custom BLE service/characteristic transmitting data from Device(MCU) to mobile apk
         i have created custom BLE service/characteristic using this ling   https://github.com/NordicPlayground/nRF5x-custom-ble-service-tutorial
So, here i am able to transmitting data from mobile apk to Device(MCU)
But the problem is i need to transmitting data from Device(MCU) to mobile apk...plz suggest me the required changes need to be done.
if u have any example code plz share me..it would be very helpful
  • Hi
    Have you had a look at the ble_app_uart example in the SDK?
    This example is also supported by apps for Android and iOS, and shows you how you can send data bidirectionally between the phone and the nRF device.
    Best regards
    Torbjørn
    I am using nrf52810 custom board.
    Here only single uart we have. I am using it for other interface...so created different custom service using that GitHub guide
    it has characteristic for send and receive the data...but i dont have any idea that how to send the data from controller to apk
    I have referred ble_app_uart example but there They are using Uart service...Here i cannot use uart for ble
  • Hi
    You don't need a physical UART to use the uart service. It is just a service for sending strings of varying lengths from the peripheral to the central, and vice versa.
    When you use the uart service you have a function for sending data called ble_nus_data_send:
    Your service implementation should have something similar.
    Can you send me the source code for your service?
    Then I will take a look and see if I can find this function.
    Best regards
    Torbjørn
  • Hello Ovrebekk,
    Thanks for the response....
    I am using SDK 15.3.0 , MCU nrf52810
    So as i already said i have created service and characteristics using the above git hub link
    any way ill share my code
    main.c
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_template_main main.c
     * @ingroup ble_sdk_app_template
     * @brief Template project main file.
     * This file contains a template for creating a new application. It has the code necessary to wakeup
     * from button, advertise, get a connection restart advertising on disconnect and if no new
     * connection created go back to system-off mode.
     * It can easily be used as a starting point for creating a new application, the comments identified
     * with 'YOUR_JOB' indicates where and how you can customize.
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "fds.h"
    #include "peer_manager.h"
    #include "bsp_btn_ble.h"
    #include "sensorsim.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "ble_cus.h"
    #define DEVICE_NAME                     "abcd"                       /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME               "wxyz"                   /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL                300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    #define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define NOTIFICATION_INTERVAL           APP_TIMER_TICKS(1000)
    #define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    NRF_BLE_GATT_DEF(m_gatt);
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< GATT module instance. */
    BLE_CUS_DEF(m_cus);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
    APP_TIMER_DEF(m_notification_timer_id);
    static uint8_t m_custom_value = 0;
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    /* YOUR_JOB: Declare all services structure your application is using
     *  BLE_XYZ_DEF(m_xyz);
    // YOUR_JOB: Use UUIDs for service(s) used in your application.
    static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
        {CUSTOM_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN }
    static void advertising_start(bool erase_bonds);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        ret_code_t err_code;
        switch (p_evt->evt_id)
            case PM_EVT_BONDED_PEER_CONNECTED:
                NRF_LOG_INFO("Connected to a previously bonded device.");
            } break;
            case PM_EVT_CONN_SEC_SUCCEEDED:
                NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                             ble_conn_state_role(p_evt->conn_handle),
                             p_evt->conn_handle,
                             p_evt->params.conn_sec_succeeded.procedure);
            } break;
            case PM_EVT_CONN_SEC_FAILED:
                /* Often, when securing fails, it shouldn't be restarted, for security reasons.
                 * Other times, it can be restarted directly.
                 * Sometimes it can be restarted, but only after changing some Security Parameters.
                 * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
                 * Sometimes it is impossible, to secure the link, or the peer device does not support it.
                 * How to handle this error is highly application dependent. */
            } break;
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Reject pairing request from an already bonded peer.
                pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
                pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
            } break;
            case PM_EVT_STORAGE_FULL:
                // Run garbage collection on the flash.
                err_code = fds_gc();
                if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                    // Retry.
            } break;
                advertising_start(false);
            } break;
            case PM_EVT_PEER_DATA_UPDATE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
            } break;
            case PM_EVT_PEER_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
            } break;
            case PM_EVT_PEERS_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
            } break;
            case PM_EVT_ERROR_UNEXPECTED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
            } break;
            case PM_EVT_CONN_SEC_START:
            case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            case PM_EVT_PEER_DELETE_SUCCEEDED:
            case PM_EVT_LOCAL_DB_CACHE_APPLIED:
            case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
                // This can happen when the local DB has changed.
            case PM_EVT_SERVICE_CHANGED_IND_SENT:
            case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
    /**@brief Function for handling the Battery measurement timer timeout.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
     *                       app_start_timer() call to the timeout handler.
    static void notification_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        // Increment the value of m_custom_value before nortifing it.
        m_custom_value++;
        err_code = ble_cus_custom_value_update(&m_cus, m_custom_value);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        // Create timers.
        err_code = app_timer_create(&m_notification_timer_id, APP_TIMER_MODE_REPEATED, notification_timeout_handler);
        /* YOUR_JOB: Create any timers to be used by the application.
                     Below is an example of how to create a timer.
                     For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                     one.
           err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
           APP_ERROR_CHECK(err_code); */
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        /* YOUR_JOB: Use an appearance value matching the application's use case.
           err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the YYY Service events.
     * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
     * @details This function will be called for all YY Service events which are passed to
     *          the application.
     * @param[in]   p_yy_service   YY Service structure.
     * @param[in]   p_evt          Event received from the YY Service.
    static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                           ble_yy_service_evt_t * p_evt)
        switch (p_evt->evt_type)
            case BLE_YY_NAME_EVT_WRITE:
                APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
                // No implementation needed.
    /**@brief Function for handling the Custom Service Service events.
     * @details This function will be called for all Custom Service events which are passed to
     *          the application.
     * @param[in]   p_cus_service  Custom Service structure.
     * @param[in]   p_evt          Event received from the Custom Service.
    static void on_cus_evt(ble_cus_t     * p_cus_service,
                           ble_cus_evt_t * p_evt)
        switch(p_evt->evt_type)
            case BLE_CUS_EVT_NOTIFICATION_ENABLED:
                 err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
            case BLE_CUS_EVT_NOTIFICATION_DISABLED:
                err_code = app_timer_stop(m_notification_timer_id);
            case BLE_CUS_EVT_CONNECTED:
            case BLE_CUS_EVT_DISCONNECTED:
            nrf_ble_qwr_init_t  qwr_init = {0};
            ble_cus_init_t      cus_init = {0};
             // Initialize CUS Service init structure to zero.
            cus_init.evt_handler                = on_cus_evt;
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.cccd_write_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.read_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.write_perm);
            err_code = ble_cus_init(&m_cus, &cus_init);
        /* YOUR_JOB: Add code to initialize the services used by the application.
           ble_xxs_init_t                     xxs_init;
           ble_yys_init_t                     yys_init;
           // Initialize XXX Service.
           memset(&xxs_init, 0, sizeof(xxs_init));
           xxs_init.evt_handler                = NULL;
           xxs_init.is_xxx_notify_supported    = true;
           xxs_init.ble_xx_initial_value.level = 100;
           err_code = ble_bas_init(&m_xxs, &xxs_init);
           // Initialize YYY Service.
           memset(&yys_init, 0, sizeof(yys_init));
           yys_init.evt_handler                  = on_yys_evt;
           yys_init.ble_yy_initial_value.counter = 0;
           err_code = ble_yy_service_init(&yys_init, &yy_init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
    /**@brief Function for starting timers.
    static void application_timers_start(void)
        /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
           err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
        // Prepare wakeup buttons.
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        ret_code_t err_code = NRF_SUCCESS;
                NRF_LOG_INFO("Disconnected.");
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
     * @param[in]   event   Event generated when button is pressed.
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
                break; // BSP_EVENT_SLEEP
            case BSP_EVENT_DISCONNECT:
                break; // BSP_EVENT_DISCONNECT
            case BSP_EVENT_WHITELIST_OFF:
                break; // BSP_EVENT_KEY_0
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /**@brief Function for application main entry.
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        NRF_LOG_INFO("Template example started.");
        application_timers_start();
        advertising_start(erase_bonds);
        // Enter main loop.
        for (;;)
            idle_state_handle();
    ble_cus.c
    #include "sdk_common.h"
    #include <string.h>
    #include "nrf_gpio.h"
    #include "boards.h"
    /**@brief Function for handling the Connect event.
     * @param[in]   p_cus       Custom Service structure.
     * @param[in]   p_ble_evt   Event received from the BLE stack.
    static void on_connect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
        p_cus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
        ble_cus_evt_t evt;
        evt.evt_type = BLE_CUS_EVT_CONNECTED;
        p_cus->evt_handler(p_cus, &evt);
    /**@brief Function for handling the Disconnect event.
    static void on_disconnect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
        UNUSED_PARAMETER(p_ble_evt);
        p_cus->conn_handle = BLE_CONN_HANDLE_INVALID;
        ble_cus_evt_t evt;
        evt.evt_type = BLE_CUS_EVT_DISCONNECTED;
    /**@brief Function for handling the Write event.
    static void on_write(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
        ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
        // Custom Value Characteristic Written to.
        if (p_evt_write->handle == p_cus->custom_value_handles.value_handle)
            nrf_gpio_pin_toggle(LED_4);
            if(*p_evt_write->data == 0x01)
                nrf_gpio_pin_clear(20);
            else if(*p_evt_write->data == 0x02)
                nrf_gpio_pin_set(20);
              //Do nothing
        // Check if the Custom value CCCD is written to and that the value is the appropriate length, i.e 2 bytes.
        if ((p_evt_write->handle == p_cus->custom_value_handles.cccd_handle)
            && (p_evt_write->len == 2)
            // CCCD written, call application event handler
            if (p_cus->evt_handler != NULL)
                ble_cus_evt_t evt;
                if (ble_srv_is_notification_enabled(p_evt_write->data))
                    evt.evt_type = BLE_CUS_EVT_NOTIFICATION_ENABLED;
                    evt.evt_type = BLE_CUS_EVT_NOTIFICATION_DISABLED;
                // Call the application event handler.
    void ble_cus_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context)
        ble_cus_t * p_cus = (ble_cus_t *) p_context;
        NRF_LOG_INFO("BLE event received. Event type = %d\r\n", p_ble_evt->header.evt_id);
        if (p_cus == NULL || p_ble_evt == NULL)
            return;
                on_connect(p_cus, p_ble_evt);
                on_disconnect(p_cus, p_ble_evt);
            case BLE_GATTS_EVT_WRITE:
                on_write(p_cus, p_ble_evt);
    /* Handling this event is not necessary
            case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
                NRF_LOG_INFO("EXCHANGE_MTU_REQUEST event received.\r\n");
    /**@brief Function for adding the Custom Value characteristic.
     * @param[in]   p_cus        Battery Service structure.
     * @param[in]   p_cus_init   Information needed to initialize the service.
     * @return      NRF_SUCCESS on success, otherwise an error code.
    static uint32_t custom_value_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
        uint32_t            err_code;
        ble_gatts_char_md_t char_md;
        ble_gatts_attr_md_t cccd_md;
        ble_gatts_attr_t    attr_char_value;
        ble_uuid_t          ble_uuid;
        ble_gatts_attr_md_t attr_md;
        // Add Custom Value characteristic
        memset(&cccd_md, 0, sizeof(cccd_md));
        //  Read  operation on cccd should be possible without authentication.
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
        cccd_md.write_perm = p_cus_init->custom_value_char_attr_md.cccd_write_perm;
        cccd_md.vloc       = BLE_GATTS_VLOC_STACK;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.read   = 1;
        char_md.char_props.write  = 1;
        char_md.char_props.notify = 1;
        char_md.p_char_user_desc  = NULL;
        char_md.p_char_pf         = NULL;
        char_md.p_user_desc_md    = NULL;
        char_md.p_cccd_md         = &cccd_md;
        char_md.p_sccd_md         = NULL;
        ble_uuid.type = p_cus->uuid_type;
        ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID;
        memset(&attr_md, 0, sizeof(attr_md));
        attr_md.read_perm  = p_cus_init->custom_value_char_attr_md.read_perm;
        attr_md.write_perm = p_cus_init->custom_value_char_attr_md.write_perm;
        attr_md.vloc       = BLE_GATTS_VLOC_STACK;
        attr_md.rd_auth    = 0;
        attr_md.wr_auth    = 0;
        attr_md.vlen       = 0;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
        attr_char_value.p_uuid    = &ble_uuid;
        attr_char_value.p_attr_md = &attr_md;
        attr_char_value.init_len  = sizeof(uint8_t);
        attr_char_value.init_offs = 0;
        attr_char_value.max_len   = sizeof(uint8_t);
        err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md,
                                                   &attr_char_value,
                                                   &p_cus->custom_value_handles);
        if (err_code != NRF_SUCCESS)
            return err_code;
        return NRF_SUCCESS;
    uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
        if (p_cus == NULL || p_cus_init == NULL)
            return NRF_ERROR_NULL;
        uint32_t   err_code;
        // Initialize service structure
        p_cus->evt_handler               = p_cus_init->evt_handler;
        // Add Custom Service UUID
        ble_uuid128_t base_uuid = {CUSTOM_SERVICE_UUID_BASE};
        err_code =  sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type);
        VERIFY_SUCCESS(err_code);
        ble_uuid.uuid = CUSTOM_SERVICE_UUID;
        // Add the Custom Service
        err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle);
            return err_code;
        return custom_value_char_add(p_cus, p_cus_init);
    uint32_t ble_cus_custom_value_update(ble_cus_t * p_cus, uint8_t custom_value)
        NRF_LOG_INFO("In ble_cus_custom_value_update. \r\n");
        if (p_cus == NULL)
        uint32_t err_code = NRF_SUCCESS;
        ble_gatts_value_t gatts_value;
        // Initialize value struct.
        memset(&gatts_value, 0, sizeof(gatts_value));
        gatts_value.len     = sizeof(uint8_t);
        gatts_value.offset  = 0;
        gatts_value.p_value = &custom_value;
        // Update database.
        err_code = sd_ble_gatts_value_set(p_cus->conn_handle,
                                          p_cus->custom_value_handles.value_handle,
                                          &gatts_value);
            return err_code;
        // Send value if connected and notifying.
        if ((p_cus->conn_handle != BLE_CONN_HANDLE_INVALID))
            ble_gatts_hvx_params_t hvx_params;
            memset(&hvx_params, 0, sizeof(hvx_params));
            hvx_params.handle = p_cus->custom_value_handles.value_handle;
            hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
            hvx_params.offset = gatts_value.offset;
            hvx_params.p_len  = &gatts_value.len;
            hvx_params.p_data = gatts_value.p_value;
            err_code = sd_ble_gatts_hvx(p_cus->conn_handle, &hvx_params);
            NRF_LOG_INFO("sd_ble_gatts_hvx result: %x. \r\n", err_code);
            err_code = NRF_ERROR_INVALID_STATE;
            NRF_LOG_INFO("sd_ble_gatts_hvx result: NRF_ERROR_INVALID_STATE. \r\n");
        return err_code;
    ble_cus.h
    #ifndef BLE_CUS_H__
    #define BLE_CUS_H__
    #include <stdint.h>
    #include "ble.h"
    /**@brief   Macro for defining a ble_hrs instance.
     * @param   _name   Name of the instance.
     * @hideinitializer
    #define BLE_CUS_DEF(_name)        \
    static ble_cus_t _name;        \
    NRF_SDH_BLE_OBSERVER(_name ## _obs,        \
                         BLE_HRS_BLE_OBSERVER_PRIO,                                                     \
                         ble_cus_on_ble_evt, &_name)
    // CUSTOM_SERVICE_UUID_BASE f364adc9-b000-4042-ba50-05ca45bf8abc
    #define CUSTOM_SERVICE_UUID_BASE         {0xBC, 0x8A, 0xBF, 0x45, 0xCA, 0x05, 0x50, 0xBA, \
                                              0x40, 0x42, 0xB0, 0x00, 0xC9, 0xAD, 0x64, 0xF3}
    #define CUSTOM_SERVICE_UUID               0x1400
    #define CUSTOM_VALUE_CHAR_UUID            0x1401
    /**@brief Custom Service event type. */
    typedef enum
        BLE_CUS_EVT_NOTIFICATION_ENABLED,                             /**< Custom value notification enabled event. */
        BLE_CUS_EVT_NOTIFICATION_DISABLED,                             /**< Custom value notification disabled event. */
        BLE_CUS_EVT_DISCONNECTED,
    } ble_cus_evt_type_t;
    /**@brief Custom Service event. */
    typedef struct
        ble_cus_evt_type_t evt_type;                                  /**< Type of event. */
    } ble_cus_evt_t;
    // Forward declaration of the ble_cus_t type.
    typedef struct ble_cus_s ble_cus_t;
    /**@brief Custom Service event handler type. */
    typedef void (*ble_cus_evt_handler_t) (ble_cus_t * p_bas, ble_cus_evt_t * p_evt);
    /**@brief Battery Service init structure. This contains all options and data needed for
     *        initialization of the service.*/
    typedef struct
        ble_cus_evt_handler_t         evt_handler;                    /**< Event handler to be called for handling events in the Custom Service. */
        uint8_t                       initial_custom_value;           /**< Initial custom value */
        ble_srv_cccd_security_mode_t  custom_value_char_attr_md;     /**< Initial security level for Custom characteristics attribute */
    } ble_cus_init_t;
    /**@brief Custom Service structure. This contains various status information for the service. */
    struct ble_cus_s
        uint16_t                      service_handle;                 /**< Handle of Custom Service (as provided by the BLE stack). */
        ble_gatts_char_handles_t      custom_value_handles;           /**< Handles related to the Custom Value characteristic. */
        uint16_t                      conn_handle;                    /**< Handle of the current connection (as provided by the BLE stack, is BLE_CONN_HANDLE_INVALID if not in a connection). */
        uint8_t                       uuid_type;
    /**@brief Function for initializing the Custom Service.
     * @param[out]  p_cus       Custom Service structure. This structure will have to be supplied by
     *                          the application. It will be initialized by this function, and will later
     *                          be used to identify this particular service instance.
     * @return      NRF_SUCCESS on successful initialization of service, otherwise an error code.
    uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init);
    /**@brief Function for handling the Application's BLE Stack events.
     * @details Handles all events from the BLE stack of interest to the Battery Service.
     * @note
    void ble_cus_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context);
    /**@brief Function for updating the custom value.
     * @details The application calls this function when the cutom value should be updated. If
     *          notification has been enabled, the custom value characteristic is sent to the client.
     * @note
     * @param[in]   p_bas          Custom Service structure.
     * @param[in]   Custom value
    uint32_t ble_cus_custom_value_update(ble_cus_t * p_cus, uint8_t custom_value);
    #endif // BLE_CUS_H__
    plz give me a solution its little urgent...
    thanks in advance
  • Hi
    Thanks for the update.
    In this service it is the ble_cus_custom_value_update(ble_cus_t * p_cus, uint8_t custom_value) function that is used to send an update from the server in the peripheral to the client on the phone side.
    As noted in the comments it is necessary for the client (phone) to enable notification on the characteristic in order for it to receive notifications.
    When using the nRF Connect mobile app you enable notifications by clicking the three arrow symbol on the characteristic in question.
    Best regards
    Torbjørn
