MPSL Timer 0 Hard Fault
I have developed an application for the nRF52-DK (nRf52832AA) and am now in the process of porting the application to my custom hardware. My custom hardware utilizes the nRF52832AB part, so I have updated the configuration and memory sizes accordingly. The resized application runs properly on the DK. When I run the exact same binary on my custom board, I get a hard fault exception in the MPSL_IRQ_TIMER0_Handler(). Since the code works perfectly on the DK, I cannot imagine what I need to change to get past this error. If I do not configure and use Bluetooth, my application appears to run.
nRF Connect SDK 1.5.1
Segger emStudio 5.34a
  • (EDIT: I noticed I used the nRF51422 as an example, but this should be same for nRF52832.)
    1. Not sure how you have setup your board to use the nRF51822qfab, but I would have simply copied the nrf51dk_nrf51422 board directory to nrf51dk_nrf51422qfab directory.
    2. Renamed the 3 files in the nrf51dk_nrf51422qfab directory to nrf51dk_nrf51422qfab, something like:
    3. Then finally edit the .dts file to use:
    #include <nordic/nrf51822_qfab.dtsi> // instead of nordic/nrf51822_qfac.dtsi
    Kenneth
  • Kenneth,
    I basically did the same thing. The strange thing is that the same binary works on the DK, but throws exceptions on the custom hardware.
  • Can you try this approach? Also build with --pristine.
    Kenneth
  • I will build with --prestine.
    What do you mean by "this approach"?
  • Opened one of the standard projects, changed uP to the AB variant, disabled "Settings". Here is the debug output:
    [00:00:07.730,560] [0m<inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)[0m
    [00:00:07.730,560] [0m<inf> bt_hci_core: HW Variant: nRF52x (0x0002)[0m
    [00:00:07.730,590] [0m<inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 217.17378 Build 3224189809[0m
    [00:00:07.731,597] [0m<inf> bt_hci_core: Identity: DC:8F:81:FA:69:B1 (random)[0m
    [00:00:07.731,628] [0m<inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x11c2, manufacturer 0x0059[0m
    [00:00:07.731,628] [0m<inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0x11c2[0m
    [00:00:07.740,478] [1;31m<err> mpsl_init: MPSL ASSERT: 112, 2163[0m
    [00:01:04.649,291] [1;31m<err> os: ***** HARD FAULT *****[0m
    [00:01:04.649,322] [1;31m<err> os: Fault escalation (see below)[0m
    [00:01:04.649,322] [1;31m<err> os: r0/a1: 0x00000003 r1/a2: 0x20006850 r2/a3: 0x20001860[0m
    [00:01:04.649,322] [1;31m<err> os: r3/a4: 0x00000007 r12/ip: 0x20000f04 r14/lr: 0x00010907[0m
    [00:01:04.649,322] [1;31m<err> os: xpsr: 0x41000018[0m
    [00:01:04.649,322] [1;31m<err> os: Faulting instruction address (r15/pc): 0x0001b562[0m
    [00:01:04.649,353] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0[0m
    [00:01:04.649,353] [1;31m<err> os: Fault during interrupt handling
    [0m
    [00:01:04.649,353] [1;31m<err> os: Current thread: 0x20001860 (unknown)[0m
    [00:01:05.233,612] [1;31m<err> fatal_error: Resetting system[0m
