Thermostat cluster enable issue
Hi All,
I am developing product using nRF52840 and SDK nRF5_SDK_for_Thread_and_Zigbee_v3.0.0_d310e71.
This product is basically, using the Thermostat cluster and Zigbee protocol to communicate with the Zigbee gateway.
So, I referred light_bulb example and followed steps to enable "Thermostat cluster and attributes".
I have included the respective files also but I am unable to execute the below callback function case statement,
static zb_void_t zcl_device_cb(zb_uint8_t param)
    zb_uint8_t                       cluster_id;
    zb_uint8_t                       attr_id;
    zb_buf_t                       * p_buffer = ZB_BUF_FROM_REF(param);
    zb_zcl_device_callback_param_t * p_device_cb_param =
                     ZB_GET_BUF_PARAM(p_buffer, zb_zcl_device_callback_param_t);
    NRF_LOG_INFO("zcl_device_cb id %hd", p_device_cb_param->device_cb_id);
    /* Set default response value. */
    p_device_cb_param->status = RET_OK;
    switch (p_device_cb_param->device_cb_id)
        case ZB_ZCL_SET_ATTR_VALUE_CB_ID:
            cluster_id = p_device_cb_param->cb_param.set_attr_value_param.cluster_id;
            attr_id    = p_device_cb_param->cb_param.set_attr_value_param.attr_id;
            if (cluster_id == ZB_ZCL_CLUSTER_ID_THERMOSTAT)
                uint16_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data16;
                NRF_LOG_INFO("thermostat local temperature: %d", value);
                if (attr_id == ZB_ZCL_ATTR_THERMOSTAT_LOCAL_TEMPERATURE_ID)
                    local_temperature_value(value);
                /* Other clusters can be processed here */
                NRF_LOG_INFO("Unhandled cluster attribute id: %d", cluster_id);
            p_device_cb_param->status = RET_ERROR;
    NRF_LOG_INFO("zcl_device_cb status: %hd", p_device_cb_param->status);
Also, I am attaching code for reference please let me know what else I forgot to enable the functions. It is urgent for me to solve this issue.
Radiator_nRF_v0.9.0.zip
And, with these attributes, for some of the commands, I need to implement custom attributes so if you share how to add custom attributes to this cluster.
Thanks in advance.
Rohit R
  • Hi Marte,
    Thank you so much.
    I assume you used the light bulb example to see how to add ZB_ZCL_SET_ATTR_VALUE_CB_ID etc. to your project. In that example, they can have cluster_id and attr_id as uint8_t values, as the IDs of the attributes used there are 0, and the cluster IDs are 6 and 8 (in decimal values). However, in your case, the ID of the current setpoint attribute is 0x4000 in hex, which in decimal is 16384. This value is too large for an uint8_t (0-255). So in your case, attr_id was set to 0 instead, which of course made the if-statement false, since you were then asking if 0 == 16384
    - ya, correct I used light_bulb code and started modifying as per my requirement. I didn't think of data type of attribute id and cluster id. I thought by default is required same and we can not change the parameter.
    now I am clear that we can modify type also depending on the Attribute value.
    Thanks and Regards
    Rohit R
  • Hi Marte,
    I forgot to ask one thing.
    I have one command which should be executed when end node connect to Gateway/coordinator.
    In SDK 3.0 I use form this command when device discovered and on board LED glows. But in SDK4.1 the function is written in Zigbee_helpers.c file and I can not alter this file. If I do then it will cause SDK in all project.
    Can let me know how I can use in main.c file. The command should not execute before connection it should only execute when network streaming complete.
    Thanks and Regards
    Rohit R
  • Hi Rohit,
    I need more information to understand what it is you want to do and to help you with how you can do it in v4.1.0. What did you use for this in v3.0.0, and how was it implemented? Which function do you refer to?
    Marte
  • Hi Marte,
    Sorry snippet didn't attached.
    Here is the SDK 3.0 main.c file snippet,
    void zboss_signal_handler(zb_uint8_t param)
        zb_zdo_app_signal_hdr_t  * p_sg_p = NULL;
        zb_zdo_app_signal_type_t   sig    = zb_get_app_signal(param, &p_sg_p);
        zb_ret_t                   status = ZB_GET_APP_SIGNAL_STATUS(param);
        zb_bool_t                  comm_status;
        switch (sig)
            case ZB_BDB_SIGNAL_DEVICE_FIRST_START:
            case ZB_BDB_SIGNAL_DEVICE_REBOOT:
                if (status == RET_OK)
                    NRF_LOG_INFO("Joined network successfully");
                    bsp_board_led_on(ZIGBEE_NETWORK_STATE_LED);
                    boolSetCommand  = true;
                    boolReady = true;
                    NRF_LOG_ERROR("Failed to join network. Status: %d", status);
                    bsp_board_led_off(ZIGBEE_NETWORK_STATE_LED);
                    comm_status = bdb_start_top_level_commissioning(ZB_BDB_NETWORK_STEERING);
                    ZB_COMM_STATUS_CHECK(comm_status);
            case ZB_ZDO_SIGNAL_PRODUCTION_CONFIG_READY:
                if (status != RET_OK)
                    NRF_LOG_WARNING("Production config is not present or invalid");
            case ZB_ZDO_SIGNAL_LEAVE:
                    zb_zdo_signal_leave_params_t * p_leave_params = ZB_ZDO_SIGNAL_GET_PARAMS(p_sg_p, zb_zdo_signal_leave_params_t);
                    NRF_LOG_INFO("Network left. Leave type: %d", p_leave_params->leave_type);
                    NRF_LOG_ERROR("Unable to leave network. Status: %d", status);
                /* Unhandled signal. For more information see: zb_zdo_app_signal_type_e and zb_ret_e */
                NRF_LOG_INFO("Unhandled signal %d. Status: %d", sig, status);
        if (param)
            ZB_FREE_BUF_BY_REF(param);
    - As you can see that in zboss_signal_handler() function for case ZB_BDB_SIGNAL_DEVICE_REBOOT when LED turn ON, I have set one flag boolsetCommand = true. So when  this get true after discovery success and do my command sending process.
    Similarly, I would like perform in SDK4.1, but here using zboss_default_signal_handler that which is present in zigbee_helpers.c file. But I can not modify this help because it affect to all project.
    So let me know how I can use default_signal_handler function (SDK 4.1)in main file and follow my above step to send command when devices gets discovered.
    Thanks and Regards
    Rohit R
  • Hi Rohit,
    The zboss_signal_handler can be used to override how the stack signals are handled in the zboss_default_signal_handler. If you want your application to do something else than what is done in the default handler upon receiving a signal, you can handle this in zboss_signal_handler. This is what is done in your application created in v3.0.0. The default signal handler is only there to simplify the application, as most Zigbee devices behave in the same way. You can read more about this here if you are interested.
    If you want to implement a different behavior for the signals, all you have to do is to get the signal sig, as in your previous application, and then create a switch with that signal. The cases should be the different signals you want to override. Make sure to also have a default case that calls the default signal handler, such that every signal that you are not creating a custom implementation of will be handled by the default handler. Be aware that this will override the implementation of the signal in the default signal handler, so if you handle e.g. ZB_BDB_SIGNAL_DEVICE_REBOOT in zboss_signal_handler, then it will never enter the case for this signal in the default signal handler.
    void zboss_signal_handler(zb_bufid_t bufid)
        zb_zdo_app_signal_type_t       sig    = zb_get_app_signal(bufid, &p_sg_p);
        zb_ret_t                       status = ZB_GET_APP_SIGNAL_STATUS(bufid);
        zb_ret_t                       zb_err_code;
        /* Update network status LED */
        zigbee_led_status_update(bufid, ZIGBEE_NETWORK_STATE_LED);
        switch(sig)
            case SIGNAL_YOU_WANT_TO_OVERRIDE:
                /* Your implementation of what to do when this signal is received */
                /* Call default signal handler. */
                ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid));
        if (bufid)
            zb_buf_free(bufid);
    Marte
