sorry if this is a trivial issue, but I've been strugling with this for a while, so I decided to just ask for help.
For context, I'm trying to create an application for Thingy 91 that will take measurements and publish them over MQTT every 15 minutes/1 hour/ couple hours and in the meanwhile consumes the least power. In the future I'd most likely try to do it on a cutom board built around nrf9160, powered by a battery.
Playing around with sample apps I couldn't see the current draw go below a few mA, so I decided to test a blank app (basicaly void main(){} ), trying to apply as many power saving options I could find on this forum and the result was around 600 uA. I've tried using:
- k_sleep
- k_cpu_idle
NRF_REGULATORS->SYSTEMOFF = 1; for(;;){}as suggested hereCONFIG_POWER_OPTIMIZATION_ENABLE=y CONFIG_USE_UI_MODULE=n CONFIG_LIGHT_SENSOR=n
as suggested here- config options generated by the Online Power Profiler
but to be fair, as the current draw was around 600 uA from the start, those options didn't make much impact.
I've also modified the mqtt_sample application, so that it doesn't subscribe to an topics, but just publishes and goes to sleep for 30 seconds a few times and the current I've measured during the period of sleep was varying between 1 mA and 20 mA (although mostly stayed below 5 mA).
I've also seen this thread, which was very insightful, but ultimately didn't help me find a solution (or at least how to implement it, or at the very least, I didn't understand it well enough I guess).
Are there any power saving options that I'm missing? Any more modules that I could disable? Is it possible to reduce the current draw dramaticaly for a specific amount of time and not having to rely on external interrupt? Maybe any other suggestions how I could implement an application like what I've described at the begining?
Paweł
