processing error related to NRF5340 Kit
in fact the error that i posted is related to this file and exactly to the bloc in grey on nvic.h file
"  C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/arch/arm/aarch32/cortex_m/nvic.h:15:44: error: pasting ")" and "_P_arm_num_irq_priority_bits" does not give a valid preprocessing token  "
C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/arch/arm/aarch32/cortex_m/nvic.h:15:32: error: 'arm_v8m_nvic' undeclared (first use in this function)
 C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/devicetree.h:463:48: error: expected ')' before '_P_arm_num_irq_priority_bits'
C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/arch/arm/aarch32/exc.h:24:36: note: to match this '('
1> C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/arch/arm/aarch32/cortex_m/nvic.h:15:28: error: missing binary operator before token "("
i'm getting these couple of errors do you know if there's a link between them
because my error is certainly a processing error
can you help with this please
knowing that i just tried to open another project from a different directory then the BME280 project
it went all on collapse !
can you please help me please
this is the message i'm getting
 i really need help
Building ‘C:/Users/rzaafouri/ncs/v1.5.1/zephyr/misc/empty_file.c’ from solution ‘build’ in configuration ‘Common’
Building ‘C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
Building ‘C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
1> 'zephyr/misc/generated/syscalls.json' is up to date
Building ‘zephyr/misc/generated/struct_tags.json’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
1> 'zephyr/include/generated/driver-validation.h' is up to date
Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
1> 'zephyr/include/generated/kobj-types-enum.h' is up to date
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
1> 'zephyr/include/generated/syscall_dispatch.c' is up to date
Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
1> zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj does not exist.
1> Compiling ‘offsets.c’
1> C:\Users\rzaafouri\ncs\v1.5.1-rc1\toolchain\opt/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.4.99-ncs2 -DKERNEL -DNRF5340_XXAA_APPLICATION -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I../../../kernel/include -I../../../arch/arm/include -I../../../include -Izephyr/include/generated -I../../../soc/arm/nordic_nrf/nrf53 -IC:/Users/rzaafouri/ncs/v1.5.1/nrf/include -IC:/Users/rzaafouri/ncs/v1.5.1/modules/hal/nordic/nrfx -IC:/Users/rzaafouri/ncs/v1.5.1/modules/hal/nordic/nrfx/drivers/include -IC:/Users/rzaafouri/ncs/v1.5.1/modules/hal/nordic/nrfx/mdk -I../../../modules/hal_nordic/nrfx/. -IC:/Users/rzaafouri/ncs/v1.5.1/modules/hal/cmsis/CMSIS/Core/Include -isystem ../../../lib/libc/minimal/include -isystem c:/users/rzaafouri/ncs/v1.5.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem c:/users/rzaafouri/ncs/v1.5.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem C:/Users/rzaafouri/ncs/v1.5.1/nrfxlib/crypto/nrf_cc312_platform/include -Os -imacros C:/Users/rzaafouri/ncs/v1.5.1/zephyr/samples/hello_world/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m33 -mthumb -mabi=aapcs -imacros C:/Users/rzaafouri/ncs/v1.5.1/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.5.1/zephyr/samples/hello_world=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.5.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.5.1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MF C:/Users/rzaafouri/ncs/v1.5.1/zephyr/samples/hello_world/build_nrf5340dk_nrf5340_cpuapp/zephyr\CMakeFiles\offsets.dir\arch\arm\core\offsets\offsets.c.obj.d -fno-diagnostics-show-caret -o zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj -c C:/Users/rzaafouri/ncs/v1.5.1/zephyr/arch/arm/core/offsets/offsets.c
1> In file included from ../../../include/arch/arm/aarch32/arch.h:20,
1>                  from ../../../include/arch/cpu.h:19,
1>                  from ../../../include/kernel_includes.h:33,
1>                  from ../../../include/kernel.h:17,
1>                  from C:/Users/rzaafouri/ncs/v1.5.1/zephyr/arch/arm/core/offsets/offsets_aarch32.c:28,
1>                  from C:/Users/rzaafouri/ncs/v1.5.1/zephyr/arch/arm/core/offsets/offsets.c:12:
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:15:21: warning: implicit declaration of function 'DT_INST' [-Wimplicit-function-declaration]
1> ../../../include/devicetree.h:2176:24: note: in definition of macro 'DT_CAT'
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:22:27: note: in expansion of macro 'DT_PROP'
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:22:35: note: in expansion of macro 'NVIC_NODEID'
1> ../../../include/arch/arm/aarch32/exc.h:24:41: note: in expansion of macro 'NUM_IRQ_PRIO_BITS'
1> ../../../include/arch/arm/aarch32/exc.h:60:31: note: in expansion of macro 'Z_EXC_PRIO'
1> ../../../include/arch/arm/aarch32/asm_inline_gcc.h:62:9: note: in expansion of macro '_EXC_IRQ_DEFAULT_PRIO'
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:15:44: error: pasting ")" and "_P_arm_num_irq_priority_bits" does not give a valid preprocessing token
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:15:32: error: 'arm_v8m_nvic' undeclared (first use in this function)
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:15:32: note: each undeclared identifier is reported only once for each function it appears in
1> ../../../include/devicetree.h:463:48: error: expected ')' before '_P_arm_num_irq_priority_bits'
1> ../../../include/devicetree.h:2176:30: note: in definition of macro 'DT_CAT'
1> In file included from ../../../include/arch/arm/aarch32/arch.h:26,
1> ../../../include/arch/arm/aarch32/exc.h:24:36: note: to match this '('
1> ../../../include/arch/arm/aarch32/cortex_m/nvic.h:15:28: error: missing binary operator before token "("
1> ../../../include/arch/arm/aarch32/cortex_m/cmsis.h:96:25: note: in expansion of macro 'NUM_IRQ_PRIO_BITS'
Build failed
  • &i2c1 {
    	status = "okay";
    	sda-pin = < 34 >;
    	scl-pin = < 35 >;
        clock-frequency = <100000>;
    	/* The I2C address could be one of two, here 0x76 is assumed */
    	bme280@76 {
    		compatible = "bosch,bme280";
    		reg = <0x76>;
    		label = "BME280";
    &uart1 {
        status = "disabled";
    yeah exactly but doesn't seem to work
  • [70/155] Building C object CMakeFiles/app.dir/src/main.c.obj
    FAILED: CMakeFiles/app.dir/src/main.c.obj
    C:\Users\rzaafouri\ncs\v1.6.1\toolchain\opt\bin\arm-none-eabi-gcc.exe -DBUILD_VERSION=v2.6.0-rc1-ncs1 -DKERNEL -DNRF5340_XXAA_APPLICATION -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/Users/rzaafouri/ncs/v1.6.1/zephyr/include -Izephyr/include/generated -IC:/Users/rzaafouri/ncs/v1.6.1/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/Users/rzaafouri/ncs/v1.6.1/nrf/include -IC:/Users/rzaafouri/ncs/v1.6.1/modules/hal/cmsis/CMSIS/Core/Include -IC:/Users/rzaafouri/ncs/v1.6.1/modules/hal/nordic/nrfx -IC:/Users/rzaafouri/ncs/v1.6.1/modules/hal/nordic/nrfx/drivers/include -IC:/Users/rzaafouri/ncs/v1.6.1/modules/hal/nordic/nrfx/mdk -IC:/Users/rzaafouri/ncs/v1.6.1/zephyr/modules/hal_nordic/nrfx/. -isystem C:/Users/rzaafouri/ncs/v1.6.1/zephyr/lib/libc/minimal/include -isystem c:/users/rzaafouri/ncs/v1.6.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem c:/users/rzaafouri/ncs/v1.6.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -isystem C:/Users/rzaafouri/ncs/v1.6.1/nrfxlib/crypto/nrf_cc312_platform/include -Os -imacros C:/Users/rzaafouri/ncs/v1.6.1/nrf/samples/sensor/bme280/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -imacros C:/Users/rzaafouri/ncs/v1.6.1/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.6.1/nrf/samples/sensor/bme280=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.6.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/Users/rzaafouri/ncs/v1.6.1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles\app.dir\src\main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj   -c ../src/main.c
    ../src/main.c:21:2: error: #error Your devicetree has no enabled nodes with compatible "bosch,bme280"
       21 | #error Your devicetree has no enabled nodes with compatible "bosch,bme280"
    [83/155] Building C object modules/hal_nordic/nrfx/CMakeFi...v1.6.1/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj
    FATAL ERROR: command exited with status 1: 'C:\Users\rzaafouri\ncs\v1.6.1\toolchain\opt\bin\cmake.EXE' --build 'C:\Users\rzaafouri\ncs\v1.6.1\nrf\samples\sensor\bme280\build_nrf5340dk_nrf5340_cpuapp'
    that's the cmd output
    something is wrong with CMake
  • Try using the exact overlay I provided. Do you still get the same output? And give me the entire log, not just the error.
    And how are you building this? In SES?
  • yes i'm building it in SES
    i tried the same thing as u recommended
    that's the whole log
    C:\Users\rzaafouri\ncs\v1.6.1\nrf\samples\sensor\bme280\build_nrf5340dk_nrf5340_cpuapp>west build -b nrf5340dk_nrf5340_cpuapp
    [3/73] Building C object CMakeFiles/app.dir/src/main.c.obj
    [16/73] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
  • If you are using the overlay I provided, then try in SES:
    Build->Clean Solution
    Project->Run CMake
    Build->Build Solution
    If that doesn't work, give me what is in the output window in SES, when the output window is set to Transcript and Output.
