mqtt_simple example: mqtt_connect error -12
Hello everyone,
I started an evaluation for the Nordic Thingy91 using the "mqtt_simple" example from the SDK1.6.0 version. The Thingy91 is HW-version 1.4.0. Programming is done in SES V5.50c.
The standard-example works (which connects to mqtt.eclipseprojects.io).
I tried to connect to another server without a username and a password and it also worked as intended. I did this by changing the "MQTT_BROKER_HOSTNAME" in Kconfig and the "CONFIG_MQTT_BROKER_HOSTNAME" in prj.conf. I know, only the prj.conf needs to be changed, I changed both to be sure.
Then I changed the host a server which need a specific username or a password. TLS is not used.
I added the username and password in the main.c:
The result is  "mqtt_connect -12":
I found this topic (mqtt connect error - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com))  and increased the buffer size in the prj.conf and Kconfig to 512:
CONFIG_MQTT_MESSAGE_BUFFER_SIZE=512
CONFIG_MQTT_PAYLOAD_BUFFER_SIZE=512
In the mentioned topic, the connect error -12 was solved by increasing buffer sizes. For me, the problem persisted, as shown in the second picture.
What can I do to find the error?
With other MQTT Clients I can connect to the server using the same username and password,
  • Hey Chris,
    Sorry, I forgot to clarify that both password and user_name are structs with a pointer and a size  Ref. zephyr\include\net\mqtt.h
    /** @brief Abstracts UTF-8 encoded strings. */
    struct mqtt_utf8 {
    	const uint8_t *utf8;       /**< Pointer to UTF-8 string. */
    	uint32_t size;             /**< Size of UTF string, in bytes. */
    Please retry with the following, tested by our developer and should work with your application:
    struct mqtt_utf8 password = {
     .utf8 = "password",
     .size = strlen("password")
     struct mqtt_utf8 username = {
     .utf8 = "username",
     .size = strlen("username")
     /* MQTT client configuration */
     client->broker = &broker;
     client->evt_cb = mqtt_evt_handler;
     client->client_id.utf8 = client_id_get();
     client->client_id.size = strlen(client->client_id.utf8);
     client->password = &password;
     client->user_name = &username;
     client->protocol_version = MQTT_VERSION_3_1_1;
    Øyvind
  • Dear Øyvind,
    thank you! Indeed, username and password as a struct works! I just had to copy your example and immediately the Thingy could connect to the server.
    Under your last post, I couldn't find neither a reply button nor a "Verify Answer"-button. I can confirm that the structs do work.
    Thank you for your quick help! Smile
    Have a good day,
    Chris
  • Hi
    I am experiencing the same, however the fix below did not solve the problem for me. Any advice?
