Hi!
I have a custom board based mostly of the nrf9160DK, where I need communication between nrf52849 and nrf9160 processor.
I have used the code from this ticket that Simon provided in a zip-file uart.zip.
Since it is a custom board I have changed the overlay-files to configure to different pins.
The code is working for for sending from the nrf52 to nrf91 but not in opposite direction (nrf91 to nrf52), and i can't grasp why only one direction.
The nrf9160_pca10090ns.overlay is set to:
&uart2 {
current-speed = <115200>;
status = "okay";
tx-pin = <29>;
rx-pin = <28>;
rts-pin = <27>;
cts-pin = <26>;
with the prj.conf file:
CONFIG_SERIAL=y #CONFIG_TRUSTED_EXECUTION_NONSECURE=y CONFIG_UART_INTERRUPT_DRIVEN=y #CONFIG_MAIN_STACK_SIZE=4096 CONFIG_DEBUG_OPTIMIZATIONS=y CONFIG_SPI_2=n CONFIG_I2C_2=n CONFIG_UART_2_NRF_UARTE=y CONFIG_UART_2_NRF_FLOW_CONTROL=y # J-TAG DEBUG CONFIG_USE_SEGGER_RTT=y
And the nrf52840 are based on pca10056 board so the nrf52840_pca10056.overlay is:
&uart1 {
status = "okay";
tx-pin = <27>;
rx-pin = <14>;
rts-pin = <15>;
cts-pin = <5>;
with the prj.conf:
CONFIG_SERIAL=y #CONFIG_TRUSTED_EXECUTION_NONSECURE=y CONFIG_UART_INTERRUPT_DRIVEN=y #CONFIG_MAIN_STACK_SIZE=4096 #CONFIG_BOARD_PCA10090_INTERFACE0_MCU=y #CONFIG_BOARD_PCA10090_INTERFACE1_MCU=y CONFIG_UART_1_NRF_UARTE=y #CONFIG_UART_1_NRF_FLOW_CONTROL=y CONFIG_UART_1_NRF_FLOW_CONTROL=n # J-TAG DEBUG CONFIG_USE_SEGGER_RTT=y
I removed the config for interface0 and 1 since it based of a pca10056 board.
Can it be because the overlay of nrf9160 are using the same pins as default for uart0?
Is it a problem that VCOM1 is "non-configurable" accoridng to docs here.
main.c is exactly the same as the example from the ticket so it looks like this:
#include <zephyr.h>
#include <sys/printk.h>
#include <drivers/uart.h>
#include <string.h>
#include "SEGGER_RTT.h"
static u8_t uart_buf[1024];
static struct device *uart_dev; //Figure out why you should/should not use static
int send_data(const u8_t *buf, size_t size)
//printk("size of output_buffer: %d\n", size);
if (size == 0) {
return 0;
for(int i = 0; i < size; i++){
//printk("Writing %c on position %d\n", buf[i], i);
uart_poll_out(uart_dev, buf[i]);
return 0;
void uart_cb(struct device *x)
uart_irq_update(x);
int data_length = 0;
if (uart_irq_rx_ready(x)) {
data_length = uart_fifo_read(x, uart_buf, sizeof(uart_buf));
uart_buf[data_length] = 0;
printk("%s", uart_buf);
SEGGER_RTT_WriteString(0, uart_buf);
void main(void)
char hey[] = "hey from 9160\n";
uart_dev = device_get_binding("UART_2");
if (!uart_dev) {
printk("Could not get UART 2\n");
uart_irq_callback_set(uart_dev, uart_cb);
uart_irq_rx_enable(uart_dev);
printk("UART 9160 [3] start!\n");
while (1) {
send_data(hey, sizeof(hey));
k_sleep(1000);
Can you please help me understand where the issue might occur that it is only sending from nrf52 and recieving on nrf91?
Kind regards, Ellinor
