Nrfutil dfu ble fails without any error message, using maximum verbosity and also log file. Same command works on another Windows PC.
My CMD.EXE is copied here, it shows the command I'm trying to run, and the output of the program. As you can see, there is no error message.
C:\Users\user\Desktop>nrfutil -v -v -v -v dfu ble -f -ic NRF52 --port COM3 --name REDACTED --package REDACTED.zip --address fa78d43f5ec0
Flashing connectivity firmware...
2021-06-02 10:20:29,337 Sending SoftDevice image...
C:\Users\user\Desktop>echo %ErrorLevel%
-1073741819
C:\Users\user\Desktop>nrfutil -o log.txt -v -v -v -v dfu ble -f -ic NRF52 --port COM3 --name REDACTED --package REDACTED.zip --address fa78d43f5ec0
2021-06-02 10:24:43,587 Sending SoftDevice image...
C:\Users\user\Desktop>type log.txt
However, it does not succeed. I can know this for certain because the image on the device is not modified to the new package. I can verify this according to the behavior of the device. Thus the command fails. There is no error message to help me diagnose the error.
I am certain that the COM port is correct, please see the screenshot of Windows Device Manager below.
I have set the verbosity to the maximum verbosity (-v -v -v -v). I also tried using the log, which has less output than not using the log.
The same command works on another Windows 10 PC (after adjusting the COM port), so I am certain that the command is valid. Because the command works, I am also certain that the receiving device is working properly. I can determine that the command succeeded based on the behavior of the device. Thus, I am 100% confident that the command is valid and works on another machine.
1) Have I missed some debugging information that would help you or me diagnose the problem?
2) How can I make the command work on this other machine?
Thank you!
  • Hi Wes,
    It is good to hear you have a workaround that works for you. But it would be good to get to the bottom of this, so if you have time to test with nRF Connect for desktop on one of the "bad" computes we would very much appreciate that as knowing if that works or not could help to narrow down the issue a bit.
    Einar
  • Thanks for following up. I tried with NrfConnect, but unfortunately there's a timeout. The log file and a screenshot of NrfConect are attached.
    2021-06-10T18:26:51.604Z INFO Application data folder: C:\Users\REDACTED\AppData\Roaming\nrfconnect\pc-nrfconnect-ble
    2021-06-10T18:26:51.703Z DEBUG App pc-nrfconnect-ble v2.5.1 official
    2021-06-10T18:26:51.703Z DEBUG App path: C:\Users\REDACTED\.nrfconnect-apps\node_modules\pc-nrfconnect-ble
    2021-06-10T18:26:51.703Z DEBUG nRFConnect 3.6.1 is supported by the app (^3.6.0)
    2021-06-10T18:26:51.703Z DEBUG nRFConnect path: C:\Users\REDACTED\AppData\Local\Programs\nrfconnect\resources\app.asar
    2021-06-10T18:26:51.703Z DEBUG HomeDir: C:\Users\REDACTED
    2021-06-10T18:26:51.703Z DEBUG TmpDir: C:\Users\REDACTED\AppData\Local\Temp
    2021-06-10T18:26:51.742Z INFO Updated list of uuids with data from https://github.com/NordicSemiconductor/bluetooth-numbers-database/tree/master/v1
    2021-06-10T18:27:06.048Z ERROR Failed to setup device: Timeout while waiting for device  FD047A90E71F to be attached and enumerated
