I closed below case by mistake.
As per your query I am using nRF9160 DK for testing.
I have modified "http_application_uodate" example code for my testing.
Smitesh Mali
Smitesh Mali
Can you please elaborate on what you have modified on the nRF9160: HTTP application update sample? What terminal are you using to connect to the COM port? Have you tried with the nRF Connect for Desktop - LTE Link Monitor?
Øyvind
Below is the interrupt routine which waits for "UUT*SIM=?\n" command from terminal.
static void UHi_PcUartCb(const struct device *x, void* data)
uart_irq_update(x);
int data_length = 0;
if (uart_irq_rx_ready(x)) {
data_length = uart_fifo_read(x, &_uartPcRxChar, 1);
if (_pcCmdRxFlg)
return;
_uartPcBuf[_pcRxCntr] = _uartPcRxChar;
if (_uartPcBuf[_pcRxCntr] == '\n')
_pcCmdRxFlg = true;
return;
_pcRxCntr++;
When "\n" is receive data will be processed.
But sometimes data received is "ª*SIM=?\n" instead of "UUT*SIM=?\n".
I am using "Docklight" utility in PC to communicate with com port.
No, I haven't tried it.
Smitesh Mali
I am using UART 0 to receive data from PC.
I debugged the issue further by enabling error interrupt for UART
uart_irq_err_enable(_uartPc);
I received "UART_BREAK" (0x08) error when I get "ª*SIM=?\n" (wrong data).
Interestingly, I am getting error when I receive expected data too which is "UUT*SIM=?\n".
But at that time error is different. It is "UART_ERROR_FRAMING" (0x04) error.
I get this error after complete data from PC is received.
Can you tell me in what case "UART_BREAK" error can come ?
As per the comment in "uart.h" it comes in below case.
* @brief Break interrupt
* A break interrupt was received. This happens when the serial input
* is held at a logic '0' state for longer than the sum of
* start time + data bits + parity + stop bits.
Smitesh Mali
Issue is resolved.
Pin 0.28 and 0.29 were defined in overlay file for SPI.
It was creating issue.
UART works properly after removing it.
Smitesh Mali
