I am trying to generate a 128Hz sine wave using the nrf_pwm library . First I tried this with SD110 enabled but ran into some problems that turned out to be a known issue with the nrf51 chip. So I tried generating my sine wave with the nrf_pwm library without softdevice but I still get the same problems. It does not occur as often but it still happens a few times every second. It seems the nrf_pwm timer changes counting direction randomly. The image below shows the sine wave after a RC filter.
This error also seems to depend on timer settings, most timeouts gives this kind of error but with some timeout values I get a nice sine wave without "bumps", see line 6 in the initTimer function. Has anyone seen this before and managed to solve it? This is my code:
#include "DRV8662.h"
#include <components/drivers_nrf/hal/nrf_gpiote.h>
#include <components/drivers_nrf/hal/nrf51.h>
#include <components/softdevice/s110/headers/nrf_soc.h>
#include <components/drivers_nrf/hal/nrf51_bitfields.h>
#include <msp/drivers/board_ViTheSSG4rev1.h>
#include <msp/drivers/delay.h>
using namespace msp::peripherals;
using namespace msp::drivers;
namespace {
uint8_t phase = 0;
bool vibratorActive = false;
float attenuation = 1; // 1 is no attenuation, 0 is 100% atteunation
uint8_t channel = 0;
const uint8_t sine26[] = {0, 4, 16, 35, 59, 88, 120, 152, 182, 210, 232, 247,
255, 255, 247, 232, 210, 182, 152, 120, 88, 59, 35, 16, 4, 0};
extern "C" {
void TIMER0_IRQHandler(void) {
if (vibratorActive) {
uint16_t amplitude = static_cast<float>(sine26[phase]) * attenuation;
uint16_t offset = 128 - attenuation * 128;
nrf_pwm_set_value(0, amplitude + offset);
if (phase < 26) {
phase += 1;
} else {
phase = 0;
NRF_TIMER0->EVENTS_COMPARE[0] = 0;
NRF_TIMER0->TASKS_CLEAR = 1; // Reset timer.
} // extern C
DRV8662::DRV8662(uint8_t enablePin, uint8_t pwmPin) :
_enablePin(enablePin), _pwmPin(pwmPin), _vibrationLevel(0), _frequency(128), _phase(
0), _channel(0), _maxLevel(5), _enabled(
false) {
pinOutput(_enablePin);
pinOutput(_pwmPin);
setVibrationLevel(_vibrationLevel);
setFrequency(128);
initPWM(_pwmPin, PWM_MODE_VITHESS_VIBRATOR);
stop();
void DRV8662::initPWM(uint8_t pin, nrf_pwm_mode_t nrfPwmMode) {
nrf_pwm_config_t
pwm_config = PWM_DEFAULT_CONFIG;
pwm_config.mode = nrfPwmMode;
pwm_config.num_channels = 1;
pwm_config.gpio_num[_channel] = pin;
// Initialize the PWM library
nrf_pwm_init (&pwm_config);
// Start the external 16 MHz clock for a more accurate PWM frequency
nrf_pwm_set_value(_channel, 0); // start LOW
// make available in extern C
channel = _channel;
void DRV8662::initTimer(uint16_t frequency) {
NRF_TIMER0->MODE = TIMER_MODE_MODE_Timer; // Set the timer in Counter Mode
NRF_TIMER0->TASKS_CLEAR = 1; // clear the task first to be usable for later
NRF_TIMER0->PRESCALER = 5; //Set prescaler. Higher number gives slower timer. Prescaler = X gives 16MHz/2^X Hz timer
NRF_TIMER0->BITMODE = TIMER_BITMODE_BITMODE_16Bit; //Set counter to 16 bit resolution
//NRF_TIMER0->CC[0] = 500000 / (frequency * 100); //Set value for timer compare register 0, timer period is 2us, pwm period is (1/(freq*255)), pwm period/timer period is 15
NRF_TIMER0->CC[0] = 107; //most values causes strange artifacts... 98, 107, 118, 150 works TODO: investigate
//NRF_TIMER0->CC[0] += us / 4; // TODO: find out why we do this.
// Enable interrupt on Timer 1,for CC[0]
NRF_TIMER0->INTENSET = (TIMER_INTENSET_COMPARE0_Enabled
<< TIMER_INTENSET_COMPARE0_Pos);
// sd_nvic_SetPriority(TIMER0_IRQn, 3);
// sd_nvic_EnableIRQ(TIMER0_IRQn);
NVIC_SetPriority(TIMER0_IRQn, 3);
NVIC_EnableIRQ(TIMER0_IRQn);
uint8_t DRV8662::setVibrationLevel(uint8_t vibrationLevel) {
// Set vibration level
_vibrationLevel = vibrationLevel;
switch (_vibrationLevel) {
case 0:
attenuation = 0;
case 1:
attenuation = 0.3;
case 2:
attenuation = 0.5;
case 3:
attenuation = 0.8;
case 4:
attenuation = 1;
attenuation = 1;
return 0; // return 0 if params in range
uint8_t DRV8662::setFrequency(uint16_t frequency) {
// Set frequency
_frequency = frequency;
initTimer(_frequency);
void DRV8662::start() {
// set pwm to 50%, transition enable from low to high, wait 2ms, datasheet 8.4.1.1
nrf_pwm_set_value(_channel, 128);
enable(true);
delayMs(2);
// Start timer
NRF_TIMER0->TASKS_START = 1; // Start timer.
vibratorActive = true;
void DRV8662::stop() {
// set pwm to 50% to bring differential output back to 0, datasheet 8.4.1.1
enable(false);
delayMs(2);
// stop timer
NRF_TIMER0->TASKS_STOP = 1;
// shut down pwm TODO: find better way to do this
nrf_pwm_set_value(0, 0);
uint8_t DRV8662::vibrationLevel() {
return _vibrationLevel;
uint16_t DRV8662::frequency() {
return _frequency;
uint8_t DRV8662::maxLevel() {
return _maxLevel;
void DRV8662::enable(bool enabled) {
if (enabled) {
pinSet(_enablePin);
} else {
pinClear(_enablePin);
_enabled = enabled;
bool DRV8662::enabled() {
return _enabled;
DRV8662::~DRV8662() {
// TODO: Write destructor
NRF_TIMER0->TASKS_SHUTDOWN = 1; // Shut down timer.
