NB-IOT JIO SIM Not connecting asset tracker Work Up to RRC Connected and stuck there.
Using NB- IOT JIO SIM in india, not connecting asset tracker Work Up to RRC Connected and stuck there. This is custom code very similar to asset tracker example. We are using custom board, same setup works fine on Ibasis SIM in USA.
[00:00:00.215,576] [0m<inf> asset_tracker: Connecting to LTE network.[0m
[00:00:00.215,942] [0m<inf> asset_tracker: This may take several minutes.[0m
[00:00:00.223,205] [0m<dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=0,1,1,0[0m
[00:00:00.259,643] [0m<inf> lte_lc: PDP Context: AT+CGDCONT=0,"IPV6","JioIPIoT"[0m
[00:00:00.267,608] [0m<dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=0,1,1,0[0m
[00:00:27.635,711] [0m<dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"C061","00282218",9
[0m
[00:00:27.636,444] [0m<inf> asset_tracker: LTE cell changed: Cell ID: 2630168, Tracking area: 49249[0m
trace-2021-07-13T00-06-58.563Z.pcapng
trace-2021-07-13T00-06-58.563Z.bin
  • There are a lot of traces lost during decoding, which isn't something we've seen before. Unfortunately, our tracing tool experts aren't back to work until next week.
    If I collect log from old trace collector, I am using trace collector v2 preview v0.0.10, is it possible to analyze log without tracing tool expert.  I am thinking may be issue with this preview version and old modem firmware version 1.2.3
  • Hi again,
    So we had the tracing tool experts take a look at the traces you provided.
    The MFW 1.3.0 log seems to be ok from a tracing perspective, i.e. no errors. So if you could get a new log with 1.3.0 starting from startup and about 1 minute long. Please confirm that the reset loop detection is not active before taking the log. Modem domain event notifications, including notifications of the modem reset loop restriction's activation, can be subscribed with AT%MDMEVAT=1.
    With regard to the 1.2.3 log there are a lot of errors, and we suspect the problem lies in NCS.
    Which version of NCS are you using with MFW 1.2.3, and which version are you using with MFW 1.3.0?
    Heidi
  • NCS v1.5.1 in both cases.
    Just for information same setup works in the USA(around Silicon Valley) with iBasis SIMs on both NBIoT and CAT-M networks.
    I will provide log, but previous log was similar from starting and 1 minute long.
    I will do AT+CFUN=0 before running this firmware.
  • Please find modem trace NCS 1.5.1. More info (LTE Physical, MAC, RRC, NAS signaling) is required by JIO. Info already there in PCAP is not sufficient for them to analyze issue.
     trace-2021-08-12T09-23-55.246Z.bin
    trace-2021-08-12T09-23-55.246Z.pcapng
    Unfortunately, in the new log, the Attach is still blocked by the modem reset loop detection.
    If the modem is reset during the wait period (i.e during the blocking), the wait period is restarted with the initial wait time of 30 minutes.
    There is a network cell available according to the log, but you must keep the device powered on and wait 30 minutes for the reset loop detection to go away.
    Please take a new modem trace of this.
