direction_finding_connectionless_rx crashes if CONFIG_ASSERT=y
If I enable CONFIG_ASSERT=y this example will crash (or code using the DF APIs)
To reproduce:
- nRF Connect 1.6.1
- In direction_finding_connectionless_rx add CONFIG_ASSERT=y to the prj.conf
- Build direction_finding_connectionless_rx and direction_finding_connectionless_tx
- Flash and run, then you will see the log below on the device running direction_finding_connectionless_rx
Log from the example:
Enable receiving of CTE...
success. CTE receive enabled.
Scan disable...Success.
Waiting for periodic sync lost...
PER_ADV_SYNC[0]: [DEVICE]: 30:A0:F1:E2:87:5D (random), tx_power 127, RSSI -58, CTE AOA, data length 0, data:
ASSERTION FAIL [0] @ WEST_TOPDIR/zephyr/subsys/net/buf.c:800
  • Hi
    I tried this on my end and did not run into an assertion fail like this. Are you running the RX and TX examle projects on nRF52833 DKs or custom boards? Is the RX device connected to an antenna array or is it just using a single antenna?
    Simon
  • Hi thanks for input, at first I useed our custom board with our antenna, however after your reply I also tried rebuilding and re-flashing the RX code on a nRF52833 DK without antenna array, so nRF52833 DK using only single PCB antenna and I get the same crash. I verified that I have no diff in the sdk except:
    ...DF/v1.6.1/zephyr/samples/bluetooth/direction_finding_connectionless_rx ((v2.6.0-rc1-ncs1))
    $ git diff
    diff --git a/samples/bluetooth/direction_finding_connectionless_rx/prj.conf b/samples/bluetooth/direction_finding_connectionless_rx/prj.conf
    index 6de448fa5a..2761c58a9f 100644
    --- a/samples/bluetooth/direction_finding_connectionless_rx/prj.conf
    +++ b/samples/bluetooth/direction_finding_connectionless_rx/prj.conf
    @@ -10,3 +10,4 @@ CONFIG_BT_OBSERVER=y
    # Enable Direction Finding Feature including AoA and AoD
    CONFIG_BT_DF=y
    CONFIG_BT_DF_CONNECTIONLESS_CTE_RX=y
    +CONFIG_ASSERT=y
    \ No newline at end of file
    I'll try to find another nRF52833 DK so that I can flash the transmitter code on that and not use our custom board for TX also if that makes a difference.
  • I now have both TX and RX (without antenna array) running on two nRF52833-DK and I get the same issue, only modification I made is to add the  CONFIG_ASSERT=y in receiver prj.conf
    Here is a full log on RX side. Could it be the issue is that there are many devices around here which causes the problem. I can give it a try in a shielded box to verify that as that could explain why you are not able to reproduce.
    *** Booting Zephyr OS build v2.6.0-rc1-ncs1 ***len]
    Starting Connectionless Locator Demo
    Bluetooth initialization...success
    Scan callbacks register...success.
    Periodic Advertising callbacks register...success.
    Start scanning...success
    Waiting for periodic advertising...[DEVICE]: 14:05:3F:9F:6C:94 (random), AD evt type 3, Tx Pwr: 127, RSSI -81 C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 22:D9:15:03:CB:94 (random), AD evt type 3, Tx Pwr: 127, RSSI -82 C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 5B:A3:06:23:12:4A (random), AD evt type 0, Tx Pwr: 127, RSSI -88 C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 5D:DD:54:53:92:DC (random), AD evt type 0, Tx Pwr: 127, RSSI -87 C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 03:EA:66:FD:62:F6 (random), AD evt type 5, Tx Pwr: 127, RSSI -63 DF Connectionless Beacon App C:0 S:0 D:0 SR:0 E:1 Prim: LE 1M, Secn: LE 2M, Interval: 0x0780 (2400 ms), SID: 0
    success. Found periodic advertising.
    Creating Periodic Advertising Sync...success.
    Waiting for periodic sync...
    [DEVICE]: 00:12:F3:43:44:41 (public), AD evt type 0, Tx Pwr: 127, RSSI -71 C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 00:12:F3:43:44:41 (public), AD evt type 4, Tx Pwr: 127, RSSI -70 NINA-B3-434441 C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: CF:98:95:2E:71:5A (random), AD evt type 3, Tx Pwr: 127, RSSI -85 C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: F1:EE:A5:62:86:31 (random), AD evt type 3, Tx Pwr: 127, RSSI -80 C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 00:12:F3:00:00:39 (public), AD evt type 0, Tx Pwr: 127, RSSI -53 C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 00:12:F3:00:00:39 (public), AD evt type 4, Tx Pwr: 127, RSSI -52 NINA-B3-000039 C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 00:12:F3:58:61:26 (public), AD evt type 0, Tx Pwr: 127, RSSI -88 C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: D5:1F:F2:64:CA:90 (random), AD evt type 3, Tx Pwr: 127, RSSI -82 C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 3C:6F:67:30:FD:B6 (random), AD evt type 3, Tx Pwr: 127, RSSI -73 C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 00:12:F3:00:00:49 (public), AD evt type 0, Tx Pwr: 127, RSSI -47 C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 00:12:F3:00:00:49 (public), AD evt type 4, Tx Pwr: 127, RSSI -46 NINA-B3-000049 C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 00:12:F3:01:19:33 (public), AD evt type 0, Tx Pwr: 127, RSSI -78 C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 00:12:F3:01:19:33 (public), AD evt type 4, Tx Pwr: 127, RSSI -78 NINA-B1-011933 C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 7F:79:EF:92:9B:67 (random), AD evt type 0, Tx Pwr: 127, RSSI -87 C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 69:CC:4E:EA:8A:1D (random), AD evt type 3, Tx Pwr: 127, RSSI -61 C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 01:C8:56:46:29:80 (random), AD evt type 3, Tx Pwr: 127, RSSI -51 C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 00:12:F3:01:33:79 (public), AD evt type 0, Tx Pwr: 127, RSSI -69 C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    [DEVICE]: 00:12:F3:01:33:79 (public), AD evt type 4, Tx Pwr: 127, RSSI -69 ANNA-B1-013379 C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
    PER_ADV_SYNC[0]: [DEVICE]: 03:EA:66:FD:62:F6 (random) synced, Interval 0x0780 (2400 ms), PHY LE 2M
    success. Periodic sync established.
    PER_ADV_SYNC[0]: [DEVICE]: 03:EA:66:FD:62:F6 (random), tx_power 127, RSSI -55, CTE AOA, data length 0, data:
    *** Booting Zephyr OS build v2.6.0-rc1-ncs1 ***len] @ WEST_TOPDIR/zephyr/subsys/net/buf.c:800
  • Tried in a shielded box still crashes for me. ncs 1.6.1 downloaded from toolchain manager.
  • Hi again
    I don't see an assertion fail in the log you posted in your last reply, are you sure this is the complete log? Can you also confirm that you're setting CONFIG_ASSERT=y in the prj.conf file located in ...\NCS v1.x.x\nrf\samples\bluetooth\direction_finding_connectionless_rx\prj.conf?
    Simon
