How to start pwm sequence after particular time delay of gpio event?
I am working on an application where I need to start pwm sequence after particular delay (accurate delay of multiple of 100us).
I am quite new to nordic environment.
Here is my code . Can please guide me what is wrong here??
#define    Period    20000 //20ms
const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(0);
APP_PWM_INSTANCE(PWM1,1);
static int gpio_flag =0;
void pwm_update(void)
      uint32_t value;
      value = duty_1;
      ready_flag = false;
      /* Set the duty cycle - keep trying until PWM is ready... */
      while ((app_pwm_channel_duty_set(&PWM1, 0, value))&(app_pwm_channel_duty_set(&PWM1, 1, value)) == NRF_ERROR_BUSY);
      /* ... or wait for callback. */
      while (!ready_flag);
      APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 1, value));
      APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 0, value));
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
   gpio_flag =1;
   nrf_drv_timer_enable(&TIMER_LED);
void timer0_handler(nrf_timer_event_t event_type, void* p_context)
  switch (event_type)
        case NRF_TIMER_EVENT_COMPARE0:
             timer_flg =1;
             nrf_drv_timer_clear(&TIMER_LED);
             gpio_flag=0;
             pwm_update();
            //Do nothing.
void timer_init(void)
    uint32_t time_us = 500;
    uint32_t time_ticks;
    uint32_t err_code = NRF_SUCCESS;
    err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer0_handler);
    time_ticks = nrf_drv_timer_us_to_ticks(&TIMER_LED, time_us);
    nrf_drv_timer_compare(
         &TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks, true);
  • Hello Karl,
    This looks mostly correct, but I cant see that you have connected the GPIOTE IN EVENT to the TIMER's START task through PPI anywher
    static void ppi_init(void)
        // Allocate the channel from the available PPI channels
        err_code = nrf_drv_ppi_channel_alloc(&ppi_channel_1);
        err_code = nrf_drv_ppi_channel_assign(ppi_channel_1,
                                              nrf_drv_gpiote_in_event_addr_get(PIN_IN),
                                              nrf_drv_timer_task_address_get(&PWM_DELAY_TIMER,
        NRF_TIMER_TASK_START));
        err_code = nrf_drv_ppi_channel_alloc(&ppi_channel_2);
        compare_event_addr = nrf_drv_timer_task_address_get(&PWM_DELAY_TIMER,NRF_TIMER_CC_CHANNEL0);
        pwm_task_addr =  nrf_drv_pwm_task_address_get(&m_pwm0,NRF_PWM_TASK_SEQSTART0);
        err_code = nrf_drv_ppi_channel_assign(ppi_channel_2, compare_event_addr,pwm_task_addr);
        err_code = nrf_drv_ppi_channel_enable(ppi_channel_1);
        err_code = nrf_drv_ppi_channel_enable(ppi_channel_2);
    static void gpio_init(void)
        ret_code_t err_code;
        nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
        in_config.pull = NRF_GPIO_PIN_PULLDOWN;
        err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
        nrf_drv_gpiote_in_event_enable(PIN_IN, true);
    void timers_init(void)
        uint32_t err_code;
        uint32_t timer_ticks;
        nrfx_timer_config_t timer_cfg = NRFX_TIMER_DEFAULT_CONFIG;
        timer_cfg.frequency = NRF_TIMER_FREQ_1MHz;
        err_code = nrfx_timer_init(&PWM_DELAY_TIMER, &timer_cfg,pwm_delay_timeout_handler);
        timer_ticks = nrfx_timer_us_to_ticks(&PWM_DELAY_TIMER, PWM_DELAY_US);
        nrfx_timer_extended_compare(&PWM_DELAY_TIMER,
                                      timer_ticks,
                                      NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                      true);
       nrfx_timer_enable(&PWM_DELAY_TIMER);
    static void pwm_init(void)
        nrf_drv_pwm_config_t const config0 =
            .output_pins =
                OUTPUT_PIN, // channel 0
                OUTPUT_PIN2,             // channel 1
                NRF_DRV_PWM_PIN_NOT_USED,             // channel 2
                NRF_DRV_PWM_PIN_NOT_USED,             // channel 3
            .irq_priority = APP_IRQ_PRIORITY_LOWEST,
            .base_clock   = NRF_PWM_CLK_1MHz,
            .count_mode   = NRF_PWM_MODE_UP,
            .top_value    = 20000,
            .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
            .step_mode    = NRF_PWM_STEP_AUTO
        // Init PWM without error handler
        APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, NULL));
        seq_values->channel_0 = duty ;
        seq_values->channel_1 = duty | 0x8000;
        APP_ERROR_CHECK(nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1,NRF_DRV_PWM_FLAG_LOOP|NRF_DRV_PWM_FLAG_START_VIA_TASK));
    So this scenario needed two ppi connection .
    1-> From GPIOTE  IN   EVENT to the TIMER START
    2->TIMER COMPATRE to PWM_TASK_SEQSTART .
    I am implemented in this way ,Please verify is this connection is right now??
    Yes, your scenario requires two PPI connections.
    Yes, I do not immediately spot anything wrong with this configuration.
    What do you see when you now attempt to compile and run this program?
    Karl
  • Hello Karl,
    compiled successfully with zero error but pwm output isn't coming , that means its not triggering.
    But below error coming.
    <error> app: Fatal error
    <warning> app: System reset
     Ram
  • Please make sure to have DEBUG defined in your preprocessor defines, like shown in the included image:
    This will make the logger output a detailed error message whenever a non-NRF_SUCCESS error is passed to an APP_ERROR_CHECK.
    Try this, and let me know what the logger says when this happens.
    Karl
  • Hello Karl,
    <info> app: PPI example started.
    <info> app: LED started.
    <info> app: gpio started.
    <info> app: timer started.
    <error> app: ERROR 1073856524 [Unknown error code] at C:\Nordic\DeviceDownload\nRF5SDK1702d674dde\nRF5_SDK_17.0.2_d674dde\examples\my proj\pwm_common_mode\main.c:176
    PC at: 0x00006BA5
    <error> app: End of error report
    And my main code is:
        uint32_t err_code;
        err_code = NRF_LOG_INIT(NULL);
        ppi_init();
        NRF_LOG_INFO("PPI example started.");
        NRF_LOG_INFO("LED started.");
        gpio_init();
        NRF_LOG_INFO("gpio started.");
        timers_init();
        NRF_LOG_INFO("timer  started.");
        pwm_init();
        NRF_LOG_INFO("pwm started.");
        unsigned int val;
        while (1)
    This means Its coming from pwm_init() function.
     Ram
