Cant get any data from uart
I have nrf52810 with soft device S132 5.1, SDK 14.2.
It works fine when NRF_LOG_ENABLED is enabled, data from NUS are printed in debug console. But Im not able to get any output on uart pins.
For other applications, im using libuarte without problems, but that is not avaiable for sdk14.2.
Please can you point me out how to get uart output? RX, TX pins are correct and checked on scope.
Thank you, Hynek
 * Copyright (c) 2016 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_pwr_mgmt.h"
#include "ble_advdata.h"
#include "ble_nus_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#define APP_BLE_CONN_CFG_TAG    1                                       /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO   3                                       /**< Application's BLE observer priority. You shoulnd't need to modify this value. */
#define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
#define SCAN_INTERVAL           0x00A0                                  /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW             0x0050                                  /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_TIMEOUT            0x0000                                  /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS)         /**< Determines minimum connection interval in millisecond. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS)         /**< Determines maximum connection interval in millisecond. */
#define SLAVE_LATENCY           0                                       /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT     MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Determines supervision time-out in units of 10 millisecond. */
#define UUID16_SIZE             2                                       /**< Size of 16 bit UUID */
#define UUID32_SIZE             4                                       /**< Size of 32 bit UUID */
#define UUID128_SIZE            16                                      /**< Size of 128 bit UUID */
#define ECHOBACK_BLE_UART_DATA  0                                       /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE NUS service client instance. */
NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< DB discovery module instance. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
    (uint16_t)MIN_CONNECTION_INTERVAL,  // Minimum connection
    (uint16_t)MAX_CONNECTION_INTERVAL,  // Maximum connection
    (uint16_t)SLAVE_LATENCY,            // Slave latency
    (uint16_t)SUPERVISION_TIMEOUT       // Supervision time-out
/** @brief Parameters used when scanning. */
static ble_gap_scan_params_t const m_scan_params =
    .active   = 1,
    .interval = SCAN_INTERVAL,
    .window   = SCAN_WINDOW,
    .timeout  = SCAN_TIMEOUT,
    #if (NRF_SD_BLE_API_VERSION <= 2)
        .selective   = 0,
        .p_whitelist = NULL,
    #if (NRF_SD_BLE_API_VERSION >= 3)
        .use_whitelist = 0,
/**@brief NUS uuid. */
static ble_uuid_t const m_nus_uuid =
    .uuid = BLE_UUID_NUS_SERVICE,
    .type = NUS_SERVICE_UUID_TYPE
/**@brief Function for asserts in the SoftDevice.
 * @param[in] line_num     Line number of the failing ASSERT call.
 * @param[in] p_file_name  File name of the failing ASSERT call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function to start scanning. */
static void scan_start(void)
    ret_code_t ret;
    ret = sd_ble_gap_scan_start(&m_scan_params);
    APP_ERROR_CHECK(ret);
 //   ret = bsp_indication_set(BSP_INDICATE_SCANNING);
 //   APP_ERROR_CHECK(ret);
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
/**@brief Function for handling characters received by the Nordic UART Service.
 * @details This function takes a list of characters of length data_len and prints the characters out on UART.
 *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
 //   NRF_LOG_DEBUG("Receiving data.");
 //   NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    //float spo2;
   // char b[] = {p_data[9], p_data[8], p_data[7], p_data[6] };
//    memcpy(&spo2, &b, sizeof(spo2));
   // printf(p_data);
    //NRF_LOG_INFO("%X",p_data);
/*   NRF_LOG_INFO("Line1> %x, %x, %x, %x, %x ,%d",
                                  p_data[0], //Packet Start 0xFF
                                  p_data[1], // General error
                                  p_data[2], // Pair status
                                  p_data[3], // Battery status
                                  p_data[4], // State
                                  p_data[5]  // Status
    ); // printime hodnoty co prisly skrz bluetooth.
//   NRF_LOG_INFO("Line2> %f ",  spo2
 //   NRF_LOG_INFO("Line2> %x, %x, %x, %x, %x, %x",
                                  p_data[6],
                                  p_data[7],
                                  p_data[8],
                                  p_data[9],
                                  p_data[10],
                                  p_data[11]
    for (uint32_t i = 0; i < data_len; i++)
        do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
              //  NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
        while (app_uart_put('\n') == NRF_ERROR_BUSY);
    if (ECHOBACK_BLE_UART_DATA)
        // Send data back to peripheral.
        do
            ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
               // NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
    // https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v14.2.0%2Fnrf52810_user_guide.html&cp=4_0_2_5_0
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
  //      int i=0;
 //       i++;
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
               // NRF_LOG_DEBUG("Ready to send data over BLE NUS");
               // NRF_LOG_HEXDUMP_DEBUG(data_array, index);
                do
                    ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_BUSY) )
                index = 0;
           // NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
           // NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
        case APP_UART_TX_EMPTY: // An event indicating that UART has completed transmission of all available data in the TX FIFO.
           // NRF_LOG_ERROR("TX empty hynek.");
/**@brief Callback handling NUS Client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS Client Handle. This identifies the NUS client
 * @param[in]   p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    ret_code_t err_code;
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
           // NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
           // NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
        case BLE_NUS_C_EVT_DISCONNECTED:
            NRF_LOG_INFO("Disconnected.");
            scan_start();
 * @brief Function for shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    //err_code = bsp_indication_set(BSP_INDICATE_IDLE);
    //APP_ERROR_CHECK(err_code);
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            // Prepare wakeup buttons.
            //err_code = bsp_btn_ble_sleep_mode_prepare();
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
/**@brief Reads an advertising report and checks if a UUID is present in the service list.
 * @details The function is able to search for 16-bit, 32-bit and 128-bit service UUIDs.
 *          To see the format of a advertisement packet, see
 *          https://www.bluetooth.org/Technical/AssignedNumbers/generic_access_profile.htm
 * @param[in]   p_target_uuid The UUID to search for.
 * @param[in]   p_adv_report  Pointer to the advertisement report.
 * @retval      true if the UUID is present in the advertisement report. Otherwise false
static bool is_uuid_present(ble_uuid_t               const * p_target_uuid,
                            ble_gap_evt_adv_report_t const * p_adv_report)
    ble_uuid_t   extracted_uuid;
    uint16_t     index  = 0;
    uint8_t    * p_data = (uint8_t *)p_adv_report->data;
    while (index < p_adv_report->dlen)
        uint8_t field_length = p_data[index];
        uint8_t field_type   = p_data[index + 1];
        if (   (field_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_MORE_AVAILABLE)
            || (field_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_COMPLETE))
            for (uint32_t i = 0; i < (field_length / UUID16_SIZE); i++)
                err_code = sd_ble_uuid_decode(UUID16_SIZE,
                                              &p_data[i * UUID16_SIZE + index + 2],
                                              &extracted_uuid);
                if (err_code == NRF_SUCCESS)
                    if (extracted_uuid.uuid == p_target_uuid->uuid)
                        return true;
        else if (   (field_type == BLE_GAP_AD_TYPE_32BIT_SERVICE_UUID_MORE_AVAILABLE)
                 || (field_type == BLE_GAP_AD_TYPE_32BIT_SERVICE_UUID_COMPLETE))
            for (uint32_t i = 0; i < (field_length / UUID32_SIZE); i++)
                err_code = sd_ble_uuid_decode(UUID32_SIZE,
                                              &p_data[i * UUID32_SIZE + index + 2],
                                              &extracted_uuid);
                    if (   (extracted_uuid.uuid == p_target_uuid->uuid)
                        && (extracted_uuid.type == p_target_uuid->type))
                        return true;
        else if (   (field_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_MORE_AVAILABLE)
                 || (field_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_COMPLETE))
            err_code = sd_ble_uuid_decode(UUID128_SIZE, &p_data[index + 2], &extracted_uuid);
                    return true;
        index += field_length + 1;
    return false;
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_ADV_REPORT:
            ble_gap_evt_adv_report_t const * p_adv_report = &p_gap_evt->params.adv_report;
            if (is_uuid_present(&m_nus_uuid, p_adv_report))
                err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
                                              &m_scan_params,
                                              &m_connection_param,
                                              APP_BLE_CONN_CFG_TAG);
                    // scan is automatically stopped by the connect
                    /*NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                             p_adv_report->peer_addr.addr[0],
                             p_adv_report->peer_addr.addr[1],
                             p_adv_report->peer_addr.addr[2],
                             p_adv_report->peer_addr.addr[3],
                             p_adv_report->peer_addr.addr[4],
                             p_adv_report->peer_addr.addr[5]
        }break; // BLE_GAP_EVT_ADV_REPORT
        case BLE_GAP_EVT_CONNECTED:
           // NRF_LOG_INFO("Connected to target");
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
           // err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
           // APP_ERROR_CHECK(err_code);
            // start discovery of services. The NUS Client waits for a discovery result
            err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
               // NRF_LOG_INFO("Scan timed out.");
                scan_start();
            else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                //NRF_LOG_INFO("Connection Request timed out.");
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
#ifndef S140
            //NRF_LOG_DEBUG("PHY update request.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
            //NRF_LOG_DEBUG("GATT Client Timeout.");
        case BLE_GATTS_EVT_TIMEOUT:
           // NRF_LOG_DEBUG("GATT Server Timeout.");
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        //NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        //NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in] event  Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
/**@brief Function for initializing the UART. */
static void uart_init(void)
    const app_uart_comm_params_t comm_params =
          20, //RX_PIN_NUMBER,
          18, //TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          UART_HWFC,
          false,
          NRF_UART_BAUDRATE_115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_event_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
/**@brief Function for initializing the NUS Client. */
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler = ble_nus_c_evt_handler;
    err_code = ble_nus_c_init(&m_ble_nus_c, &init);
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LED, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/**@brief Function for initializing the Power manager. */
static void power_init(void)
    ret_code_t err_code = nrf_pwr_mgmt_init();
/** @brief Function for initializing the Database Discovery Module. */
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
#define WHITELIST_PEERS 1
const ble_gap_addr_t const m_peripheral_addr =
    .addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
    .addr      = {0xCE, 0x42, 0xBB, 0xD5, 0x91, 0x12}
ble_gap_addr_t const * addr_ptrs[WHITELIST_PEERS];
    log_init();
    timer_init();
    power_init();
    uart_init();
  //  buttons_leds_init();
   db_discovery_init();
   ble_stack_init();
    gatt_init();
    nus_c_init();
//    addr_ptrs[0] = &m_peripheral_addr;
 //   uint32_t err_code = sd_ble_gap_whitelist_set(addr_ptrs, 1); //ERRATA Hynek https://devzone.nordicsemi.com/f/nordic-q-a/75020/use-of-whitelist
    // Start scanning for peripherals and initiate connection
    // with devices that advertise NUS UUID.
    //printf("BLE UART central1 example started.\r\n");
   // NRF_LOG_INFO("BLE UART central2 example started.");
    scan_start();
    err_code = app_uart_put('A');
    printf("\r\nStart: \r\n");
    for (;;)
 //    err_code = app_uart_put('A');
 //     nrf_delay_ms(500);
            nrf_pwr_mgmt_run();
1425.app_config.h10268.sdk_config.h
