nRF sniffer for nRF52840: Can not set filter
2. In the nRF sniffer software, the device I'm interested in does not show up in the "Source" column with its addess, b8:80:4f:6b:b6:9e, but as "TexasIns_6b:b6:9e". It seems this prevents me from filtering. If a filter is added for the device's address (eth.src == b8:80:4f:6b:b6:9e), all events disappear and no new events appear. I'm not allowed to enter "eth.src == TexasIns_6b:b6:90" as filter: "not a valid ethernet address". Is there a work-around?!
2. Another problem is that the drop-down devices list (inital content: "All advertising devices") is not populated. "All advertising devices" remains the only entry. It was populated when I used the program for the first time but not now (and it was only partially populated; my device was not in it). Windows 8.1
/resized-image/__size/320x236/__key/communityserver-discussions-components-files/4/Screenshot-1.PNG
/resized-image/__size/320x236/__key/communityserver-discussions-components-files/4/Screenshot-2.PNG
  • Yes, I can see the advertising packets of various devices nearby (example video: https://vimeo.com/611782193 ). It's just that the drop-down devices list is not filled out accordingly. It remains empty most times I run Wireshark. On rare occasions, I get lucky and the list is filled but even then it is not always fully populated. Only some devices may show up there (example: https://vimeo.com/611782337).
    Can you try Window10?
    See nRF Sniffer for Bluetooth LE:
    Supported operating systems
    • Windows 10
    • 64-bit OS X/macOS 10.6 or later
    • Linux (check the Wireshark prerequisites for version compatibility)
    -Amanda
    Alas, no.
    Is it a verified fact that Windows 10 is required? Wireshark and Python are not limited to Windows 10 and the sniffer is a Python program. It seems the only part that could be OS-dependend would be the driver. I had a problem with that driver: After flashing the sniffer hex, my stick was not recognized (before that, it was a COM device). This was probably caused by it having a different PID (product id) than expected. It was enumerated as USB device with
    USB\VID_1915&PID_522A&REV_0204&MI_00
    USB\VID_1915&PID_522A&MI_00
    I found some other user with that problem in this forum and followed the suggestions: Download the nRF SDK, locate an USB driver under examples, use that. So I installed that driver. It didn't work directly, it didn't match the PID of my stick (it was for VID_1915&PID_520F&MI_00 and VID_1915&PID_521F&MI_00). However, by choosing "manual installation/select from installed drivers", I could assign that driver to the dongle. There was a warning though. I assumed that is just a serial-over-usb driver and that the warning could be ignored (since the serial link obviously works).
    I think this is one of the reasons requires to use Windows 10.
    Unfortunately, I don't have access to a Windows 8.1 computer. Can you please try the suggestions that Stian provides in this thread:
    https://devzone.nordicsemi.com/f/nordic-q-a/41853/usb-driver-install-fail-on-window-7-8-nrf52840-nordic_cdc_acm-inf
    If this still cannot help, I would strongly suggest you use Windows 10 as the doc requires.
    -Amanda
  • 1. It does not look like a driver problem (after manually installing one). BLE packets are sniffed and show up in Wireshark, including advertisements. The packets required to build a device list apparently arrive, they just don't get translated into a device list. This seems to be an issue on a higher level (python code of capture filter?). I've tried different versions of Wireshark (back to 2019) and Python (python-3.7.9-amd64, python-3.9.7-amd64) to exclude incompatibility with the latest versions.
    2. The Python code of the Nordic sniffer capture filter contains logging statements, such as this one in nrf_sniffer_ble.py:
    log = "Scanning all advertising devices"
    logging.info(log)
    Do you know how/where these log messages can be viewed? I don't think it's the log displayed by the "Log" button in the user interface of Wireshark because above message is not in there:
    INFO: Log started at Fri Sep 24 14:28:02 2021
    INFO: Extcap version 3.4
    INFO: Opening serial port COM4
    INFO: closing UART
    INFO: args: ()
    INFO: kwargs: {'callbacks': [('*', <bound method Notifier.passOnNotification of <Sniffer(Thread-3, initial)>>)]}
    INFO: board ID: 4
    INFO: Sniffer created
    INFO: Software version: 4.0.0
    INFO: sniffer started
    INFO: Firmware version 4.0.0
    INFO: starting scan
    INFO: Firmware timestamp 742688758 reference: Sep 24 2021 14:28:02.835117 Mitteleuropäische Sommerzeit
