Use BLE_GAP_EVT_ADV_REPORT to scan for beacon
Setup:
Module: nRF51822.
SDK version:nRF5_SDK_11.0.0_89a8197.
Example: ble_app_uart.
Softdevice: S130.
I use ble_nus_string_send on the BLE_GAP_EVT_ADV_REPORT in on_ble_evt tring to scan for
beacon and found that it only outputs strings less than 20 bytes. Dig a little further, I found it's
because of
if (length > BLE_NUS_MAX_DATA_LEN)
return NRF_ERROR_INVALID_PARAM;
in ble_nus.c while BLE_NUS_MAX_DATA_LEN is defined as (GATT_MTU_SIZE_DEFAULT - 3) and
GATT_MTU_SIZE_DEFAULT is defined to be 23.
My question is how to modify so I can scan for beacon whose data length is about 30? Or it's just
not supported in S130 to scan for beacons this way?
  • It's for inspection of received packets only.
    /* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
     * The information contained herein is property of Nordic Semiconductor ASA.
     * Terms and conditions of usage are described in detail in NORDIC
     * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
     * Licensees are granted free, non-transferable use of the information. NO
     * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
     * the file.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "softdevice_handler.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    // 20210714
    // Max Lu
    #include "nrf_delay.h"
    #include "scanner_beacon.h"
    #define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                           /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
    #define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
    #define PERIPHERAL_LINK_COUNT           1                                           /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
    #ifdef living_room
    #define DEVICE_NAME                     "iot_livingroom"                               /**< Name of device. Will be included in the advertising data. */
    #define BEACON_LOC                      0xf4                        //Identify Beacons. 0xf4 is in living room.
    #else
    #define DEVICE_NAME                     "Not_defined"                               /**< Name of device. Will be included in the advertising data. */
    #define BEACON_LOC                      0xff
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    //#define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
    #define APP_ADV_TIMEOUT_IN_SECONDS      20                                         /**< The advertising timeout (in units of seconds). */
    #define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
    #define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
    static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
    static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
    // 20210714
    // Max Lu
    #define BLE_IDLE 0
    #define BLE_ADVERTISING 1
    #define BLE_CONNECTED 2
    #define SEARCHED_MAJOR                          0x1234  // Decimal 13330
    #define SEARCHED_MINOR                          0x5678  // Decimal 30806
    #define APP_COMPANY_IDENTIFIER                  0x004C                                  /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    #define MAX_IDENTIFIER                  0x0617                                  /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    #define APP_BEACON_UUID                  0xe2, 0xc5, 0x6d, 0xb5, \
                                             0xdf, 0xfb, 0x48, 0xd2, \
                                             0xb0, 0x60, 0xd0, 0xf5, \
                                             0xa7, 0x10, 0x96, 0xe0            /**< Proprietary UUID for Beacon. */
    static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
    static bool beacon_broadcast = false;
    uint8_t ble_state = BLE_IDLE;
    uint16_t raw_temp;
    void beacon_start(uint16_t manu_id, uint16_t major_value, uint16_t minor_value);
    void sensor_start();
    static ble_beacon_scanner_init_t m_beacon_scanner_init;
    APP_TIMER_DEF(m_xs_timer_id);
    APP_TIMER_DEF(m_xm_timer_id);
    #define XS_INTERVAL          APP_TIMER_TICKS(3000, APP_TIMER_PRESCALER)
    #define XM_INTERVAL          APP_TIMER_TICKS(3600000, APP_TIMER_PRESCALER)
    #define BROADCAST_TIME      3000
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_nus    Nordic UART Service structure.
     * @param[in] p_data   Data to be send to UART module.
     * @param[in] length   Length of the data.
    /**@snippet [Handling the data received over BLE] */
    static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
        for (uint32_t i = 0; i < length; i++)
            while(app_uart_put(p_data[i]) != NRF_SUCCESS);
        while(app_uart_put('\n') != NRF_SUCCESS);
        uint32_t       err_code;
        ble_nus_init_t nus_init;
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
        if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
    /**@brief Function for handling errors from the Connection Parameters module.
        APP_ERROR_HANDLER(nrf_error);
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                // 20210714
                // Max
                //sleep_mode_enter();
    /**@brief Function for the application's SoftDevice event handler.
     * @param[in] p_ble_evt SoftDevice event.
    static void on_ble_evt(ble_evt_t * p_ble_evt)
        uint32_t                         err_code;
        //ble_gap_evt_adv_report_t        * p_adv_report = &p_ble_evt->evt.gap_evt.params.adv_report;
            case BLE_GAP_EVT_CONNECTED:
                ble_state = BLE_CONNECTED;
            case BLE_GAP_EVT_TIMEOUT:
            case BLE_GAP_EVT_ADV_REPORT:
                    //uint16_t length;
                    //length = p_adv_report->dlen;
                    //if ((p_adv_report->dlen == 30 ) && (ble_state == BLE_CONNECTED) &&
                        //(p_adv_report->data[25] == 0x34) &&
                        //(p_adv_report->data[26] == 0x12) &&
                        //(p_adv_report->data[27] == 0x78) &&
                        //(p_adv_report->data[2] == 0x1a))
                        //ble_nus_string_send(&m_nus, p_adv_report->data, p_adv_report->dlen);
                // Pairing not supported
                // No implementation needed.
    /**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice
     *        event handler.
     * @details This function is called from the SoftDevice event interrupt handler after a
     *          SoftDevice event has been received.
    static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
        ble_conn_params_on_ble_evt(p_ble_evt);
        ble_nus_on_ble_evt(&m_nus, p_ble_evt);
        ble_advertising_on_ble_evt(p_ble_evt);
        bsp_btn_ble_on_ble_evt(p_ble_evt);
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize SoftDevice.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        //Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        err_code = softdevice_enable(&ble_enable_params);
        // Subscribe for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
                err_code = ble_advertising_restart_without_whitelist();
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' i.e '\n' (hex 0x0D) or if the string has reached a length of
     *          @ref NUS_MAX_DATA_LENGTH.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if (((data_array[index - 2] == '\n') && (data_array[index - 1] == '\r')) || (index >= (BLE_NUS_MAX_DATA_LEN)))
                    raw_temp = ((data_array[index - 4] << 8) | data_array[index - 3]);
                    if ((ble_state == BLE_CONNECTED) && !beacon_broadcast)
                        err_code = ble_nus_string_send(&m_nus, data_array, index);
                    if ((ble_state == BLE_IDLE) && !beacon_broadcast)
                        sensor_start();
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
        const app_uart_comm_params_t comm_params =
            RX_PIN_NUMBER,
            TX_PIN_NUMBER,
            RTS_PIN_NUMBER,
            CTS_PIN_NUMBER,
            //APP_UART_FLOW_CONTROL_ENABLED,
            APP_UART_FLOW_CONTROL_DISABLED,
            false,
            UART_BAUDRATE_BAUDRATE_Baud115200
        APP_UART_FIFO_INIT( &comm_params,
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOW,
                           err_code);
        uint32_t      err_code;
        ble_advdata_t advdata;
        ble_advdata_t scanrsp;
        // Build advertising data struct to pass into @ref ble_advertising_init.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = false;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        memset(&scanrsp, 0, sizeof(scanrsp));
        scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
        ble_adv_modes_config_t options = {0};
        options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
        options.ble_adv_fast_interval = APP_ADV_INTERVAL;
        options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
        err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
    /*static void buttons_leds_init(bool * p_erase_bonds)
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                     APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                     bsp_event_handler);
    /**@brief Function for placing the application in low power state while waiting for events.
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
    // 2015/11/27 Sending iBeacon for iot sensors detection
        uint32_t err_code;
        //app_beacon_scanner_stop();
        if (ble_state == BLE_IDLE)
        ble_advdata_manuf_data_t manuf_specific_data;
        //manuf_specific_data.company_identifier = 0x004C;                            /**< Company identifier for Apple Inc. as per www.bluetooth.org. */
        manuf_specific_data.company_identifier = manu_id;                            /**< Company identifier for Apple Inc. as per www.bluetooth.org. */
    uint8_t m_beacon_info[0x17] =                     /**< Information advertised by the Beacon. */
        0x02,     // Manufacturer specific information. Specifies the device type in this
                             // implementation.
        0x15, // Manufacturer specific information. Specifies the length of the
                             // manufacturer specific data in this implementation.
        APP_BEACON_UUID,     // 128 bit UUID value.
        major_value, major_value>>8,    // Major arbitrary value that can be used to distinguish between Beacons.
        minor_value, minor_value>>8,    // Minor arbitrary value that can be used to distinguish between Beacons.
        0xC8    // Manufacturer specific information. The Beacon's measured TX power in
                             // this implementation.
        manuf_specific_data.data.p_data        = (uint8_t *) m_beacon_info;
        manuf_specific_data.data.size          = 0x17;
        // Build and set advertising data.
        advdata.name_type               = BLE_ADVDATA_NO_NAME;
        advdata.flags                   = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
        advdata.p_manuf_specific_data   = &manuf_specific_data;
        err_code = ble_advdata_set(&advdata, NULL);
        // Initialize advertising parameters (used when starting advertising).
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        m_adv_params.type        = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
        m_adv_params.p_peer_addr = NULL;                             // Undirected advertisement.
        m_adv_params.fp          = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval    = MSEC_TO_UNITS(100, UNIT_0_625_MS); /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
        //m_adv_params.timeout     = 0;
        m_adv_params.timeout     = 2;           // In second
            beacon_broadcast = true;
            err_code = sd_ble_gap_adv_start(&m_adv_params);
            //err_code = sd_ble_gap_adv_stop();
            //APP_ERROR_CHECK(err_code);
            nrf_delay_ms(BROADCAST_TIME);
        //app_beacon_scanner_start();
    // 2021/07/18
    // Max Lu
    // Modified for beacon_start for sending sensor data
    void sensor_start()
        uint32_t err_code;
        uint8_t data[]                      = "123456789"; // Our data to adverise
        data[0] = BEACON_LOC ;	        // Sensor ID
        data[1] = raw_temp >> 4;		                // Temperature
        //data[2] = ach1;		                // Gas detector reading
        //data[3] = ach1 >> 8;
        manuf_specific_data.company_identifier = 0xAAAA; // Max ID
        manuf_specific_data.data.p_data        = data;
        manuf_specific_data.data.size          = sizeof(data);
    static void xs_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        if ((ble_state == BLE_IDLE) && (nrf_gpio_pin_read(LED_1) == 1))
            beacon_start(APP_COMPANY_IDENTIFIER, 0x01, BEACON_LOC);
    static void xm_timeout_handler(void * p_context)
        //if (nrf_gpio_pin_read(LED_4) == 0)
            app_uart_put('t');
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        uint32_t err_code;
        // Initialize timer module.
        APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
        // 20210714
        // Max Lu
        // 2 seconds interval timer
        err_code = app_timer_create(&m_xs_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    xs_timeout_handler);
        err_code = app_timer_start(m_xs_timer_id, XS_INTERVAL, NULL);
        err_code = app_timer_create(&m_xm_timer_id,
                                    xm_timeout_handler);
        err_code = app_timer_start(m_xm_timer_id, XM_INTERVAL, NULL);
    /**@brief Function for handling a BeaconScanner event.
     * @details This function will be called each time the scanner has found an advertiser with beacon data.
     *          In this simple implementation, it checks the Major and Minor and company ID fields from the beacon data,
     *          and if they match, @ref BSP_INDICATE_ALERT_3 is indicated.
     * @param[in]   p_evt   scanner event data.
    static void beacon_evt_handler(ble_scan_beacon_evt_t * p_evt)
        if((p_evt->rcv_adv_packet.adv_data.major    == SEARCHED_MAJOR)
         &&(p_evt->rcv_adv_packet.adv_data.minor    == SEARCHED_MINOR)
         &&(p_evt->rcv_adv_packet.adv_data.manuf_id == APP_COMPANY_IDENTIFIER))
            //beacon_cnt++;
            advertising_init();
            ble_advertising_start(BLE_ADV_MODE_FAST);
    /**@brief Function for handling a BeaconScanner error.
    static void beacon_scanner_error_handler(uint32_t nrf_error)
    /**@brief Function for initializing the beacon scanner module.
    static void scanner_init()
        m_beacon_scanner_init.evt_handler   = beacon_evt_handler;
        m_beacon_scanner_init.error_handler = beacon_scanner_error_handler;
        app_beacon_scanner_init(&m_beacon_scanner_init);
    /**@brief Function for starting the beacon scanner module.
    static void scanner_start()
    /**@brief Application main function.
        uint32_t err_code;
        //bool erase_bonds;
        // Initialize.
        uart_init();
        //buttons_leds_init(&erase_bonds);
        ble_stack_init();
        gap_params_init();
        services_init();
        advertising_init();
        conn_params_init();
        // 20210714
        // Max Lu
        timers_init();
        nrf_gpio_cfg_input(LED_1, NRF_GPIO_PIN_NOPULL); // Motion detection
        //nrf_gpio_cfg_output(LED_4);
        //nrf_gpio_pin_clear(LED_4);
        nrf_gpio_cfg_input(LED_4, NRF_GPIO_PIN_PULLUP);
        scanner_init();
        scanner_start();
        // 2017/05/04 Max Lu
        // Set Tx power, available value -40, -30, -20, -16, -12, -8, -4, 0, 4 dBm
        sd_ble_gap_tx_power_set(4);
        printf("\r\nUART Start!\r\n");
        err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
        ble_state = BLE_ADVERTISING;
        // Enter main loop.
        for (;;)
            power_manage();
  • Hi Max,
    Please explain why you call ble_nus_string_send() , what's it for ?
    So you want to see the beacon data on the phone ? correct ?
  • Then please read my reply from the beginning.
    The way we send the data from the nRF52 to the phone is via notification. And there is a limitation of the notification compare to read/write.
  • My question is to scan for a specific beacon signal in nRF51. How to implement this in nRF51?
