Hi there,
Currently, I am getting an error with a low power node when the remote cannot configure through another regular node in a mesh network. What causes me to get this error?
Hi there,
How to get 1 friend node when LPN is not configured? How can it agree to this friend request process?
Judge
I need someone's help me !!
You need to provision the nodes (the Friend node and the Low Power node) into the same network. Once the devices are both provisioned, they should be able to communicate on the network. You should then be able to configure the node (also if the communication between configuration client and configuration server goes via relay nodes, friend nodes, proxy nodes, etc.
The friendship gets established without user interaction. It happens automatically between Friend nodes and Low Power nodes in the same network.
I need more information in order to help. Where / when / at what stage do you get an error? What guide or description are you following for testing this out? What SDK and example are you using?
Terje
