how to solve Error: L6218E: Undefined symbol (the undefine target) (referred from main.o).
hy, i have a problem wit undefine simbol, how to define the simbol, i laready add related path folder that contain the undefine simbol target, but this error still appear.
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_drv_clock_init (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_drv_clock_lfclk_request (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_drv_rtc_disable (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_drv_rtc_enable (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_drv_rtc_init (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_drv_rtc_tick_enable (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_gzll_add_packet_to_tx_fifo (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_gzll_enable (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_gzll_fetch_packet_from_rx_fifo (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_gzll_init (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_gzll_set_base_address_0 (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_gzll_set_base_address_1 (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_gzll_set_channel_table (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_gzll_set_datarate (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_gzll_set_max_tx_attempts (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_gzll_set_timeslot_period (referred from main.o).
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol nrf_gzll_set_timeslots_per_channel (referred from main.o).
Not enough information to list image symbols.
Not enough information to list load addresses in the image map.
if you wanto check my code:
 * Either COMPILE_RIGHT or COMPILE_LEFT has to be defined from the make call to allow proper functionality
#include "redox-w.h"
#include "nrf_drv_config.h"
#include "nrf_gzll.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_drv_clock.h"
#include "nrf_drv_rtc.h"
#include "nrf51_bitfields.h"
#include "nrf51.h"
/** Configuration */
const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(1); /**< Declaring an instance of nrf_drv_rtc for RTC1. */
// Data and acknowledgement payloads
static uint8_t ack_payload[NRF_GZLL_CONST_MAX_PAYLOAD_LENGTH]; ///< Placeholder for received ACK payloads from Host.
// Debounce time (dependent on tick frequency)
#define DEBOUNCE 5
// Mark as inactive after a number of ticks:
#define INACTIVITY_THRESHOLD 500 // 0.5sec
#ifdef COMPILE_LEFT
static uint8_t channel_table[3]={4, 42, 77};
#ifdef COMPILE_RIGHT
static uint8_t channel_table[3]={25, 63, 33};
// Setup switch pins with pullups
static void gpio_config(void)
    nrf_gpio_cfg_sense_input(R01, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
    nrf_gpio_cfg_sense_input(R02, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
    nrf_gpio_cfg_sense_input(R03, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
    nrf_gpio_cfg_sense_input(R04, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
    nrf_gpio_cfg_sense_input(R05, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
    nrf_gpio_cfg_output(C01);
    nrf_gpio_cfg_output(C02);
    nrf_gpio_cfg_output(C03);
    nrf_gpio_cfg_output(C04);
    nrf_gpio_cfg_output(C05);
    nrf_gpio_cfg_output(C06);
    nrf_gpio_cfg_output(C07);
    nrf_gpio_pin_clear(C01);
    nrf_gpio_pin_clear(C02);
    nrf_gpio_pin_clear(C03);
    nrf_gpio_pin_clear(C04);
    nrf_gpio_pin_clear(C05);
    nrf_gpio_pin_clear(C06);
    nrf_gpio_pin_clear(C07);
// Return the key states
static void read_keys(uint8_t *row_stat)
    unsigned short c;
    uint32_t input = 0;
    static const uint32_t COL_PINS[] = { C01, C02, C03, C04, C05, C06, C07 };
    // scan matrix by columns
    for (c = 0; c < COLUMNS; ++c) {
        // Force the compiler to add one cycle gap between activating
        // the column pin and reading the input to allow some time for
        // it to be come stable. Note that compile optimizations are
        // not allowed for next three statements. Setting the pin
        // write a location which is marked as volatile
        // (NRF_GPIO->OUTSET) and reading the input is also a memory
        // access to a location which is marked as volatile too
        // (NRF_GPIO->IN).
        nrf_gpio_pin_set(COL_PINS[c]);
        //asm volatile("nop");
        input = NRF_GPIO->IN;
        row_stat[0] = (row_stat[0] << 1) | ((input >> R01) & 1);
        row_stat[1] = (row_stat[1] << 1) | ((input >> R02) & 1);
        row_stat[2] = (row_stat[2] << 1) | ((input >> R03) & 1);
        row_stat[3] = (row_stat[3] << 1) | ((input >> R04) & 1);
        row_stat[4] = (row_stat[4] << 1) | ((input >> R05) & 1);
        nrf_gpio_pin_clear(COL_PINS[c]);
static bool compare_keys(const uint8_t* first, const uint8_t* second,
                         uint32_t size)
    for(int i=0; i < size; i++)
        if (first[i] != second[i])
          return false;
    return true;
static bool empty_keys(const uint8_t* keys_buffer)
    for(int i=0; i < ROWS; i++)
        if (keys_buffer[i])
          return false;
    return true;
static void handle_inactivity(const uint8_t *keys_buffer)
    static uint32_t inactivity_ticks = 0;
    // looking for 500 ticks of no keys pressed, to go back to deep sleep
    if (empty_keys(keys_buffer)) {
        inactivity_ticks++;
        if (inactivity_ticks > INACTIVITY_THRESHOLD) {
            nrf_drv_rtc_disable(&rtc);
            nrf_gpio_pin_set(C01);
            nrf_gpio_pin_set(C02);
            nrf_gpio_pin_set(C03);
            nrf_gpio_pin_set(C04);
            nrf_gpio_pin_set(C05);
            nrf_gpio_pin_set(C06);
            nrf_gpio_pin_set(C07);
            NRF_POWER->SYSTEMOFF = 1;
    } else {
static void handle_send(const uint8_t* keys_buffer)
    static uint8_t keys_snapshot[ROWS] = {0};
    static uint32_t debounce_ticks = 0;
    const bool no_change = compare_keys(keys_buffer, keys_snapshot, ROWS);
    if (no_change) {
        debounce_ticks++;
        // debouncing - send only if the keys state has been stable
        // for DEBOUNCE ticks
        if (debounce_ticks == DEBOUNCE) {
            // Assemble packet and send to receiver
            nrf_gzll_add_packet_to_tx_fifo(PIPE_NUMBER, keys_snapshot, ROWS);
            debounce_ticks = 0;
    } else {
        // change detected, start over
        debounce_ticks = 0;
        for (int k = 0; k < ROWS; k++) {
            keys_snapshot[k] = keys_buffer[k];
// 1000Hz debounce sampling
static void tick(nrf_drv_rtc_int_type_t int_type)
    uint8_t keys_buffer[ROWS] = {0, 0, 0, 0, 0};
    read_keys(keys_buffer);
    handle_inactivity(keys_buffer);
    handle_send(keys_buffer);
// Low frequency clock configuration
static void lfclk_config(void)
    nrf_drv_clock_init();
// RTC peripheral configuration
static void rtc_config(void)
    //Initialize RTC instance
    nrf_drv_rtc_init(&rtc, NULL, tick);
    //Enable tick event & interrupt
    nrf_drv_rtc_tick_enable(&rtc, true);
    //Power on RTC instance
    nrf_drv_rtc_enable(&rtc);
int main()
    // Initialize Gazell
    nrf_gzll_init(NRF_GZLL_MODE_DEVICE);
    // Attempt sending every packet up to 100 times
    nrf_gzll_set_max_tx_attempts(100);
    nrf_gzll_set_timeslots_per_channel(4);
    nrf_gzll_set_channel_table(channel_table,3);
    nrf_gzll_set_datarate(NRF_GZLL_DATARATE_1MBIT);
    nrf_gzll_set_timeslot_period(900);
    // Addressing
    nrf_gzll_set_base_address_0(0x01020304);
    nrf_gzll_set_base_address_1(0x05060708);
    // Enable Gazell to start sending over the air
    nrf_gzll_enable();
    // Configure 32kHz xtal oscillator
    lfclk_config();
    // Configure RTC peripherals with ticks
    rtc_config();
    // Configure all keys as inputs with pullups
    gpio_config();
    // Main loop, constantly sleep, waiting for RTC and gpio IRQs
    while(1)
        __SEV();
        __WFE();
        __WFE();
/** Gazell callback function definitions  */
void  nrf_gzll_device_tx_success(uint32_t pipe, nrf_gzll_device_tx_info_t tx_info)
    uint32_t ack_payload_length = NRF_GZLL_CONST_MAX_PAYLOAD_LENGTH;
    if (tx_info.payload_received_in_ack)
        // Pop packet and write first byte of the payload to the GPIO port.
        nrf_gzll_fetch_packet_from_rx_fifo(pipe, ack_payload, &ack_payload_length);
// no action is taken when a packet fails to send, this might need to change
void nrf_gzll_device_tx_failed(uint32_t pipe, nrf_gzll_device_tx_info_t tx_info)
// Callbacks not needed
void nrf_gzll_host_rx_data_ready(uint32_t pipe, nrf_gzll_host_rx_info_t rx_info)
void nrf_gzll_disabled()
