the I2C line, the MCU and two sensors, the diagram illustrates the setup:
My problem is that during startup when communication starts with AS3935 the SDA line goes bad. Every Ack bit from the sensor becomes half the voltage for some unknown reason. A screen capture from a oscilloscope shows the problem, see below:
Every ninth bit results in 1.5V when VDD voltage actually is 3.0V.
When searching for this specific problem i have found that this problem can be related to the configuration of the I2C pins. More specific that they are not configured as Open-drain.
I am using the Zephyr stack and have dived deep down and found that the configuration of the SDA pin is :
#define TWIM_PIN_INIT(_pin) nrf_gpio_cfg((_pin),
                                         NRF_GPIO_PIN_DIR_INPUT,
                                         NRF_GPIO_PIN_INPUT_CONNECT,
                                         NRF_GPIO_PIN_PULLUP,
                                         NRF_GPIO_PIN_S0D1,
                                         NRF_GPIO_PIN_NOSENSE)
Does this configuration of the SDA pin results in open-drain?
Have anyone else experienced this problem and if so, what was causing the problem?
The addresses for the sensors are correct and I have tried different pull ups with same result. The internal pull-up (13k) are used and accounted for.
