Problem with I and Q Samples During the Reference Period of CTE Packets
Hi
As described in this white paper: https://infocenter.nordicsemi.com/pdf/nwp_036.pdf during the reference period of CTE signals, 8 samples are taken. These samples contain both "I" and "Q" elements of signal which has different phases relatively.
I have captured the reported "I" and "Q" samples using the samples provided by SDK:
For the reference period, I can not see any phase difference between "I" and "Q" elements (while it should be different). I have visualized the data and you can see the result in the below images:
IQ samples with 2us switching slots and using PCB antenna:
IQ samples with 1us switching slots and using PCB antenna:
IQ samples with 1us switching slots and using array antenna:
As you can see, in all conditions, the reference period has the similar behavior. I have plotted a third party product which uses the CTE packets and you can see the visualized data here,
Obviously the "I" and "Q" samples are in different phases during the reference period. What is wrong in the above nRF examples?
Saleh
  • Hi Louis
    This is simply plotting the IQ samples reported by the MCU without any modification. Print the IQ samples using UART2USB line and then store the result in a file. In a for loop, go over the IQ samples and print them:
    printf("%i,%i, i_val, q_val)
    Then open the file that you've stored the IQ log by a python script and plot the numbers:
    import matplotlib.pyplot as plt
    IQ_LOG_FILE = "iq_raw_log/iq.txt"
    def read_file_to_lists(file_name):
        with open(file_name, 'r') as f:
            # Read each line, split the string by spaces, and convert to integers
            return [list(map(int, line.split())) for line in f]
    def plot_iq(samples):
        i_sample = samples[::2]
        q_sample = samples[1::2]
        plt.plot(i_sample, label='I')
        plt.plot(q_sample, label='Q')
        plt.legend()
        plt.show()
    if __name__ == '__main__':
        lists_from_file = read_file_to_lists(IQ_LOG_FILE)
        plot_iq(lists_from_file[2])
    It assumes the IQ is stored into the file in a format like this:
    i11, q11, i12, q12, ...., i1n, q1n
    i21, q21, i22, q22, ...., i2n, q2n
    Each line has the IQ samples of one single CTE capture, I comes first and then Q, and they are seperated by comma
