How to start pwm sequence after particular time delay of gpio event?
I am working on an application where I need to start pwm sequence after particular delay (accurate delay of multiple of 100us).
I am quite new to nordic environment.
Here is my code . Can please guide me what is wrong here??
#define    Period    20000 //20ms
const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(0);
APP_PWM_INSTANCE(PWM1,1);
static int gpio_flag =0;
void pwm_update(void)
      uint32_t value;
      value = duty_1;
      ready_flag = false;
      /* Set the duty cycle - keep trying until PWM is ready... */
      while ((app_pwm_channel_duty_set(&PWM1, 0, value))&(app_pwm_channel_duty_set(&PWM1, 1, value)) == NRF_ERROR_BUSY);
      /* ... or wait for callback. */
      while (!ready_flag);
      APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 1, value));
      APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 0, value));
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
   gpio_flag =1;
   nrf_drv_timer_enable(&TIMER_LED);
void timer0_handler(nrf_timer_event_t event_type, void* p_context)
  switch (event_type)
        case NRF_TIMER_EVENT_COMPARE0:
             timer_flg =1;
             nrf_drv_timer_clear(&TIMER_LED);
             gpio_flag=0;
             pwm_update();
            //Do nothing.
void timer_init(void)
    uint32_t time_us = 500;
    uint32_t time_ticks;
    uint32_t err_code = NRF_SUCCESS;
    err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer0_handler);
    time_ticks = nrf_drv_timer_us_to_ticks(&TIMER_LED, time_us);
    nrf_drv_timer_compare(
         &TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks, true);
  • Hello Karl,
    This does indeed not look correct - that is quite the added delay, more than 200 µs it seems.
    Could you clarify exactly what you are scoping here with the blue and yellow line? I assume it is the inputted PWM and the resulting delayed PWM output, but it would be good if you could confirm / specify this
    Yes ,you assumed right .Yellow line is inputted PWM and blue line is delayed PWM output.
    To debug this we will need to find out where in the chain of events this delay is introduced.
    Could you try this again with different delays, so we may see if there is an issue with the timer configuration for instance?
    I tested with different delays that is 1ms ,2ms ,3ms etc .Every where the same added delay around 200 µs
    coming.
    Alternatively, as a debugging measure, you could change to have the TIMER CC event connected to a pin toggle TASK, so we may verify that the timer is producing the correct delay.
    I tested this and the output is attached here in below .
    Here yellow line is inputted PWM and blue line is gpio toggle output .
    Here you can clearly notice that 2ms timing is exact.
    Ram
  • Hello again Ram,
    Thank you for the clarification and update.
    coming.
    This is great steps for the debugging - well done!
    So, it it clear that the timer toggles the GPIOTE at a precise interval, and that the delay is added elsewhere.
    Could you check whether you are receiving any EVENTS_SEQSTARTED events in your pwm event handler?
    To find out how long it takes from the PWM start task is triggered until the SEQSTARTED event is received you could use the nrf_timer_cc_read function in the timer's event handler for the CC event, and then again in the PWM handler for the SEQSTARTED event - then subtract the initial value and the added delay to find the difference.
    Could you show me your code as it is right now? I will take a look and see if I can spot what might be adding the delay.
    Did you change it so that you are providing the pwm_start_task_address returned from the nrf_drv_simple_playback call to the PPI initialization?
    Karl
  • Hello Karl,
    Here I attached the code for your reference.
    0310.main.zip
    Yes ,I changed .
    Please verify once is it right in provided code.
    I am trying to test this .I will update you soon.
    Ram
    Thank you for sharing the code.
    Looking through the code I notice that you are initializing the GPIOTE as a low-accuracy input, in the line:
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(false);
    Could you try to change this to high accuracy, by changing the configuration parameter to true?
    I do not really think that this should matter, since the PORT event will be triggered just as fast as the IN_EVENT, but it would be good to have ruled out as well.
    I also recommend that you define your pins using the NRF_GPIO_PIN_MAP macro instead of just writing their pin number, but this is a very minor comment on my part and it will work just as well with the pins number directly.
    RAM_MS said:
    Yes ,I changed .
    I do not see this change implemented in the code you just shared - it seems like this might be the code that was used to test the TIMER's accuracy.
    I see that you have created a global variable to store the pwm_task_addr returned by the nrf_drv_pwm_simple_playback function call, so I assume you will be using that variable to store it, and pass it to the PPI assign function.
    I would urge you to add a check to the PPI init function that checks if the pwm_task_addr and gpiote_task_addr variables has been set before you proceed to pass them to the PPI peripheral.
    You will also need to run the GPIOTE and PWM init functions before the PPI init function, to make sure that the addresses has been updated before they are connected through the PPI.
    Great, I look forward to hearing what you find out! :)
    Karl
  • Hello Karl,
    Sorry ,You are right I shared the code that was used to test the TIMER's accuracy.
    Yes ,you are right I am using that variable to store it and pass it to the PPI assign function.
    Thank you so much Karl ,this was the problem in my code after arranging this correcting now I am able to get exact TIMING Delay .
    Now ,another problem arises actually .
    For testing purpose I generated inputting PWM signal from PIN NO 11( that is PWM_PIN 11) in the code you might seen it and giving it to (PIN_IN 22).
    But in real case the inputting PWM will come from outside .
    So for create this scenario I created inputted PWM signal from a different NRF52 DK .
    And what I observed is my Generated PWM Signal is Shifting with time.
    For your reference I am attaching the video of it.
    what could be the reason for this problem ?
    As always Yellow one is INPUTTED PWM SIGNAL and Blue one is my OUTPUT PWM .
    And you can clearly see that blue line is slowly shifting to left .
    Ram
