processing error related to NRF5340 Kit
in fact the error that i posted is related to this file and exactly to the bloc in grey on nvic.h file
"  C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/arch/arm/aarch32/cortex_m/nvic.h:15:44: error: pasting ")" and "_P_arm_num_irq_priority_bits" does not give a valid preprocessing token  "
C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/arch/arm/aarch32/cortex_m/nvic.h:15:32: error: 'arm_v8m_nvic' undeclared (first use in this function)
 C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/devicetree.h:463:48: error: expected ')' before '_P_arm_num_irq_priority_bits'
C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/arch/arm/aarch32/exc.h:24:36: note: to match this '('
1> C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/arch/arm/aarch32/cortex_m/nvic.h:15:28: error: missing binary operator before token "("
i'm getting these couple of errors do you know if there's a link between them
because my error is certainly a processing error
can you help with this please
knowing that i just tried to open another project from a different directory then the BME280 project
it went all on collapse !
can you please help me please
this is the message i'm getting
 i really need help
Building ‘C:/Users/rzaafouri/ncs/v1.5.1/zephyr/misc/empty_file.c’ from solution ‘build’ in configuration ‘Common’
Building ‘C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
Building ‘C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
1> 'zephyr/misc/generated/syscalls.json' is up to date
Building ‘zephyr/misc/generated/struct_tags.json’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
1> 'zephyr/include/generated/driver-validation.h' is up to date
Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
1> 'zephyr/include/generated/kobj-types-enum.h' is up to date
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
1> 'zephyr/include/generated/syscall_dispatch.c' is up to date
Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
1> zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj does not exist.
1> Compiling ‘offsets.c’
1> C:\Users\rzaafouri\ncs\v1.5.1-rc1\toolchain\opt/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.4.99-ncs2 -DKERNEL -DNRF5340_XXAA_APPLICATION -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I../../../kernel/include -I../../../arch/arm/include -I../../../include -Izephyr/include/generated -I../../../soc/arm/nordic_nrf/nrf53 -IC:/Users/rzaafouri/ncs/v1.5.1/nrf/include -IC:/Users/rzaafouri/ncs/v1.5.1/modules/hal/nordic/nrfx -IC:/Users/rzaafouri/ncs/v1.5.1/modules/hal/nordic/nrfx/drivers/include -IC:/Users/rzaafouri/ncs/v1.5.1/modules/hal/nordic/nrfx/mdk -I../../../modules/hal_nordic/nrfx/. -IC:/Users/rzaafouri/ncs/v1.5.1/modules/hal/cmsis/CMSIS/Core/Include -isystem ../../../lib/libc/minimal/include -isystem c:/users/rzaafouri/ncs/v1.5.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem c:/users/rzaafouri/ncs/v1.5.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem C:/Users/rzaafouri/ncs/v1.5.1/nrfxlib/crypto/nrf_cc312_platform/include -Os -imacros C:/Users/rzaafouri/ncs/v1.5.1/zephyr/samples/hello_world/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m33 -mthumb -mabi=aapcs -imacros C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.5.1/zephyr/samples/hello_world=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.5.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.5.1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MF C:/Users/rzaafouri/ncs/v1.5.1/zephyr/samples/hello_world/build_nrf5340dk_nrf5340_cpuapp/zephyr\CMakeFiles\offsets.dir\arch\arm\core\offsets\offsets.c.obj.d -fno-diagnostics-show-caret -o zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj -c C:/Users/rzaafouri/ncs/v1.5.1/zephyr/arch/arm/core/offsets/offsets.c
1> In file included from ../../../include/arch/arm/aarch32/arch.h:20,
1>                  from ../../../include/arch/cpu.h:19,
1>                  from ../../../include/kernel_includes.h:33,
1>                  from ../../../include/kernel.h:17,
1>                  from C:/Users/rzaafouri/ncs/v1.5.1/zephyr/arch/arm/core/offsets/offsets_aarch32.c:28,
1>                  from C:/Users/rzaafouri/ncs/v1.5.1/zephyr/arch/arm/core/offsets/offsets.c:12:
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:15:21: warning: implicit declaration of function 'DT_INST' [-Wimplicit-function-declaration]
1> ../../../include/devicetree.h:2176:24: note: in definition of macro 'DT_CAT'
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:22:27: note: in expansion of macro 'DT_PROP'
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:22:35: note: in expansion of macro 'NVIC_NODEID'
1> ../../../include/arch/arm/aarch32/exc.h:24:41: note: in expansion of macro 'NUM_IRQ_PRIO_BITS'
1> ../../../include/arch/arm/aarch32/exc.h:60:31: note: in expansion of macro 'Z_EXC_PRIO'
1> ../../../include/arch/arm/aarch32/asm_inline_gcc.h:62:9: note: in expansion of macro '_EXC_IRQ_DEFAULT_PRIO'
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:15:44: error: pasting ")" and "_P_arm_num_irq_priority_bits" does not give a valid preprocessing token
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:15:32: error: 'arm_v8m_nvic' undeclared (first use in this function)
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:15:32: note: each undeclared identifier is reported only once for each function it appears in
1> ../../../include/devicetree.h:463:48: error: expected ')' before '_P_arm_num_irq_priority_bits'
1> ../../../include/devicetree.h:2176:30: note: in definition of macro 'DT_CAT'
1> In file included from ../../../include/arch/arm/aarch32/arch.h:26,
1> ../../../include/arch/arm/aarch32/exc.h:24:36: note: to match this '('
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:15:28: error: missing binary operator before token "("
1> ../../../include/arch/arm/aarch32/cortex_m/cmsis.h:96:25: note: in expansion of macro 'NUM_IRQ_PRIO_BITS'
Build failed
  • How did you add it manually? That is not something you should have to do.
  • i did it through chocolatey and python packages and i disabled it in the toolchain manager .
    i had multiple problems with the flashing through programmer in the nrf connect so i decided to install west manually . and it went better and smoother the flashing and erasing.
    i will proceed to the reinstallation of everything
    i will keep you updated if something went wrong
  • You can also try installing v1.6.1 in the Toolchain Manager if you don't already have it, and see if that sdk works. It will be entirely separate from v1.5.1.
    Also download and install the nRF Command Line Tools: https://www.nordicsemi.com/Products/Development-tools/nrf-command-line-tools/download
    If nRF Command Line Tools is already installed, then click "repair" in the installer.
  • thank you oivind,
    i fixed the compilation environment
    m trying to build the bme280 sample and i'm getting the devicetree error
    can you help me with this
    1> zephyr/linker_zephyr_prebuilt.cmd does not exist.
    1> Combining ‘zephyr/linker_zephyr_prebuilt.cmd’
    1> C:\Users\rzaafouri\ncs\v1.6.1\toolchain\opt\bin\arm-none-eabi-gcc.exe -x assembler-with-cpp -undef -MD -MF linker_zephyr_prebuilt.cmd.dep -MT zephyr/linker_zephyr_prebuilt.cmd -D_LINKER -D_ASMLANGUAGE -IC:/Users/rzaafouri/ncs/v1.6.1/zephyr/include -IC:/Users/rzaafouri/ncs/v1.6.1/nrf/samples/sensor/bme280/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated -IC:/Users/rzaafouri/ncs/v1.6.1/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/Users/rzaafouri/ncs/v1.6.1/zephyr/lib/libc/minimal/include -IC:/Users/rzaafouri/ncs/v1.6.1/nrf/include -IC:/Users/rzaafouri/ncs/v1.6.1/modules/hal/cmsis/CMSIS/Core/Include -IC:/Users/rzaafouri/ncs/v1.6.1/modules/hal/nordic/nrfx -IC:/Users/rzaafouri/ncs/v1.6.1/modules/hal/nordic/nrfx/drivers/include -IC:/Users/rzaafouri/ncs/v1.6.1/modules/hal/nordic/nrfx/mdk -IC:/Users/rzaafouri/ncs/v1.6.1/zephyr/modules/hal_nordic/nrfx/. -D__GCC_LINKER_CMD__ -DUSE_PARTITION_MANAGER=0 -DLINKER_ZEPHYR_PREBUILT -E C:/Users/rzaafouri/ncs/v1.6.1/zephyr/soc/arm/nordic_nrf/nrf53/linker.ld -P -o linker_zephyr_prebuilt.cmd
    Building ‘zephyr/CMakeFiles/linker_zephyr_prebuilt_script_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘zephyr/linker_zephyr_prebuilt_script_target’ from solution ‘build’ in configuration ‘Common’
    Building ‘cmake_object_order_depends_target_zephyr_prebuilt’ from solution ‘build’ in configuration ‘Common’
    Building ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’
    2> CMakeFiles/app.dir/src/main.c.obj does not exist.
    2> Compiling ‘main.c’
    2> C:\Users\rzaafouri\ncs\v1.6.1\toolchain\opt/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.6.0-rc1-ncs1 -DKERNEL -DNRF5340_XXAA_APPLICATION -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/Users/rzaafouri/ncs/v1.6.1/zephyr/include -Izephyr/include/generated -IC:/Users/rzaafouri/ncs/v1.6.1/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/Users/rzaafouri/ncs/v1.6.1/nrf/include -IC:/Users/rzaafouri/ncs/v1.6.1/modules/hal/cmsis/CMSIS/Core/Include -IC:/Users/rzaafouri/ncs/v1.6.1/modules/hal/nordic/nrfx -IC:/Users/rzaafouri/ncs/v1.6.1/modules/hal/nordic/nrfx/drivers/include -IC:/Users/rzaafouri/ncs/v1.6.1/modules/hal/nordic/nrfx/mdk -IC:/Users/rzaafouri/ncs/v1.6.1/zephyr/modules/hal_nordic/nrfx/. -isystem C:/Users/rzaafouri/ncs/v1.6.1/zephyr/lib/libc/minimal/include -isystem c:/users/rzaafouri/ncs/v1.6.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem c:/users/rzaafouri/ncs/v1.6.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem C:/Users/rzaafouri/ncs/v1.6.1/nrfxlib/crypto/nrf_cc312_platform/include -Os -imacros C:/Users/rzaafouri/ncs/v1.6.1/nrf/samples/sensor/bme280/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -imacros C:/Users/rzaafouri/ncs/v1.6.1/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.6.1/nrf/samples/sensor/bme280=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.6.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.6.1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MF C:/Users/rzaafouri/ncs/v1.6.1/nrf/samples/sensor/bme280/build_nrf5340dk_nrf5340_cpuapp/CMakeFiles\app.dir\src\main.c.obj.d -fno-diagnostics-show-caret -o CMakeFiles/app.dir/src/main.c.obj -c ../src/main.c
    2> ../src/main.c:21:2: error: #error Your devicetree has no enabled nodes with compatible "bosch,bme280"
    Build failed
  • Just add this overlay to the sample, seems to work for me.
    nrf5340dk_nrf5340_cpuapp.overlay:
    &i2c1 {
    	bme280: bme280@76 {
    		compatible = "bosch,bme280";
    		reg = <0x76>;
    		label = "BME280";
    I2C_1 uses P1.02 for sda-pin and P1.03 for scl-pin.
