Hi:
nRF52832 SDK17.1.0\examples\peripheral\spi\pca10040 , Is the maximum frequency of the SPI in here only 8M?
The following screenshots:
Can't the frequency be set to higher ? Such as 20M , 30M .
thanks !
Hi:
thanks !
zxcv7063,
Yes, the maximum SPI clock frequency can be 8MHz. Refer to datasheet page # 421. I am attaching the screenshot below as well.
Thanks.
Hi:
Thank you for your reply .
Our project application needs 20M, how should we modify it?
@varung the datasheet you're referring to seems to be for the nRF52840, while zxcv7063 is asking about the nRF52832.
The maximum frequency of the SPI and SPIM peripheral of the nRF52832 is 8 MHz, as shown in the SPIM peripheral documentation.
If you require < 20 MHz you could switch to using the nRF52840 or the nRF52833, both of which have an SPIM instance with 32 MHz as its maximum frequency.
Karl
Hi:
Is the SPI in SDK hardware SPI or software analog SPI ?
Can I get higher frequencies if use an software analog SPI?
zxcv7063 said:Thank you for your reply .
No problem at all, I am happy to help!
zxcv7063 said:Is the SPI in SDK hardware SPI or software analog SPI ?
The SPI peripherals have their own dedicated hardware.
zxcv7063 said:Can I get higher frequencies if use an software analog SPI?
There are no analogue outputs on the nRF52832. If you are asking if bit-banging SPI through GPIOTE toggling could achieve higher than 8 MHz frequency the answer is also no, unfortunately. If you need higher than 8 MHz frequency you will need to use SPIM3 on an nRF52833 or nRF52840 instead.
Karl
