Motivation: I would like to use SEGGER Embedded Studio V4.10 to use sample projects whose size is not available in keil(no license).
Problem: I can't check the operation of the program (nothing is displayed in TeraTerm), even though the writing seems to be successful. When I write the exact same program from keil, I can see it with TeraTerm.
failure: used segger
success: used keil
I am using SDK12.3.0 and nRF51822.
The evaluation board is EBSGCNZWY by TAIYOYUDEN, and system_nrf51.c is modified according to the specification.
#define __SYSTEM_CLOCK (32000000UL) /*!< nRF51 devices use a fixed System Clock Frequency of 16MHz */
static bool is_manual_peripheral_setup_needed(void);
static bool is_disabled_in_debug_needed(void);
static bool is_peripheral_domain_setup_needed(void);
#if defined ( __CC_ARM )
uint32_t SystemCoreClock __attribute__((used)) = __SYSTEM_CLOCK;
#elif defined ( __ICCARM__ )
__root uint32_t SystemCoreClock = __SYSTEM_CLOCK;
#elif defined ( __GNUC__ )
void SystemCoreClockUpdate(void)
void SystemInit(void)
if (*(uint32_t *)0x10001008 == 0xFFFFFFFF)
NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen<<NVMC_CONFIG_WEN_Pos;
while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
*(uint32_t *)0x10001008 = 0xFFFFFF00;
NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren<<NVMC_CONFIG_WEN_Pos;
NVIC_SystemReset();
while (true){}
/* If desired, switch off the unused RAM to lower consumption by the use of RAMON register.
It can also be done in the application main() function. */
/* Prepare the peripherals for use as indicated by the PAN 26 "System: Manual setup is required
to enable the use of peripherals" found at Product Anomaly document for your device found at
https://www.nordicsemi.com/. The side effect of executing these instructions in the devices
that do not need it is that the new peripherals in the second generation devices (LPCOMP for
example) will not be available. */
if (is_manual_peripheral_setup_needed())
//The following are unchanged
I changed the settings of segger by referring to the following link.
The only differences from the settings are the following.
And "Target Device" is nRF51822xxAC .
The write operation was probably successful.
Connecting ‘J-Link’ using ‘USB’ Connecting to target using SWD Loaded C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.10/bin/JLink_x64.dll Firmware Version: J-Link Lite-Cortex-M V9 compiled Feb 2 2021 16:33:27 DLL Version: 6.34h Hardware Version: V9.00 Target Voltage: 3.386 Device "NRF51822_XXAC" selected. Found SW-DP with ID 0x0BB11477 Scanning AP map to find all available APs AP[1]: Stopped AP scan as end of AP map has been reached AP[0]: AHB-AP (IDR: 0x04770021) Iterating through AP map to find AHB-AP to use AP[0]: Core found AP[0]: AHB-AP ROM base: 0xF0000000 CPUID register: 0x410CC200. Implementer code: 0x41 (ARM) Found Cortex-M0 r0p0, Little endian. FPUnit: 4 code (BP) slots and 0 literal slots CoreSight components: ROMTbl[0] @ F0000000 ROMTbl[0][0]: E00FF000, CID: B105100D, PID: 000BB471 ROM Table ROMTbl[1] @ E00FF000 ROMTbl[1][0]: E000E000, CID: B105E00D, PID: 000BB008 SCS ROMTbl[1][1]: E0001000, CID: B105E00D, PID: 000BB00A DWT ROMTbl[1][2]: E0002000, CID: B105E00D, PID: 000BB00B FPB ROMTbl[0][1]: F0002000, CID: B105900D, PID: 000BB9A3 ??? Preparing target for download Executing script TargetInterface.resetAndStop() Reset: Halt core after reset via DEMCR.VC_CORERESET. Reset: Reset device via AIRCR.SYSRESETREQ. Downloading ‘s130_nrf51_2.0.1_softdevice.hex’ to J-Link Programming 1.9 KB of addresses 00000000 — 000007bf Programming 103.9 KB of addresses 00001000 — 0001afdf J-Link: Flash download: Bank 0 @ 0x00000000: Skipped. Contents already match Download successful Downloading ‘ble_app_uart_c_pca10028_s130.elf’ to J-Link Programming 30.8 KB of addresses 0001b000 — 00022b87 Programming 0.0 KB of addresses 00022b88 — 00022b9f J-Link: Flash download: Bank 0 @ 0x00000000: Skipped. Contents already match Download successful Executing disconnect script Executing script TargetInterface.resetAndStop() Reset: Halt core after reset via DEMCR.VC_CORERESET. Reset: Reset device via AIRCR.SYSRESETREQ.
The output is shown above.
I checked the programmer of nRF connect and it is as follows.
Please give me suggestions for improvement.
