nRF 5340 DK High Idle Current
As the title states, my program (and a simple idle/hello world program for that matter) pull approximately 600-800 uA at idle. Same exact program, driver, and config on my nRF 52833 DK pulls about 8 uA at idle. I cannot figure out why this is. I suspect it has to do with the serial/UART interface and/or the network core? I noticed that even with "CONFIG_SERIAL=n" and "CONFIG_LOG=n" set in prj.conf I get output on UART/serial upon boot though it is from the bootloader. I did use the programmer tool to completely wipe the device (both network and app core) before I flashed it using West/Segger.
Output ("CONFIG_SERIAL=n" and "CONFIG_LOG=n")  :
*** Booting Zephyr OS build v2.4.99-ncs2-2-g5049afda7b9f  ***
Flash regions		Domain		Permissions
00 01 0x00000 0x08000 	Secure		rwxl
02 63 0x08000 0x100000 	Non-Secure	rwxl
Non-secure callable region 0 placed in flash region 1 with size 32.
SRAM region		Domain		Permissions
00 03 0x00000 0x08000 	Secure		rwxl
04 63 0x08000 0x80000 	Non-Secure	rwxl
Peripheral		Domain		Status
00 NRF_P0               Non-Secure	OK
01 NRF_CLOCK            Non-Secure	OK
02 NRF_RTC0             Non-Secure	OK
03 NRF_RTC1             Non-Secure	OK
04 NRF_NFCT             Non-Secure	OK
05 NRF_NVMC             Non-Secure	OK
06 NRF_UARTE1           Non-Secure	OK
07 NRF_UARTE2           Secure		SKIP
08 NRF_TWIM2            Non-Secure	OK
09 NRF_SPIM3            Non-Secure	OK
10 NRF_TIMER0           Non-Secure	OK
11 NRF_TIMER1           Non-Secure	OK
12 NRF_TIMER2           Non-Secure	OK
13 NRF_SAADC            Non-Secure	OK
14 NRF_PWM0             Non-Secure	OK
15 NRF_PWM1             Non-Secure	OK
16 NRF_PWM2             Non-Secure	OK
17 NRF_PWM3             Non-Secure	OK
18 NRF_IPC              Non-Secure	OK
19 NRF_VMC              Non-Secure	OK
20 NRF_FPU              Non-Secure	OK
21 NRF_EGU1             Non-Secure	OK
22 NRF_EGU2             Non-Secure	OK
23 NRF_DPPIC            Non-Secure	OK
24 NRF_REGULATORS       Non-Secure	OK
25 NRF_DCNF             Secure		SKIP
26 NRF_CTRLAP           Secure		SKIP
27 NRF_SPIM4            Non-Secure	OK
28 NRF_WDT0             Non-Secure	OK
29 NRF_WDT1             Non-Secure	OK
30 NRF_COMP             Non-Secure	OK
31 NRF_LPCOMP           Non-Secure	OK
32 NRF_PDM0             Non-Secure	OK
33 NRF_I2S0             Non-Secure	OK
34 NRF_QSPI             Non-Secure	OK
35 NRF_NFCT             Non-Secure	OK
36 NRF_MUTEX            Non-Secure	OK
37 NRF_QDEC0            Non-Secure	OK
38 NRF_QDEC1            Non-Secure	OK
39 NRF_USBD             Non-Secure	OK
40 NRF_USBREGULATOR     Non-Secure	OK
41 NRF_P1               Non-Secure	OK
42 NRF_OSCILLATORS      Non-Secure	OK
43 NRF_RESET            Non-Secure	OK
44 NRF_GPIOTE1          Non-Secure	OK
SPM: NS image at 0x8000
SPM: NS MSP at 0x200094d0
SPM: NS reset vector at 0xb3dd
SPM: prepare to jump to Non-Secure image.
Output ("CONFIG_SERIAL=y" and "CONFIG_LOG=y" ) :
SPM: NS MSP at 0x200099a0
SPM: NS reset vector at 0xc1b1
main entry point!
accel_entry_point!
main entry point!
temp_entry_point!
Running on arm!
Temp Sensor 0x20008390 name HDC2022 is ready!
START OF temp_entry_point LOOP
START OF accel_entry_point LOOP
Waiting for a threshold event
trigger_handler fired!
1072693248.00 g: #
END OF accel_entry_point LOOP
Note I get about the same idle current draw whether SERIAL and LOG is set to yes or no.
Here is my project config and other relevant info:
I am building using nrf5340dk_nrf5340_cpuappns.
nrf5340dk_nrf5340_cpuappns.overlay :
&i2c1 {
	status = "okay";
	sda-pin = < 30 >;
	scl-pin = < 31 >;
    clock-frequency = <I2C_BITRATE_STANDARD>;
	adi_adxl372: adxl372@53 {
		compatible = "adi,adxl372";
		reg = <0x53>;
		label = "ADXL372";
		int1-gpios = <&gpio0 11 0>;
	ti_hdc20x0: hdc20x0@41 {
		compatible = "ti,hdc20x0";
		reg = <0x41>;
		label = "HDC2022";
                drdy-gpios = <&gpio0 12 GPIO_ACTIVE_LOW>;
prj.conf :
CONFIG_ASSERT=y 	# validation
CONFIG_STDOUT_CONSOLE=y
CONFIG_LOG=n
CONFIG_SERIAL=n
CONFIG_SENSOR_LOG_LEVEL_WRN=y
CONFIG_I2C=y
CONFIG_I2C_NRFX=y
CONFIG_SENSOR=y
CONFIG_GPIO=y
CONFIG_ADXL372=y
CONFIG_ADXL372_I2C=y
CONFIG_ADXL372_PEAK_DETECT_MODE=y
CONFIG_ADXL372_TRIGGER_GLOBAL_THREAD=y #THIS ENABLES ADXL372_TRIGGER (see Kconfig.txt for more!)
#CONFIG_ADXL372_TRIGGER_OWN_THREAD=y		#THIS ENABLES ADXL372_TRIGGER (see Kconfig.txt for more!)
CONFIG_HDC20X0=y
# Zephyr Device Power Management
CONFIG_DEVICE_POWER_MANAGEMENT=y
CONFIG_PM=y
CMakeLists.txt :
cmake_minimum_required(VERSION 3.13.1)
set(TEST_DTC_OVERLAY_FILE
  ${CMAKE_CURRENT_SOURCE_DIR}/nrf5340dk_nrf5340_cpuappns.overlay
set(PRJ_CONF_FILE
  prj.conf
  ${CMAKE_CURRENT_LIST_DIR}/prj.conf
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(hub_control)
zephyr_include_directories(include)
FILE(GLOB app_sources src/*.c)
target_sources(app PRIVATE ${app_sources})
Zephyr.dts :
/dts-v1/;
	#address-cells = < 0x1 >;
	#size-cells = < 0x1 >;
	model = "Nordic NRF5340 DK NRF5340 Application";
	compatible = "nordic,nrf5340-dk-nrf5340-cpuapp";
	chosen {
		zephyr,flash-controller = &flash_controller;
		zephyr,entropy = &cryptocell_sw;
		zephyr,console = &uart0;
		zephyr,shell-uart = &uart0;
		zephyr,uart-mcumgr = &uart0;
		zephyr,bt-mon-uart = &uart0;
		zephyr,bt-c2h-uart = &uart0;
		zephyr,ipc_shm = &sram0_shared;
		zephyr,sram = &sram0_ns;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_ns_partition;
	aliases {
		led0 = &led0;
		led1 = &led1;
		led2 = &led2;
		led3 = &led3;
		sw0 = &button0;
		sw1 = &button1;
		sw2 = &button2;
		sw3 = &button3;
	soc {
		compatible = "nordic,nRF5340-CPUAPP-QKAA", "nordic,nRF5340-CPUAPP", "nordic,nRF53", "simple-bus";
		interrupt-parent = < &nvic >;
		ranges;
		nvic: interrupt-controller@e000e100 {
			compatible = "arm,v8m-nvic";
			reg = < 0xe000e100 0xc00 >;
			interrupt-controller;
			#interrupt-cells = < 0x2 >;
			arm,num-irq-priority-bits = < 0x3 >;
			phandle = < 0x1 >;
		systick: timer@e000e010 {
			compatible = "arm,armv8m-systick";
			reg = < 0xe000e010 0x10 >;
			status = "disabled";
		sram0: memory@20000000 {
			compatible = "mmio-sram";
			reg = < 0x20000000 0x80000 >;
		sram1: memory@21000000 {
			reg = < 0x21000000 0x10000 >;
		peripheral@40000000 {
			ranges = < 0x0 0x40000000 0x10000000 >;
			flash_controller: flash-controller@39000 {
				compatible = "nordic,nrf53-flash-controller";
				reg = < 0x39000 0x1000 >;
				label = "NRF_FLASH_DRV_NAME";
				flash0: flash@0 {
					compatible = "soc-nv-flash";
					label = "NRF_FLASH";
					erase-block-size = < 0x1000 >;
					write-block-size = < 0x4 >;
					reg = < 0x0 0x100000 >;
					partitions {
						boot_partition: partition@0 {
							label = "mcuboot";
							reg = < 0x0 0x10000 >;
						slot0_partition: partition@10000 {
							label = "image-0";
							reg = < 0x10000 0x40000 >;
						slot0_ns_partition: partition@50000 {
							label = "image-0-nonsecure";
							reg = < 0x50000 0x30000 >;
						slot1_partition: partition@80000 {
							label = "image-1";
							reg = < 0x80000 0x40000 >;
						slot1_ns_partition: partition@c0000 {
							label = "image-1-nonsecure";
							reg = < 0xc0000 0x30000 >;
						scratch_partition: partition@f0000 {
							label = "image-scratch";
							reg = < 0xf0000 0xa000 >;
						storage_partition: partition@fa000 {
							label = "storage";
							reg = < 0xfa000 0x6000 >;
			adc: adc@e000 {
				compatible = "nordic,nrf-saadc";
				reg = < 0xe000 0x1000 >;
				interrupts = < 0xe 0x1 >;
				status = "okay";
				label = "ADC_0";
				#io-channel-cells = < 0x1 >;
			dppic: dppic@17000 {
				compatible = "nordic,nrf-dppic";
				reg = < 0x17000 0x1000 >;
				status = "okay";
				label = "DPPIC";
			egu0: egu@1b000 {
				compatible = "nordic,nrf-egu";
				reg = < 0x1b000 0x1000 >;
				interrupts = < 0x1b 0x1 >;
				status = "okay";
			egu1: egu@1c000 {
				reg = < 0x1c000 0x1000 >;
				interrupts = < 0x1c 0x1 >;
				status = "okay";
			egu2: egu@1d000 {
				reg = < 0x1d000 0x1000 >;
				interrupts = < 0x1d 0x1 >;
				status = "okay";
			egu3: egu@1e000 {
				reg = < 0x1e000 0x1000 >;
				interrupts = < 0x1e 0x1 >;
				status = "okay";
			egu4: egu@1f000 {
				reg = < 0x1f000 0x1000 >;
				interrupts = < 0x1f 0x1 >;
				status = "okay";
			egu5: egu@20000 {
				reg = < 0x20000 0x1000 >;
				interrupts = < 0x20 0x1 >;
				status = "okay";
			i2s0: i2s@28000 {
				compatible = "nordic,nrf-i2s";
				#size-cells = < 0x0 >;
				reg = < 0x28000 0x1000 >;
				interrupts = < 0x28 0x1 >;
				label = "I2S_0";
			ipc: ipc@2a000 {
				compatible = "nordic,nrf-ipc";
				reg = < 0x2a000 0x1000 >;
				interrupts = < 0x2a 0x1 >;
				status = "okay";
				label = "IPC";
			kmu: kmu@39000 {
				compatible = "nordic,nrf-kmu";
				interrupts = < 0x39 0x1 >;
				status = "okay";
			pdm0: pdm@26000 {
				compatible = "nordic,nrf-pdm";
				reg = < 0x26000 0x1000 >;
				interrupts = < 0x26 0x1 >;
				label = "PDM_0";
			regulators: regulator@4000 {
				compatible = "nordic,nrf-regulators";
				reg = < 0x4000 0x1000 >;
				status = "okay";
			vmc: vmc@81000 {
				compatible = "nordic,nrf-vmc";
				reg = < 0x81000 0x1000 >;
				status = "okay";
			uart0: uart@8000 {
				reg = < 0x8000 0x1000 >;
				interrupts = < 0x8 0x1 >;
				status = "okay";
				label = "UART_0";
				current-speed = < 0x1c200 >;
				tx-pin = < 0x14 >;
				rx-pin = < 0x16 >;
				rts-pin = < 0x13 >;
				cts-pin = < 0x15 >;
			uart1: uart@9000 {
				reg = < 0x9000 0x1000 >;
				interrupts = < 0x9 0x1 >;
				label = "UART_1";
			uart2: uart@b000 {
				reg = < 0xb000 0x1000 >;
				interrupts = < 0xb 0x1 >;
				label = "UART_2";
			uart3: uart@c000 {
				reg = < 0xc000 0x1000 >;
				interrupts = < 0xc 0x1 >;
				label = "UART_3";
			i2c0: i2c@8000 {
				clock-frequency = < 0x186a0 >;
				label = "I2C_0";
			i2c1: i2c@9000 {
				status = "okay";
				label = "I2C_1";
				sda-pin = < 0x1e >;
				scl-pin = < 0x1f >;
					reg = < 0x53 >;
					label = "ADXL372";
					int1-gpios = < &gpio0 0xb 0x0 >;
					reg = < 0x41 >;
					label = "HDC2022";
					drdy-gpios = < &gpio0 0xc 0x1 >;
			i2c2: i2c@b000 {
				label = "I2C_2";
			i2c3: i2c@c000 {
				label = "I2C_3";
			spi0: spi@8000 {
				label = "SPI_0";
			spi1: spi@9000 {
				label = "SPI_1";
			spi2: spi@b000 {
				label = "SPI_2";
			spi3: spi@c000 {
				label = "SPI_3";
			spi4: spi@a000 {
				reg = < 0xa000 0x1000 >;
				interrupts = < 0xa 0x1 >;
				label = "SPI_4";
			pwm0: pwm@21000 {
				compatible = "nordic,nrf-pwm";
				reg = < 0x21000 0x1000 >;
				interrupts = < 0x21 0x1 >;
				status = "okay";
				label = "PWM_0";
				#pwm-cells = < 0x1 >;
				ch0-pin = < 0x1c >;
			pwm1: pwm@22000 {
				reg = < 0x22000 0x1000 >;
				interrupts = < 0x22 0x1 >;
				label = "PWM_1";
			pwm2: pwm@23000 {
				reg = < 0x23000 0x1000 >;
				interrupts = < 0x23 0x1 >;
				label = "PWM_2";
			pwm3: pwm@24000 {
				reg = < 0x24000 0x1000 >;
				interrupts = < 0x24 0x1 >;
				label = "PWM_3";
			gpio0: gpio@842500 {
				compatible = "nordic,nrf-gpio";
				gpio-controller;
				reg = < 0x842500 0x300 >;
				#gpio-cells = < 0x2 >;
				label = "GPIO_0";
				status = "okay";
				port = < 0x0 >;
				phandle = < 0x2 >;
			gpio1: gpio@842800 {
				gpio-controller;
				reg = < 0x842800 0x300 >;
				ngpios = < 0x10 >;
				label = "GPIO_1";
				status = "okay";
				port = < 0x1 >;
			qspi: qspi@2b000 {
				compatible = "nordic,nrf-qspi";
				reg = < 0x2b000 0x1000 >;
				interrupts = < 0x2b 0x1 >;
				status = "okay";
				label = "QSPI";
				sck-pin = < 0x11 >;
				io-pins = < 0xd >, < 0xe >, < 0xf >, < 0x10 >;
				csn-pins = < 0x12 >;
				mx25r64: mx25r6435f@0 {
					compatible = "nordic,qspi-nor";
					reg = < 0x0 >;
					writeoc = "pp4io";
					readoc = "read4io";
					sck-frequency = < 0x7a1200 >;
					label = "MX25R64";
					jedec-id = [ C2 28 17 ];
					sfdp-bfp = [ E5 20 F1 FF FF FF FF 03 44 EB 08 6B 08 3B 04 BB EE FF FF FF FF FF 00 FF FF FF 00 FF 0C 20 0F 52 10 D8 00 FF 23 72 F5 00 82 ED 04 CC 44 83 68 44 30 B0 30 B0 F7 C4 D5 5C 00 BE 29 FF F0 D0 FF FF ];
					size = < 0x4000000 >;
					has-dpd;
					t-enter-dpd = < 0x2710 >;
					t-exit-dpd = < 0x88b8 >;
			rtc0: rtc@14000 {
				compatible = "nordic,nrf-rtc";
				reg = < 0x14000 0x1000 >;
				cc-num = < 0x4 >;
				interrupts = < 0x14 0x1 >;
				status = "okay";
				clock-frequency = < 0x8000 >;
				prescaler = < 0x1 >;
				label = "RTC_0";
			rtc1: rtc@15000 {
				reg = < 0x15000 0x1000 >;
				cc-num = < 0x4 >;
				interrupts = < 0x15 0x1 >;
				status = "okay";
				label = "RTC_1";
			clock: clock@5000 {
				compatible = "nordic,nrf-clock";
				reg = < 0x5000 0x1000 >;
				interrupts = < 0x5 0x1 >;
				status = "okay";
				label = "CLOCK";
			power: power@5000 {
				compatible = "nordic,nrf-power";
				status = "okay";
			wdt: wdt0: watchdog@18000 {
				compatible = "nordic,nrf-watchdog";
				reg = < 0x18000 0x1000 >;
				interrupts = < 0x18 0x1 >;
				status = "okay";
				label = "WDT";
			wdt1: watchdog@19000 {
				reg = < 0x19000 0x1000 >;
				interrupts = < 0x19 0x1 >;
				label = "WDT_1";
			timer0: timer@f000 {
				compatible = "nordic,nrf-timer";
				status = "okay";
				reg = < 0xf000 0x1000 >;
				cc-num = < 0x6 >;
				interrupts = < 0xf 0x1 >;
				prescaler = < 0x0 >;
				label = "TIMER_0";
			timer1: timer@10000 {
				status = "okay";
				reg = < 0x10000 0x1000 >;
				cc-num = < 0x6 >;
				interrupts = < 0x10 0x1 >;
				label = "TIMER_1";
			timer2: timer@11000 {
				status = "okay";
				reg = < 0x11000 0x1000 >;
				cc-num = < 0x6 >;
				interrupts = < 0x11 0x1 >;
				label = "TIMER_2";
			usbd: usbd@36000 {
				compatible = "nordic,nrf-usbd";
				reg = < 0x36000 0x1000 >;
				interrupts = < 0x36 0x1 >;
				num-bidir-endpoints = < 0x1 >;
				num-in-endpoints = < 0x7 >;
				num-out-endpoints = < 0x7 >;
				num-isoin-endpoints = < 0x1 >;
				num-isoout-endpoints = < 0x1 >;
				status = "okay";
				label = "USBD";
		gpiote: gpiote@4002f000 {
			compatible = "nordic,nrf-gpiote";
			reg = < 0x4002f000 0x1000 >;
			interrupts = < 0x2f 0x5 >;
			status = "okay";
			label = "GPIOTE_1";
		cryptocell_sw: cryptocell-sw {
			compatible = "nordic,nrf-cc312-sw";
			#address-cells = < 0x0 >;
			label = "CRYPTOCELL_SW";
	cpus {
		cpu@0 {
			device_type = "cpu";
			compatible = "arm,cortex-m33f";
			reg = < 0x0 >;
			mpu: mpu@e000ed90 {
				compatible = "arm,armv8m-mpu";
				reg = < 0xe000ed90 0x40 >;
				arm,num-mpu-regions = < 0x8 >;
	leds {
		compatible = "gpio-leds";
		led0: led_0 {
			gpios = < &gpio0 0x1c 0x1 >;
			label = "Green LED 0";
		led1: led_1 {
			gpios = < &gpio0 0x1d 0x1 >;
			label = "Green LED 1";
		led2: led_2 {
			gpios = < &gpio0 0x1e 0x1 >;
			label = "Green LED 2";
		led3: led_3 {
			gpios = < &gpio0 0x1f 0x1 >;
			label = "Green LED 3";
	buttons {
		compatible = "gpio-keys";
		button0: button_0 {
			gpios = < &gpio0 0x17 0x11 >;
			label = "Push button 1";
		button1: button_1 {
			gpios = < &gpio0 0x18 0x11 >;
			label = "Push button 2";
		button2: button_2 {
			gpios = < &gpio0 0x8 0x11 >;
			label = "Push button 3";
		button3: button_3 {
			gpios = < &gpio0 0x9 0x11 >;
			label = "Push button 4";
	reserved-memory {
		ranges;
		sram0_image: image@20000000 {
			reg = < 0x20000000 0x70000 >;
		sram0_s: image_s@20000000 {
			reg = < 0x20000000 0x40000 >;
		sram0_ns: image_ns@20040000 {
			reg = < 0x20040000 0x30000 >;
		sram0_shared: memory@20070000 {
			reg = < 0x20070000 0x10000 >;
SDK and Build Versions:
nRF Connect SDK: v1.5.1
Zephyr OS: 2.4.99
  • Hi Sam,
    You will have to disable UART in the SPM project as well. Add CONFIG_SERIAL=n to the prj.conf file in the nrf/samples/spm/ folder.
    If you are using both the application core and the network core you will have to disable UART in both. Usually for BLE applications, the zephyr/samples/bluetooth/hci_rpmsg application is loaded onto the network core, so you will have to add this CONFIG_SERIAL=n here as well (and remove CONFIG_LOG=y).
    Instead of using the CONFIG_SERIAL=n config you can enable and disable the UARTs in the application by using the code which Amanda linked to, but then the SERIAL has to be enabled or else the power management calls will fail.
    Here is a hex file from the zephyr/samples/basic/blinky application. I just added CONFIG_SERIAL=n to the prj.conf in both the application and the SPM folder. You can try it out and see if the current goes down to the expected level: 2318.merged.hex I just checked here, and I get 4 uA in idle on a nRF5340 DK.
  • Got it, I understand how the 5340 is using multiple images now after your post and some more digging on my end. So yeah I went ahead and made those config changes and made sure it was booting using the samples/boilerplate you mentioned with the config changes you mentioned.
    Despite those changes I made to the config, I still have an idle current of ~70uA on the 5340 compared to ~7uA on my 52833
    I also added functionality to my application which causes it to enter deep sleep/system off with sense on a pin to wake/reset. In system off mode (pm_power_state_force(POWER_STATE_DEEP_SLEEP_1)) it draws about 14uA which is higher than I expected as well. I haven't tested this code on my 52833 yet but I feel like this is might be related to my high idle current as well.
    Where do I look next/how can I debug/what resources do I have at my disposal to figure out what is causing this?
    Is there anyway I can see what the PMU is doing via debugging?
    Edit:
    Also, I did try the hex for the blinky application you posted and I too get about ~5uA idle.
  • Hi, sorry for the late response. You say that you have configured a wakeup pin. Can you make sure that the pin configuration is GPIO_INT_LEVEL_ACTIVE and not GPIO_INT_EDGE_TO_ACTIVE ? The latter one will use the GPIOTE IN event. I did some measurements now and it seems like the GPIOTE IN event consumes about 80 uA of current. So this might be what you are seeing.
    EDIT: I see now that this LEVEL vs EDGE behavior has changed in the NCS v1.6.0. So now it should be enough to add CONFIG_GPIO_NRF_INT_EDGE_USING_SENSE=y to the prj.conf file, and the current should go down. By enabling this option, the interrupt will be triggered by the GPIO SENSE event, and not using the GPIOTE IN event.
  • I just got around to testing this on NCS 1.6.0 and it appears to be fixed using CONFIG_GPIO_NRF_INT_EDGE_USING_SENSE=y like suggested.
    Thank you!
