nRF52 Ble Bonding freezing Error
Hi, Dev Zone.
thanks for help : )
i'm try to porting DK Board's ble Boanding function to Target Board.
DK is working success.
refer to 16.0.0 SDK and 7.0.1 Soft device
when i boot my target board, it's look like freezing.
target board also using nRF52840 same SDK and softdevice
run on free RTOS
so, i was check "https://devzone.nordicsemi.com/f/nordic-q-a/51449/lesc-and-freertos" this issue and adjust it
non inturrupt lib and disable mecro and enough thread size
i find error point, try to solve but i it's hard to me,
error point is here
in cc310_backend_rng.c
err_code = CRYS_RndInit(&p_ctx->crys_rnd_state, p_work_buffer); // Fail
ret_val = result_get(err_code);
before this function, i can check print debug message
and &p_ctx->crys_rnd_state, p_work_buffer
both variable's ram address also
but when PC goto CRYS_RndInit() function it's frozen
  • Hello, Dev Zone
    new update and get another question
    today, i was changed config option that
    "NRF_CRYPTO_BACKEND_CC310_INTERRUPTS_ENABLED" TRUE to FALSE
    then it looks like solve freezing problem
    this is Error and Info log message
    Connected // << try to ble connect nRF Connect App and nRF52840
    Data len is set to 0xF4(244)
    // << try to Bonding
    BLE_GAP_EVT_LESC_DHKEY_REQUEST
    Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Bonding, error: 1
    BLE_GAP_EVT_AUTH_STATUS: status=0x1 bond=0x0 lv4: 0 kdist_own:0x0 kdist_peer:0x0
    Disconnected
    to solve this problem,
    what can i check next
    thanks for help
    Best Regardes
  • Hi
    Have you tried to run exactly the same code on the DK (after setting "NRF_CRYPTO_BACKEND_CC310_INTERRUPTS_ENABLED" TRUE to FALSE) and see if the DK works, or if you have the same problem on the DK and on the target board?
    Are you able to get a sniffer trace of the connection and pairing stage?
    If you don't have access to a professional Bluetooth sniffer it is possible to use a Nordic DK as a sniffer as explained here.
    Best regards
    Torbjørn
  • Hi, Torbjørn
    thanks to reply my question.
    first i use default setting "use Interrupts" in DK
    and target board use freeRTOS, that's why we don't use interrupts.
    To tell you the conclusion now it's working well !
    main problem is mutex error.
    block all cc310_mutex_trylock function and then replace freeRTOS's mutec function.
    and then it's working well : )
    i cna check BONEDE sign iin NRF Connect app
    so, now i'm trying to check that sniffer is block or not
    thanks for information.
    best regardes, Empe
  • Hi
    I am glad to hear you found the solution. I will consider the case resolved then Slight smile
    Best regards
    Torbjørn
