NRF_LOG timestamp resolution via UART
I would like to do log timestamping using the UART backend with NRF_LOG.
As described in many devzone posts (e.g. here: https://devzone.nordicsemi.com/f/nordic-q-a/18707/timestamp-problem/72239#72239) , I added counter.h and counter.c (see also attachments to this post) configured NRF_LOG_USES_TIMESTAMP 1, NRF_LOG_TIMESTAMP_DEFAULT_FREQUENCE 0 and also have NRFX_RTC_DEFAULT_CONFIG_FREQUENCY=32768 and added the relevant changes to log_init()
static void log_init(void)
    #if NRF_LOG_USES_TIMESTAMP==1
    counter_init();
    counter_start();
    ret_code_t err_code = NRF_LOG_INIT(counter_get);
    #else
This basically does what it is supposed to - add timestamps but the timestamp itself looked totally off and not in 1s resp. 1000ms intervals.
[00:00:00.114,746] <info> app: Tick! 1/1000
[00:00:00.114,990] <info> calculations: prev_cumulative_crank_revs=0 - Should never happen after start!
[00:00:00.115,600] <info> calculations: prev_last_crank_event_time=0 - Very unlikely to happen!
[00:00:00.175,354] <info> app: Tick! 2/2000
[00:00:00.235,961] <info> app: Tick! 3/3000
[00:00:00.296,569] <info> app: Tick! 4/4000
[00:00:00.357,177] <info> app: Tick! 5/5000
[00:00:00.417,785] <info> app: Tick! 6/6000
[00:00:00.478,393] <info> app: Tick! 7/7000
[00:00:00.539,001] <info> app: Tick! 8/8000
[00:00:00.599,609] <info> app: Tick! 9/9000
[00:00:00.660,217] <info> app: Tick! 10/10000
[00:00:00.720,825] <info> app: Tick! 11/11000
[00:00:00.781,433] <info> app: Tick! 12/12000
[00:00:00.842,041] <info> app: Tick! 13/13000
[00:00:00.902,648] <info> app: Tick! 14/14000
[00:00:00.963,256] <info> app: Tick! 15/15000
[00:00:01.023,864] <info> app: Tick! 16/16000
[00:00:01.084,472] <info> app: Tick! 17/17000
I figured out, that when I set config.prescaler =1
void counter_init(void)
    ret_code_t err_code;
    // Initialize the RTC instance.
    nrfx_rtc_config_t config = NRFX_RTC_DEFAULT_CONFIG;
    // 1 ms interval.
    //config.prescaler = 32;
    config.prescaler = 1; // prescaler = 1 gives proper timestamps
    err_code = nrfx_rtc_init(&m_rtc, &config, rtc_handler);
    nrfx_rtc_tick_disable(&m_rtc);
The log cleanly logs in the right time intervals.
For example I have a 1000ms tick I log and this is printed in the log as:
[00:00:46.117,126] <info> app: Found 0 services on conn_handle: 0
[00:00:46.123,474] <info> app: Disconnected due to sec failure. Deleting peers.
[00:00:46.130,920] <info> app: Erase bonds!
[00:00:46.889,770] <info> app: Tick! 46/46000
[00:00:47.889,770] <info> app: Tick! 47/47000
[00:00:48.889,831] <info> app: Tick! 48/48000
[00:00:49.889,831] <info> app: Tick! 49/49000
[00:00:50.646,179] <info> oled: Start OLED redraw()
However I am worried about the info at https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v15.0.0%2Fgroup__nrfx__rtc.html  stating that a rollover at prescaler=1 will occur very soon.
How do I need to adapt the counter.h/RTC config in order to keep the proper timebase but allow the system to log for a much longer time than a couple of hundred seconds? I don't care so much about the actual ms resolution in the log, it is more important to me to see whether the log message was logged about 5s, 5min or 20min
 * Copyright (c) 2016 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/**@cond To Make Doxygen skip documentation generation for this file.
#include "counter.h"
#include "nrfx_rtc.h"
// RTC driver instance using RTC2.
// RTC0 is used by the SoftDevice, and RTC1 by the app_timer library.
static const nrfx_rtc_t m_rtc = NRFX_RTC_INSTANCE(2);
static void rtc_handler(nrfx_rtc_int_type_t int_type)
    // Likely a counter overflow.
    APP_ERROR_CHECK(0xFFFFFFFF);
    // 1 ms interval.
void counter_start(void)
    nrfx_rtc_counter_clear(&m_rtc);
    // Power on!
    nrfx_rtc_enable(&m_rtc);
void counter_stop(void)
    nrfx_rtc_disable(&m_rtc);
uint32_t counter_get(void)
    uint32_t cnt = nrfx_rtc_counter_get(&m_rtc);
    return cnt;
 *  @endcond
counter.h
  • Hi Markus,
    Sorry for the late reply. We are on summer vacation staffing so responses may be a bit slower than usual. You can handle the rollover using an external variable you increment each time RTC overflows. Something like this:
        cnt |= overflow_counter << 24;
        return cnt;
    This way you could increase the counter to 256 instead of only having the RTC 24-bit counter. It will give you 72 hours before the RTC overflows instead of 17 minutes. I don't know if this would be OK for your implementation?
    Marjeris
  • Thank you, this is a great "trick"! For what it's worth here is the full code file to help others.
    static volatile uint32_t overflow_counter = 0;
        if (int_type == NRFX_RTC_INT_OVERFLOW) overflow_counter++;    // Used for timer extension
        // 1 ms interval.
        //config.prescaler = 256; // prescaler = 1 gives proper timestamps
        nrfx_rtc_overflow_enable(&m_rtc, true);  // Count overflow events to extend counter, see below
        // Power on!
        cnt |= overflow_counter << 24;    // We artifically "extend" the counter from 24 bit to 32 bit doing so.
        return cnt;
     *  @endcond
