how to interface external MCU host viaUART interface with nrf9160, with only 3 pins from UART (RD,TX,GND)
We would like to use nRF9160 has MODEM only feature, such that MCU in our product can talk to nRF9160 via UART interface.
We have found an sample application [Serial LTE Modem] that comes with nRFConnect SDK , we would need to use this application with following constraint
We have UART TX , UART RX and GND ( 3 signals ) and do not have provision for CTS/RTS or any other additional GPIO for interface MODEM(nRF9160) and our UART I/O signal TTL level is 3.3V
Is this possible to accomplish the same with the sample application [Serial LTE Modem].
External Com port ( 115200 bps, 8N1) ,
Pin connection between nrf9160 and 3.3v ttl-uart-usb cable connected to pc
 1. ( P0.11(RX) to usb to TTL cable (TX))
2. (P0.10(TX) to usb to TTL cable (RX))
3. Common ground
In serial lte modem app .proj file modified to enable  Uart2 based macros and disabled the UART 0 based macro.
Note: I/O switch is kept at 3.3v side
Still couldn't get response for AT commands.
Please let me know is there is a steps to configure UART 2 with no flow control and no additional gpio .
I am using segger embedded studio.
With Best Regards,
Ilanchezhian T
  • Ilanchezhian T said:
    4) Our microcontroller I/O line is 3.3V does the nRF9160 supports 3.3V on its I/O line
     4) Yes. As mentioned above, make sure to configure nRF9160 accordingly.
    6) In our custom hardware , to flash the nrf9160 modem software and its MCU for applications, What are the additional circuitry required other than the uart I/F connections, VCC and GND ?
     6) You will need the 10-pin programming interface in Table 1. Does your board have tight pcb area constraints? If that case, you could convert this to a 6-pin interface. The board will  in any case need to have it's own supply as this is not supplied through the programming interface.
    6.a) I think we need usb and jlink circuitry, please provide your input in this regard
    6.a) Sorry, I am not sure exactly what you are asking for. Could you please explain?
    5) We might need to develop the custom hardware that gets plugged into our product, How easy is to customize the "LTE Serial Modem" software available as part of nrf9160 SDK
    It sounds like changing a few configs and device tree properties will allow you to run the application on a custom board. We are not testing the applications in all possible combinations of configurations, so you would need to perform tests, like any project.
    5.a) If it is very simple only in terms of configurations please provide us some steps to perform this
    This should be feasible. Going through the application description and the section on Connecting with an external MCU should get you started. I will be back with more details.
    One approach, as you are moving forward, might be to demonstrate the setup using an nRF 52 series DK. This setup has been tested, and it allows you to get familiar with the functionality.
    Please also read the section Extending the application
  • 6.a) Question is - Do we need to have  similar hardware circuitry as present in nRF9160 DK ( usb connector and debugger circuitry) in our product in order to code flashing in both Modem Processor and Application Processor.
  • 6.a) Thank you for the clarification. In order to program the nRF9160 SiP you only need the programming interface mentioned as a reply to 6).
    2) What are the necessary UART pins required ( As per the application note we have seen that 5 pins (RTS,CTS,RX,TX,GPIO) are mentioned,
    I think GND pin is also required as the uart signals are not differential signals)
    2) Normally, only the three connections RX, TX and ground are needed for UART to work without flow control. I have not yet been able to confirm whether someone has tested disabling this with serial_lte_modem, specifically.
    2.a) If all the pins are not required ( then RX,TX,GND) is ok to establish connection between modem and our host microcontroller
    2.a) The serial_lte_modem has a config option, CONFIG_SLM_INTERFACE_PIN - Interface GPIO to wake up or exit idle mode, for setting up an additional GPIO between nRF9160 and the external MCU. This GPIO seems to be used for exiting nRF9160 from IDLE or sleep. If you have another way to wake up nRF9160, then only RX, TX and GND are needed between the two devices.
