SDKv1.5.1 Blinky example with UART
Dear Nordic support,
i'm evaluating the Nordic nRF52840_Dongle with the SDK 1.5.1, inlucing Zephyr etc. I could successfully compile and load the Blinky-example (..\ncs\v1.5.1\zephyr\samples\basic\blinky\build_nrf52840dongle_nrf52840) and manipulated it.
Now i am really struggeling to add a UART (a real UART, no CDC-USB) connection to the dongle. I promise i've read so many documentation (Zephyr, K-Config, Device-Tree, Nordic-SDK...). But i can't find answers...
1.) On which pins at the dongle, can i map the UART RX and TX pins?! Normally on a microcontroller i have a bunch of options, in the Nordic docs it looks like i can map them anywhere, can I? Precisely this configuration is feasible
zephyr.dts --
        uart0: uart@40002000 {
            reg = < 0x40002000 0x1000 >;
            interrupts = < 0x2 0x1 >;
            status = "okay";
            label = "UART_0";
            current-speed = < 0x1c200 >;
            tx-pin = < 0x1f >;
            rx-pin = < 0x1d >;
            rts-pin = < 0x00 >;
            cts-pin = < 0x00 >;
2.) In the docs and even in the video the pins are numbered like "30", "31" and so on. But the in ref-maunal and the schematic there ist port number AND the pin number , e.g 0.12, 1.15, how do i address 1.15, when i want to used it as a UART pin in the config overlay file?
3.) In the picture below, there is my code of the blinky example, including my attemps of using the UART via the zephyr-API. The Problem is, that the "device_get_binding" - function returns a NULL-pointer. I have no idea why.
Thanks a lot.
Sören
  • 2437.blinky.rar
    Hi Einar,
    no i did not manage it. But here is my project.
    Thank you,
    Sören
    I have attached a modified project that is working here. This works both on the DK and dongle. I tested with the default board file (zephyr\boards\arm\nrf52840dongle_nrf52840\nrf52840dongle_nrf52840.dts) with the Tx pin being P0.20, but using another pin should be no problem.
    Code:
    #include <zephyr.h>
    #include <device.h>
    #include <soc.h>
    #include <devicetree.h>
    #include <drivers/gpio.h>
    #include <drivers/uart.h>
    /* 1000 msec = 1 sec */
    #define SLEEP_TIME_MS 1000
    /* The devicetree node identifier for the "led0" alias. */
    #define LED0_NODE DT_ALIAS(led0)
    #define LED0 DT_GPIO_LABEL(LED0_NODE, gpios)
    #define PIN0 DT_GPIO_PIN(LED0_NODE, gpios)
    #define FLAGS0 DT_GPIO_FLAGS(LED0_NODE, gpios)
    #define LED1_NODE DT_ALIAS(led1)
    #define LED1 DT_GPIO_LABEL(LED1_NODE, gpios)
    #define PIN1 DT_GPIO_PIN(LED1_NODE, gpios)
    #define FLAGS1 DT_GPIO_FLAGS(LED1_NODE, gpios)
    #define UART0_NODE DT_NODELABEL(uart0)
    #define UART0 DT_LABEL(UART0_NODE)
    #define UART_LABEL		DT_LABEL(DT_NODELABEL(uart0))
    void main(void)
    	const struct device *green_led_handle;
    	const struct device *red_led_handle;
    	const struct device *uart_0_handle;
    	bool led_is_on = true;
    	volatile int ret;
    	const uint8_t message[] = "Hello World! \n\r";
    	green_led_handle = device_get_binding(LED0);
    	if (green_led_handle == NULL)
    		return;
    	red_led_handle = device_get_binding(LED1);
    	if (red_led_handle == NULL)
    		return;
    	uart_0_handle = device_get_binding(UART_LABEL);
    	if (!uart_0_handle) {
    		return;
    	ret = gpio_pin_configure(green_led_handle, PIN0, GPIO_OUTPUT_ACTIVE | FLAGS0);
    	if (ret < 0)
    		return;
    	ret = gpio_pin_configure(red_led_handle, PIN1, GPIO_OUTPUT_ACTIVE | FLAGS1);
    	if (ret < 0)
    		return;
    	while (1)
    		gpio_pin_set(green_led_handle, PIN0, (int)led_is_on);
    		led_is_on = !led_is_on;
    		gpio_pin_set(red_led_handle, PIN1, (int)led_is_on);
    		ret = uart_tx(uart_0_handle, message, sizeof(message), 100);
    		k_msleep(SLEEP_TIME_MS);
    Config:
    8015.prj.conf
    Logic analyzer plot:
  • Thanks Einar,
    The key was just one line in the prj.conf file
    after i deleted CONFIG_UART_INTERRUPT_DRIVEN it immediately worked!
    The next question will be, how do i get the interrupt based transfer started.
    Best regards
    Sören
  • Hi Sören,
    You cannot use uart_tx() with CONFIG_UART_INTERRUPT_DRIVEN, as that is only supported by the newer CONFIG_UART_ASYNC_API. Note that CONFIG_UART_ASYNC_API is also interrupt driven so there are typically no reason to use the older API unless you want to be conservative.
