"Add New File To CMakeLists.txt" option missing
I am working through the Getting Started documentation for the nRF Connect SDK 1.5.1 on a Windows 10 machine running SEGGER Embedded Studio Nordic Edition Windows x64, Release 5.34a Build 2021011401.44914. So far the examples compile and download to my device successfully.
In the section Maintaining CMakeLists.txt in SES, the documentation refers to right-clicking the "Project 'app/libapp.a' to find the functions "Add New File To CMakeLists.txt" and "Add Existing File To CMakeLists.txt". However, these functions are not present when I right-click:
According to the documentation, the following is expected:
Also missing is the "Edit Compile Options in CMakeLists.txt" option at the bottom of the menu.
I have tried a couple of different example projects from the "Open nRF Connect SDK Project" menu and this is the case for all of them.
Am I missing something here?
Thanks!
  • , I'm glad it's appreciated!
    Here's another quick note about the Bluetooth Low Energy app under Windows 10. It would be nice if it had a more advanced filter system, so it could be set to filter out some of the common devices from Google, Apple, Windows, etc.
    I've found that the "brand" icons next to the discovered devices in the Android nRF Connect app are useful, in that the unusual ones stand out easily. Extending that idea to simply filtering out the plethora of Google, Apple, Windows, etc. devices would help with the clutter, especially in the cases where the MAC address of device of interest isn't known.
  • Hi . Here's another comment for you regarding the SDK setup.
    I must have missed this the first time through, but the start of the "Getting Started Assistant" v1.1.2 has a big deprecation warning:
    Deprecation warning
    For nRF Connect SDK v1.2.0 (and later), this app has been replaced by the Toolchain Manager app. Go to the app overview to install and open the Toolchain Manager.
    However, the nRF Connect SDK documentation clearly directs the user to use the Getting Started Assistant. Obviously there is a conflict there. Slight smile
    An additional problems with the Toolchain Manager is that it does not put any of the installed tools onto the path. (Windows 10 at least.) So, while it may have installed west, it cannot be used easily.
  • Hi Chris!
     This is something I've also noticed, but I have forgotten to report internally when looking through our bugs. I believe we're mixing due to the launch of toolchain manager, and the manual setup via getting started.
    I will report this!
    Deprecation warning
    Yes, this is correct. We have bundled the whole SDK (incl. deps) in the toolchain manager, but we clearly have improvements to do here.
    The layout of where you would normally click, here highlighted:
    These are, atleast in my mind, the path of least resistance when looking at heading/sub-headings.
    By only looking at the left-hand frame, my mind assumes that this is the proper way: "I want to get started, install, and here's an assistant"
    However, that is unfortunately not the simplest way to get started at this time. I'll work together with our technical writers to improve upon this.
    Håkon
