It looks like a possible policy issue - but I was wondering if anyone here has successfully provisioned IoT in this Amazon AWS Region/Endpoint: iot.ap-northeast-1.amazonaws.com ?
johnwest
johnwest
I have not tried this, but it looks like it shouldn't be a problem. Kindly check this. Just make sure that the IoT core instance where the devices are created is in the correct region. Try checking your region.
Hello Swathy,
Yep - did that - and that's why I'm posting here. It appears to be a policy issue. No matter what I do - the IoT ARN always lands in us-east-1.
Maybe you can try what you've suggested and verify it works.
The issue is the policy JSON - no matter what I try there - it always lands in us-east-1.
My JSON-foo isn't great (obviously) - since it's an infinite open bag as to what the correct syntax is for forcing the ARN to land in a certain Region/Endpoint.
Go ahead and do what you've suggested and show (prove) you can control where the Region/Endpoint lands.
I'll look for your post and steps and JSON syntax.
johnwest
Hi John,
I see that you have your problem solved in this other ticket. Kindly continue your conversation there. I am closing this ticket.
Thank you,
Swathy
