NB-IOT JIO SIM Not connecting asset tracker Work Up to RRC Connected and stuck there.
Using NB- IOT JIO SIM in india, not connecting asset tracker Work Up to RRC Connected and stuck there. This is custom code very similar to asset tracker example. We are using custom board, same setup works fine on Ibasis SIM in USA.
[00:00:00.215,576] [0m<inf> asset_tracker: Connecting to LTE network.[0m
[00:00:00.215,942] [0m<inf> asset_tracker: This may take several minutes.[0m
[00:00:00.223,205] [0m<dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=0,1,1,0[0m
[00:00:00.259,643] [0m<inf> lte_lc: PDP Context: AT+CGDCONT=0,"IPV6","JioIPIoT"[0m
[00:00:00.267,608] [0m<dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=0,1,1,0[0m
[00:00:27.635,711] [0m<dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"C061","00282218",9
[0m
[00:00:27.636,444] [0m<inf> asset_tracker: LTE cell changed: Cell ID: 2630168, Tracking area: 49249[0m
trace-2021-07-13T00-06-58.563Z.pcapng
trace-2021-07-13T00-06-58.563Z.bin
  • Hardik.Harpal said:
    Can AT_Client example running with link monitor can provide modem trace by default or do I have to change prj config changes to enable it?
     The AT Client sample does not have the correct config enabled by default, you have to add CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y to the prj.conf file.
    Hardik.Harpal said:
    Can you analyze this  new log withing next 22 hours?
     I am dependent on the schedule of the modem team, but if you provide me the trace within the next hour they should have enough time to analyze it by tomorrow morning.
    Unfortunately, the converted modem logs are only for use internally in Nordic so I can't provide the converted file, but I will try to provide the relevant information (LTE Physical, MAC, RRC, NAS signaling).
    Heidi
  • Application: mqtt_simple, modem FW:1.2.3, board: nrf91DK, NCS1.6.0
    5808.mqtt_simple.rar
    Application Log:
    16:01:22.338, *** Booting Zephyr OS build v2.6.0-rc1-ncs1 ***
    16:01:23.337, [00:00:00.212,249] [0m<inf> mqtt_simple: The MQTT simple sample started[0m
    16:01:23.448, [00:00:00.218,902] [0m<inf> mqtt_simple: Disabling PSM and eDRX[0m
    16:01:23.448, [00:00:00.219,696] [0m<inf> mqtt_simple: LTE Link Connecting...[0m
    16:02:17.323, +CEREG: 2,"C057","00094218",9,0,0,"11100000","11100000"
    16:02:17.445, +CSCON: 1
    16:02:17.666, +CEREG: 0,"C057","00094218",9,0,8,"11100000","11100000"
    16:02:17.666, +CSCON: 0
    trace-2021-08-03T10-44-01.054Z.pcapng
    trace-2021-08-03T10-44-01.054Z.bin
  • There are a lot of traces lost during decoding, which isn't something we've seen before. Unfortunately, our tracing tool experts aren't back to work until next week.
    The last NAS level trace shows that it is requesting RRC connection establishment for the Attach Request which was not the case in MFW 1.3.0 in which Attach procedure was blocked due to reset loop restriction.
  • Okay. So let's wait for next week, If anything required again, just let me know.
    If any progress made from my side I will update you.
