GPIO port 1 unable to read with MCUBoot added
I've recently upgraded my SDK to 1.6.0 and I am now unable to read the state of P1.00 but I am able to read the state of P0.28.
I've stripped the project down to just a gpio setup and pin read loop.
If I remove the MCUBOOT define I can read the pin on GPIO 1 but when I add it in I can't.
I am now testing with a nRF5340-DK with a basic button example.
Any ideas will be gratefully received.
Thank you,
Neil
  • sdk1.4.99peripheral_hr.zipsdk1_7_0peripheral_hr.zip
    I've been doing some more testing,  I've used a basic bt example to test,  it shows that in sdk 1.4.99 i'm able to read the state of gpio1.0 and gpio1.1 but in 1.7.0 I am not.  In the project settings if I remove CONFIG_BT=y and hence remove the net core it starts working again.
    Thank you,
    Neil
  • UPDATE - after more testing, SDK1.5.1 works but sdk1.6.0 and later doesn't.  It seems that is it only P1.00 and P1.01 effected.
  • I have had similar issues with 1.6.1  where my interrupts configured  for Pin P1.1 don't work while  it's fine if I use 1.5.1
    I tried editing v1.6.1\zephyr\boards\arm\nrf5340dk_nrf5340\nrf5340_cpunet_reset.c (I use secure build).. i saw the code uses the pins 0 and 1 (of port 1) so i commented the usage.. I HAVE NO IDEA what's the side effect of this is (yet) but if i do this, i can get interrupts on my configured pin
    Like you mentioned, this issue happens only if you use BLE.. if you have a simple application without BLE (and hence no netcore), life is good.. but who would need nrf5340 if that's the use case :-)
    static void remoteproc_mgr_config(void)
    /* UARTE */
    /* Assign specific GPIOs that will be used to get UARTE from
    * nRF5340 Network MCU.
    #if 0 ///---------------------- commented these lines
    CPUNET_UARTE_PORT_TRX->PIN_CNF[CPUNET_UARTE_PIN_TX] =
    GPIO_PIN_CNF_MCUSEL_NetworkMCU << GPIO_PIN_CNF_MCUSEL_Pos;
    CPUNET_UARTE_PORT_TRX->PIN_CNF[CPUNET_UARTE_PIN_RX] =
    NRF_P0->PIN_CNF[CPUNET_UARTE_PIN_RTS] =
    NRF_P0->PIN_CNF[CPUNET_UARTE_PIN_CTS] =
    /* Route Bluetooth Controller Debug Pins */
    DEBUG_SETUP();
    /* Retain nRF5340 Network MCU in Secure domain (bus
    * accesses by Network MCU will have Secure attribute set).
    NRF_SPU->EXTDOMAIN[0].PERM = 1 << 4;
    #endif /* !CONFIG_TRUSTED_EXECUTION_NONSECURE */
  • Thank you for your input, I was comparing SDK versions and they all set these pins, so I'm not sure what has changed.  Hopefully I'll get a reply from Nordic soon.
    I don't need the net core to access the uart so probably safe to delete.
  • i didn;t make this change earlier for the same reasons (previous sdk has the same code) but given that piece of code is the only one that uses the pins in question, i tried it yesterday and it worked.. I had also removed all arduino pin definitions from the dts files in zephyr\boards\arm\nrf5340dk_nrf5340 but that didn't help..
    I have another ticket where i have requested why does this solve my problem.. hoping to hear back there as well
