How to start pwm sequence after particular time delay of gpio event?
I am working on an application where I need to start pwm sequence after particular delay (accurate delay of multiple of 100us).
I am quite new to nordic environment.
Here is my code . Can please guide me what is wrong here??
#define    Period    20000 //20ms
const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(0);
APP_PWM_INSTANCE(PWM1,1);
static int gpio_flag =0;
void pwm_update(void)
      uint32_t value;
      value = duty_1;
      ready_flag = false;
      /* Set the duty cycle - keep trying until PWM is ready... */
      while ((app_pwm_channel_duty_set(&PWM1, 0, value))&(app_pwm_channel_duty_set(&PWM1, 1, value)) == NRF_ERROR_BUSY);
      /* ... or wait for callback. */
      while (!ready_flag);
      APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 1, value));
      APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 0, value));
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
   gpio_flag =1;
   nrf_drv_timer_enable(&TIMER_LED);
void timer0_handler(nrf_timer_event_t event_type, void* p_context)
  switch (event_type)
        case NRF_TIMER_EVENT_COMPARE0:
             timer_flg =1;
             nrf_drv_timer_clear(&TIMER_LED);
             gpio_flag=0;
             pwm_update();
            //Do nothing.
void timer_init(void)
    uint32_t time_us = 500;
    uint32_t time_ticks;
    uint32_t err_code = NRF_SUCCESS;
    err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer0_handler);
    time_ticks = nrf_drv_timer_us_to_ticks(&TIMER_LED, time_us);
    nrf_drv_timer_compare(
         &TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks, true);
  • Hello again, Ram
    RAM_MS said:
    <error> app: ERROR 1073856524 [Unknown error code] at C:\Nordic\DeviceDownload\nRF5SDK1702d674dde\nRF5_SDK_17.0.2_d674dde\examples\my proj\pwm_common_mode\main.c:176
    PC at: 0x00006BA5
    Exactly which function call returned the error code passed to an APP_ERROR_CHECK on line 176 of main?
    Could you share the entire pwm_init function as it currently is? To proceed we will need to pinpoint which APP_ERROR_CHECK that triggered the reset, and which function generated the error.
    Karl
  • Hello Karl,
    Here is my entire  pwm_init function as it currently is.
    And on line 176  [[APP_ERROR_CHECK(nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1,NRF_DRV_PWM_FLAG_LOOP | NRF_DRV_PWM_FLAG_START_VIA_TASK));]]
    static void pwm_init(void)
        nrf_drv_pwm_config_t const config0 =
            .output_pins =
                OUTPUT_PIN, // channel 0
                OUTPUT_PIN2,             // channel 1
                NRF_DRV_PWM_PIN_NOT_USED,             // channel 2
                NRF_DRV_PWM_PIN_NOT_USED,             // channel 3
            .irq_priority = APP_IRQ_PRIORITY_LOWEST,
            .base_clock   = NRF_PWM_CLK_1MHz,
            .count_mode   = NRF_PWM_MODE_UP,
            .top_value    = 20000,
            .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
            .step_mode    = NRF_PWM_STEP_AUTO
        // Init PWM without error handler
        APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, NULL));
        seq_values->channel_0 = duty ;
        seq_values->channel_1 = duty | 0x8000;
        APP_ERROR_CHECK(nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1,NRF_DRV_PWM_FLAG_STOP | NRF_DRV_PWM_FLAG_START_VIA_TASK));
     Ram
  • Oh, I see now - you should not do an APP_ERROR_CHECK on the return value from nrf_drv_pwm_simple_playback, as mention in its API Reference it returns the address of the task you should trigger to start the sequence (this address should be equal to the one you got from the addres_get function in the PPI setup).
    The documentation exempt reads:
    Address of the task to be triggered to start the playback if the NRFX_PWM_FLAG_START_VIA_TASK flag was used, 0 otherwise.
    Karl
  • Hello Karl,
    You mean to say that what Get from  pwm_task_addr= nrf_drv_pwm_task_address_get(&m_pwm0,NRF_PWM_TASK_SEQSTART0);
    Same should use here  like pwm_task_addr=nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1,NRF_DRV_PWM_FLAG_STOP | NRF_DRV_PWM_FLAG_START_VIA_TASK);
    //ppi init part
    compare_event_addr = nrf_drv_timer_task_address_get(&PWM_DELAY_TIMER,NRF_TIMER_CC_CHANNEL0);
    pwm_task_addr =  nrf_drv_pwm_task_address_get(&m_pwm0,NRF_PWM_TASK_SEQSTART0);
    err_code = nrf_drv_ppi_channel_assign(ppi_channel_2, compare_event_addr,pwm_task_addr);
    // pwm init part
    pwm_task_addr=nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1,NRF_DRV_PWM_FLAG_LOOP | NRF_DRV_PWM_FLAG_START_VIA_TASK);
    Thanks Karl It is working now .
    Many Many Thanks .
    But now there is a problem.
    1)the timing is not correct .Here I am attaching the snapshot of it
    From the picture you can clearly see that the delay time is more than 1ms .
    How can I make it exact??
     Ram
  • Hello again, Ram
    Yes, you could use the address returned by nrf_drv_pwm_simple_playback as the input to the PPI connection.
    Many Many Thanks .
    Great, I am happy to hear that we have progressed closer to the desired functionality.
    This does indeed not look correct - that is quite the added delay, more than 200 µs it seems.
    Could you clarify exactly what you are scoping here with the blue and yellow line? I assume it is the inputted PWM and the resulting delayed PWM output, but it would be good if you could confirm / specify this.
    To debug this we will need to find out where in the chain of events this delay is introduced.
    Could you try this again with different delays, so we may see if there is an issue with the timer configuration for instance?
    Alternatively, as a debugging measure, you could change to have the TIMER CC event connected to a pin toggle TASK, so we may verify that the timer is producing the correct delay.
    I look forward to hearing what you observe when you test this!
    Karl
