How to send sensor data using AT commands to a device using Uart in segger embedded studio
Hi, I am new to NRF and segger embedded studio.
So I want to send temperature sensor data connected with nrf52840 DK to the Murata1_SC  device using UART.
The data will be sent using AT Commands.
So how to send AT Commands in Segger embedded studio.
Thank you for the help in advance.
  • I have seen this code
    uart_putstring((uint8_t*)"AT\r");
    nrf_delay_ms(2000);
    uart_putstring((uint8_t*)"AT+CMGF=1\r");
           nrf_delay_ms(2000);
    uart_putstring((uint8_t*)"AT+CMGS=\"8919242248\"\r");
       nrf_delay_ms(2000);
       uart_putstring((uint8_t*)"test\r");
              nrf_delay_ms(2000);
              app_uart_put((char)0x1A);   ///used (uint8_t) 26 also but no response..
                     nrf_delay_ms(1000);
    in this link, where someone is saying to wait for the response, so how can i do that.
  • that is really bad code - it is making the classic mistake of using blind delays.
  • yes, he has put a delay after every command.
    So could you please help with this.
    I just want a basic format to send the commands.
    Here is the code I have created till now
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include "app_uart.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf.h"
    #include "bsp.h"
    #include "nrf_uart.h"
    #define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
    /* When UART is used for communication with the host do not use flow control.*/
    #define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
    void uart_error_handle(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
     void uart_putstring(const uint8_t *str)
           uint32_t err_code;
           uint8_t len = strlen((uint8_t *)str);
           for (uint8_t i = 0; i < len; i++)
             err_code = app_uart_put(str[i]);
        uint32_t err_code;
        const app_uart_comm_params_t comm_params =
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              UART_HWFC,
              false,
              NRF_UART_BAUDRATE_115200
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             APP_IRQ_PRIORITY_LOWEST,
                             err_code);
         //printf("Hello PC from Nordic Device!!!\r\n");
     //Commands to send data to murata_1sc
         app_uart_put((char)0x0A);
  • For text strings, use 'char' rather than uint8_t - then you won't have to keep casting.
    Although it should work, that's a grossly over-complicated way of sending a string.
    void uart_putstring(const char *str)
           uint32_t err_code;
           while( str )
                err_code = app_uart_put( str++ );
    that's standard textbook stuff - not specific to Nordic.
    Why do you do this:
    instead of just:
    uart_putstring((uint8_t*)"AT\r\n");
    But note that you shouldn't be putting a LF on the end of an AT Command anyhow - the command terminator is just CR:
    https://www.avrfreaks.net/comment/2209136#comment-2209136
    Study this thread:
    https://www.avrfreaks.net/forum/atmega128a-get-response-string-sim900
    also:
    https://www.avrfreaks.net/comment/2212181#comment-2212181
    EDIT
    And note the links to  V.250 - the ITU standard which formalises the so-called "AT Command" structure:
    https://www.avrfreaks.net/comment/1205711#comment-1205711
    https://en.wikipedia.org/wiki/Hayes_command_set
  • Thanks for the help, I have read the threads and got some information, but I have multiple commands to send and have to wait for their responses.
    .First, send a command and then wait for a response.
    Could you please tell me how much timeout should I keep for waiting for the response
    send_AT_Command();
    timeout();
    if (received_srting == actual_string)
    print(received_srting);
    print("ERROR",received_srting);
    send_AT_Command()
    timeout()
    so on.............
    I think this will the format, but I don't know how to write in Segger
    Please help me with the format.
