I2C SDA Ack half voltage
Im using a NRF52840 custom made board and im having some issue with the I2C communication. There are 3 units on the I2C line, the MCU and two sensors, the diagram illustrates the setup:
My problem is that during startup when communication starts with AS3935 the SDA line goes bad. Every Ack bit from the sensor becomes half the voltage for some unknown reason. A screen capture from a oscilloscope shows the problem, see below:
Every ninth bit results in 1.5V when VDD voltage actually is 3.0V.
When searching for this specific problem i have found that this problem can be related to the configuration of the I2C pins. More specific that they are not configured as Open-drain.
I am using the Zephyr stack and have dived deep down and found that the configuration of the SDA pin is :
#define TWIM_PIN_INIT(_pin) nrf_gpio_cfg((_pin),
                                         NRF_GPIO_PIN_DIR_INPUT,
                                         NRF_GPIO_PIN_INPUT_CONNECT,
                                         NRF_GPIO_PIN_PULLUP,
                                         NRF_GPIO_PIN_S0D1,
                                         NRF_GPIO_PIN_NOSENSE)
Does this configuration of the SDA pin results in open-drain?
Have anyone else experienced this problem and if so, what was causing the problem?
The addresses for the sensors are correct and I have tried different pull ups with same result. The internal pull-up (13k) are used and accounted for.
  • If the voltage level on Ack is still at 50% then Is there any other code touching the SDA port? The level does look suspiciously like a standard-drive nRF52 io pin driving high instead of floating. The setting should be H0D1 for SDA; hit a breakpoint just after the transfer and bring up the debug window for port P0 and verify it has indeed been set to that. I assume the pins are not left in LFXTAL mode, by the way; P0.00 is an output driver in LFCLK mode; that means do not use the external LF crystal selection active (often the case in examples). The LFCLK external crystal mode eclipses the I2C/TWI mode.
    Otherwise I would try awneil's suggestion and physically disconnect the other I2C device INA260 in case there is some issue with that, though hard to see what as the addresses are different and the INA260 should just be setting its SDA to open drain and never trying to drive it high.
