How to start pwm sequence after particular time delay of gpio event?
I am working on an application where I need to start pwm sequence after particular delay (accurate delay of multiple of 100us).
I am quite new to nordic environment.
Here is my code . Can please guide me what is wrong here??
#define    Period    20000 //20ms
const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(0);
APP_PWM_INSTANCE(PWM1,1);
static int gpio_flag =0;
void pwm_update(void)
      uint32_t value;
      value = duty_1;
      ready_flag = false;
      /* Set the duty cycle - keep trying until PWM is ready... */
      while ((app_pwm_channel_duty_set(&PWM1, 0, value))&(app_pwm_channel_duty_set(&PWM1, 1, value)) == NRF_ERROR_BUSY);
      /* ... or wait for callback. */
      while (!ready_flag);
      APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 1, value));
      APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 0, value));
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
   gpio_flag =1;
   nrf_drv_timer_enable(&TIMER_LED);
void timer0_handler(nrf_timer_event_t event_type, void* p_context)
  switch (event_type)
        case NRF_TIMER_EVENT_COMPARE0:
             timer_flg =1;
             nrf_drv_timer_clear(&TIMER_LED);
             gpio_flag=0;
             pwm_update();
            //Do nothing.
void timer_init(void)
    uint32_t time_us = 500;
    uint32_t time_ticks;
    uint32_t err_code = NRF_SUCCESS;
    err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer0_handler);
    time_ticks = nrf_drv_timer_us_to_ticks(&TIMER_LED, time_us);
    nrf_drv_timer_compare(
         &TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks, true);
  • Hello again, Ram
    RAM_MS said:
    Thank you for your valuable inputs .
    No problem at all, I am happy to help you.
    RAM_MS said:
    I tried with your code and timer is triggering but instead of 1ms delay its coming increments                         automatically.
    I am not sure that I understand what you mean by this - are you not seeing the button trigger a configurable timer, which calls pwm_update on expiration?
    Keep in mind that the pwm_update function is not populated in my example, so you will have to have it do something worthwhile in the pwm_update example before the example outputs anything useful when the delay expires.
    RAM_MS said:
     For your better understand I am attaching both project .zip and my configuration aim in .png file
                  Also I am adding video of my outputs.
    Oh, I see - I was under the impression that you wanted to update a PWM's duty cycle after a given delay. I was not aware that you wanted to output the same waveform out that you have received in, with an added delay.
    The simplest implementation of this would perhaps be to just have the GPIOTE IN event trigger a timer with the provided delay, that in turn sets the output pin high or low?
    You could use the PPI peripheral to have the GPIOTE in event start the TIMER, and the TIMER CC event toggle the output GPIO directly, so that none of it requires CPU intervention.
    Karl
  • Hello Karl,
    I am not getting you here .
    Can you please elaborate little more or give me a small demo of it what you are explaining.
    Thanks & regards,
    Ram
  • Hello Ram,
    I do not understand what you mean by this, could you clarify?
    I do not have a demo for this, but to elaborate you could start by taking a look at how the SAADC example connects a TIMER event to a SAADC task.
    You could use the exact same approach to connect a GPIOTE EVENTS_IN event to a TIMER START task through PPI. This will make the GPIOTE event (such as a LOW to HIGH event) start the delay TIMER.
    Then, you can use the PPI peripheral in the same manner to also have the TIMER CC EVENT (timer expired) trigger a GPIOTE SET task - setting the GPIO high when the delay has passed.
    There might be other good ways of doing this as well, depending on the assumptions one could make about your application. For example, will the duty cycle of the incoming PWM always be the same, or will this change as well? Is your end goal to output the exact same waveform out, as it was received in, with only the delay added, or will you do make any sort of changes to the incoming waveform?
    Karl
  • Hello Karl,
    I will definitely do this a try.
    Definitely ,Because I did it STM32 by using TIMER in one pulse mode and its working properly .
    As BLE is needed in this application ,I am trying to do in Nordic.
    And yes duty cycle of incoming PWM always will be same .
    Yes ,My goal is to output the same waveform out ,as it was received in, with only the delay added from (100 µs to 10ms).
    Here I am attaching the pictures of what I achieved in STM32 for your reference.
    Thanks & regards,
    Ram
    Thank you for elaborating on the requirements and operation.
    If the duty cycle will always be the same, that makes things easier.
    Then, you might be able to do this more easily, using less resources, if you instead set up the waveform using the PWM driver to ready the waveform - setting the NRFX_PWM_FLAG_LOOP flag as the last argument of the _playback() function call - , and then have the TIMER CC event trigger the TASKS_SEQSTART[0] to start the PWM peripheral instead. Once started you could disable the GPIOTE low_to_high detection, and the PPI channels.
    This way, you will not have to continuously monitor and set/clear the output pin.
    This will ensure that the PWM sequence is started after a given delay, and run until stopped. If you need to change the delay you will need to stop the PWM, re-enable the GPIOTE in event, and re-enable the PPI channels.
    Great, let me know if you encounter any issues or questions!
    Karl
