Use BLE_GAP_EVT_ADV_REPORT to scan for beacon
Setup:
Module: nRF51822.
SDK version:nRF5_SDK_11.0.0_89a8197.
Example: ble_app_uart.
Softdevice: S130.
I use ble_nus_string_send on the BLE_GAP_EVT_ADV_REPORT in on_ble_evt tring to scan for
beacon and found that it only outputs strings less than 20 bytes. Dig a little further, I found it's
because of
if (length > BLE_NUS_MAX_DATA_LEN)
return NRF_ERROR_INVALID_PARAM;
in ble_nus.c while BLE_NUS_MAX_DATA_LEN is defined as (GATT_MTU_SIZE_DEFAULT - 3) and
GATT_MTU_SIZE_DEFAULT is defined to be 23.
My question is how to modify so I can scan for beacon whose data length is about 30? Or it's just
not supported in S130 to scan for beacons this way?
  • Have you managed to scan for beacon ?
    You mentioned that you found if the beacon datasize is above 20 bytes you can't send it via ble_nus_string_send(). I assume that you have managed to scan for beacon with smaller than 20 bytes payload ?
    If you haven't implemented the code to scan, please look at the examples in ble_central folder.
  • The problem is how do I get the beacon data with more than 20 bytes in nRF51. Not sending, please.
    In anther words, how to achieve the condition in BLE_GAP_EVT_ADV_REPORT events (line 336 of attached main.c)
    if ((p_adv_report->dlen == 30 ) && (ble_state == BLE_CONNECTED) && ...
    where p_adv_report->dlen could never be 30 due to S130 limitation.
  • Are you sure it was because of :
    How do you know if you receive the beacon advertising packet or not ? If you simply call ble_nus_string_send() when it matched then it will never send out the notification to the phone because the length is over 20 bytes.
    Please try to test again with just toggling a GPIO or printout the log. Also try to test with simple check for example only use "if ((p_adv_report->dlen == 30 )  " or just printout any advertising packet you receives.
    As far as I know the nRF51 shouldn't have any trouble scanning for beacon having more than 20 bytes payload.
  • You're right. I wasn't thinking straight and misunderstood. Now I can wake up from BLE idle by a specific beacon signal. Thank you very much for the help.
