[Zigbee] Sleepy end device get out of sleep in approx 10 mins
Hi everyone,
I have this question to ask. So I am trying do make an end device that run on low power. I can see that there is an example about the sleepy end device in the Zigbee and Thread SDK 4.1. So i try it and measure the current through the prolifier kit. Because i am running a NRF52833 on a custom board(just some with some io pins to use led and button), i run the code for PCA10100 on the light switch example. Then, I also modify some part of the code like delete the finding and binding part as well as pressing a button for the device to go sleepy but instead got sleepy automatically at startup. In addition, i also use the RTT log instead of the UART backend log.ut
When i first measure the power by the prolifier board version 1, it is get to 2.4uA on average, so good so far. But then, when i measure for a little longer like in 15 mins, the current start to go up to 80uA at 10-11mins i did not even start to commission the device to the coordinator. This is really weird since I keep like 90% of the code in the example. So, I have not modified any part of the code so that i can send it to you. Also, I try to not start the zigbee module and just run  __WFE() and __SEV() in the main while(1) loop and it working just fine. So i have a wild guess that there are some thing need to be done in the zigbee configuration that i miss.
Please help and reply soon, I attach the code i make with this.
Test_lowpower.zip
Hoang Ngoc Tu
  • Hi Marte,
    Sorry for the late reply, I have tested the new setting for the SDK and let the board run for 12 hours straight to find out that the power consumption did not suffer from the waking problem like before. So I guess that your walkaround solve the problem.
    Thank you very much, I could not do it without your support.
    Best regards and have a nice day,
    Tu
