Ble Bonding - error of unknown cause
Hi, Dev Zone.
thanks for help : )
I'm try to porting DK Board's Ble Bonding function to Target Board.
1st_question <- this is my first question links
main problem is freezing and reason is mutex error, that use cc310 mutex lock function,
so i was chenged to cc310 mutex function to freeRTOS mutex lock function to so solve it and looks like work it well
and now get another problem that can know error case
when processing Ble bonding between my device and nRF Connect App, it means when bonding request message send from App to my board
my board stop somewhere and reboot
i don't know why and hard to find stop point. that's why re make issue
this is my App's log
Connecting to MAC:ADD
gatt = device.coonnectGatt(autoConnect = false, TRANSPORT_LE)
[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
Connected to MAC:ADD
[Broadcast]Action received: androide.bluetooth.device.action.ACL_CONNECTED
Discovering service
gatt.discoverService()
[Callback]Service discovered with status: 0
Service discovered
Generic Access (0x1800)
gatt.setCharacteristicNotification(...., true)
device.createBond()
[Broadcast]Action received: androide.bluetooth.device.action.BOND_STATE_CHEANGED, bond state change to: BOND_BONDING(11)
[Broadcast]Action received: androide.bluetooth.device.action.BOND_STATE_CHEANGED, bond state change to: BOND_BONDING(12)
Device bonded
this is my device log
Connected
Data len is set to 0xF4(244)
BLE_GAP_EVT_LESC_DHKEY_REQUEST
Calling sd_ble_gap_lesc_dhkey_reply on conn_handle: 0
Generating ECC key pair
Event PM_EVT_CONN_SEC_START
Connection security produre started: Peripheral, conn_handle: 0, procedure: Bonding
Event PM_EVT_SEC_PARAMS_REQ
Security parameter request
after reboot, all function, auto connect, bonding working well
It would be a great help to correct the error if you tell us the possible cause or point of the error.
#Ble #Ble_Bonding #Bonding
thank you.
Best Regardes
    Have you tried to see if bonding works ok if you disable LESC support (i.e. set SEC_PARAM_LESC = 0)? Also, are you calling the nrf_ble_lesc_request_handler() function periodically like in the ble_app_hrs example?
    Vidar
    Edit: Forgot that we do have an example with Freertos+LESC in our nRF5 Thread & Zigbee SDK. Maybe that example could serve as a reference: https://devzone.nordicsemi.com/f/nordic-q-a/74337/use-the-le-secure-connections-in-the-ble_thread_dyn_mtd_coap_cli-example
  • Hello, Vidar
    thanks for answer
    yes, i try Enable and disable both result are same
    here is full log (i was turn on Error, Warning, Info, Debug Message ) - using LESC 0
    Erase bonds!
    Event PM_EVT_PEERS_DELETE_SUCCEEDED
    All peers deleted.
    BLE event: 0x10.
    Requesting to update ATT MTU to 247 bytes on connection 0x0.
    Updating data length to 251 on connection 0x0.
    Connected
    BLE event: 0x1c.
    BLE event: 0x3a.
    ATT MTU updated to 247 bytes on connection 0x0 (response).
    ATT MTU exchange completed. central 0xf7 peripheral 0xf7
    BLE event: 0x24.
    Data length updated to 123 on connection 0x0.
    max_rx_octets: 123
    max_tx_octets: 123
    max_rx_time: 1096
    max_tx_time: 1096
    BLE event: 0x12.
    BLE event: 0x23.
    Peer on connection 0x0 requested a data length of 123 bytes.
    Updating data length to 123 on connection 0x0.
    BLE event: 0x24.
    max_rx_octets: 123
    max_tx_octets: 123
    max_rx_time: 1096
    max_tx_time: 1096
    BLE event: 0x12.
    BLE event: 0x13.
    Connection security procedure started: role: Peripheral, conn_handle: 0, procedure: Bonding
    Event PM_EVT_CONN_SEC_PARAMS_REQ
    BLE event: 0x12.
    BLE event: 0x1a.
    BLE event: 0x19.
    Event PM_EVT_CONN_SEC_SUCCEEDED
    here is full log ( also turn on Error, Warning, Info, Debug Message ) - using LESC 1
    Erase bonds!
    All peers deleted.
    BLE event: 0x10.
    Connected
    BLE event: 0x1c.
    BLE event: 0x3a.
    BLE event: 0x24.
    max_rx_octets: 123
    max_tx_octets: 123
    max_rx_time: 1096
    max_tx_time: 1096
    BLE event: 0x12.
    BLE event: 0x23.
    BLE event: 0x24.
    max_rx_octets: 123
    max_tx_octets: 123
    max_rx_time: 1096
    max_tx_time: 1096
    BLE event: 0x12.
    BLE event: 0x13.
    BLE event: 0x18.
    BLE event: 0x12.
    BLE event: 0x12.
    BLE event: 0x1a.
    BLE event: 0x19.
    situation are same both get BLE event fleg : 0x19 "Authentication procedure completed with status"
    and send PM_EVT_CONN_SEC_SUCCEEDED and stuck in somewhere
    after that log, device go to reset mode via watch-dog
    ( when i block watch-dog, stuck in somewhere and no-respons)
    this function is run on another thread,
    it means using freeRTOS, useing several thread, initialize in main thread and lesc handler is working on ble thread
    ble thread's job is only work update app's time and call lesc handler
    ++ test that run (initialize and lesc handler) as same thread, it's situation result is same
    Thanks
    Best Regards, Empe
     What's the status code? PM_EVT_CONN_SEC_SUCCEEDED indicate that the bonding procedure completed succesfully, so maybe it's something else that causes your program to hang. Have you tried to debug the app to see if the program maybe gets stuck in one of your threads?
    Vidar
    thanks for reply and sorry for late update.
    now, i'm solve stuck problem, i don't now true reason but maybe thread's size problem
    links <- this is my new post
    try to insert debug code and looks like find some error point
    when your not busy, please check it once
    thanks for help
    best regards
