Thermostat cluster enable issue
Hi All,
I am developing product using nRF52840 and SDK nRF5_SDK_for_Thread_and_Zigbee_v3.0.0_d310e71.
This product is basically, using the Thermostat cluster and Zigbee protocol to communicate with the Zigbee gateway.
So, I referred light_bulb example and followed steps to enable "Thermostat cluster and attributes".
I have included the respective files also but I am unable to execute the below callback function case statement,
static zb_void_t zcl_device_cb(zb_uint8_t param)
    zb_uint8_t                       cluster_id;
    zb_uint8_t                       attr_id;
    zb_buf_t                       * p_buffer = ZB_BUF_FROM_REF(param);
    zb_zcl_device_callback_param_t * p_device_cb_param =
                     ZB_GET_BUF_PARAM(p_buffer, zb_zcl_device_callback_param_t);
    NRF_LOG_INFO("zcl_device_cb id %hd", p_device_cb_param->device_cb_id);
    /* Set default response value. */
    p_device_cb_param->status = RET_OK;
    switch (p_device_cb_param->device_cb_id)
        case ZB_ZCL_SET_ATTR_VALUE_CB_ID:
            cluster_id = p_device_cb_param->cb_param.set_attr_value_param.cluster_id;
            attr_id    = p_device_cb_param->cb_param.set_attr_value_param.attr_id;
            if (cluster_id == ZB_ZCL_CLUSTER_ID_THERMOSTAT)
                uint16_t value = p_device_cb_param->cb_param.set_attr_value_param.values.data16;
                NRF_LOG_INFO("thermostat local temperature: %d", value);
                if (attr_id == ZB_ZCL_ATTR_THERMOSTAT_LOCAL_TEMPERATURE_ID)
                    local_temperature_value(value);
                /* Other clusters can be processed here */
                NRF_LOG_INFO("Unhandled cluster attribute id: %d", cluster_id);
            p_device_cb_param->status = RET_ERROR;
    NRF_LOG_INFO("zcl_device_cb status: %hd", p_device_cb_param->status);
Also, I am attaching code for reference please let me know what else I forgot to enable the functions. It is urgent for me to solve this issue.
Radiator_nRF_v0.9.0.zip
And, with these attributes, for some of the commands, I need to implement custom attributes so if you share how to add custom attributes to this cluster.
Thanks in advance.
Rohit R
  • Hi Marte,
    Sorry for this inconvenience. I am not getting reply option to your latest feedback. I don't know what is wrong.
    And to last post reply -
    1. Yes, I have tried only current_setpoint_attribute() function also then also same problem. code line are not executing as marked in previous image.
    2. I tried your suggestion also but still the same problem. You find the attached image where i am not able to put break point.
    Should I share the code. but is same to last only thing is I have enabled more extended attributes.
    Rohit R
  • Hi Marte,
    I am really sorry, I don't know what is the problem.
    Things posted multiple times. Really sorry Disappointed
    Please consider only one. And remove others.
    Thanks and Regards
    Rohit R
  • Hi Rohit,
    I think I figured out what the issue is. Could you change cluster_id and attr_id to be unsigned 16 bit int instead of bit? So when you declare them for the first time in zcl_device_cb, you should use the following instead:
    zb_uint16_t                cluster_id;
    zb_uint16_t                attr_id;
    Please let me know whether this fixes the issue on your side or not.
    Marte
  • Hi Marte,
    Thank you so much for quick response.
    It worked at my end. Now I can see my attribute function enable in callback.
    I will write my value parsing logic and send to Radiator to display these value.
    Once the testing is done I will share the result with you.
    Thanks a lot Slight smile.
    - Can you please explain what is the difference using this?
    Means, I am making notes of all the resolved points so that it will help me in future for other project.
    Thanks and Regards
    Rohit R
  • Hi Rohit,
    That is great to hear!
    uint8_t and uint16_t are two data types of different sizes, where the numbers 8 and 16 specifies the size of the value in bits. So a uint8_t is an unsigned 8 bit value (or 1 byte, since 8 bits = 1 byte), and uint16_t is an unsigned 16 bit value (or 2 bytes). The u at the beginning indicates that it is unsigned. When a value is unsigned, it means that it cannot be a negative value, only zero or positive. So if you have a value that is of the data type uint8_t, the maximum value it can be is then 28-1 =  255. For uint16_t the maximum value is 216 -1 = 65 535. If you want to read more about these data types, you can find a lot of information on the internet.
    I assume you used the light bulb example to see how to add ZB_ZCL_SET_ATTR_VALUE_CB_ID etc. to your project. In that example, they can have cluster_id and attr_id as uint8_t values, as the IDs of the attributes used there are 0, and the cluster IDs are 6 and 8 (in decimal values). However, in your case, the ID of the current setpoint attribute is 0x4000 in hex, which in decimal is 16384. This value is too large for an uint8_t (0-255). So in your case, attr_id was set to 0 instead, which of course made the if-statement false, since you were then asking if 0 == 16384.
    Marte
