BL654 UART question
Looking for advice on reading data from the BL654 UART RX pin which is getting a text data stream from an STM32 micro.
I tried the "peripheral_uart" sample app in Segger Studio but it crashes a lot and sometimes I see UART events but have not seen any actual data yet.
Should I use UART IRQ API?  Or UART FIFO API? Should I be using the Nordic UART system CONFIG_BT_NUS like the peripheral_uart example?
I have verified data is working using a terminal to read the serial port.  I have verified the pin assignments and baud rate for the zephyr board DTS file.
Thanks.
    Could you share logs of what happens when it crashes?
    What type of custom board is it ? Are you sure that you have correct overlay/board file?
    Jonathan
  • *** Booting Zephyr OS build v2.6.0-rc1-ncs1  ***
    [00:00:02.292,755] <inf> peripheral_uart: UART_RX_BUF_REQUEST
    [00:00:02.298,583] <inf> fs_nvs: 8 Sectors of 4096 bytes
    [00:00:02.298,583] <inf> fs_nvs: alloc wra: 7, f90
    [00:00:02.298,583] <inf> fs_nvs: data wra: 7, d8
    [00:00:02.298,706] <inf> sdc_hci_driver: SoftDevice Controller build revision:
                                             58 5d 8b 31 54 67 00 e9  b8 4a a7 df a9 9c e4 1c |X].1Tg.. .J......
                                             b3 0b ce 74                                      |...t
    [00:00:02.302,459] <inf> bt_hci_core: No ID address. App must call settings_load()
    [00:00:02.302,459] <inf> peripheral_uart: Bluetooth initialized
    [00:00:02.314,849] <inf> peripheral_uart: Starting Nordic UART service example
    [00:00:02.314,880] <inf> peripheral_uart: ble_write_thread after ble_init_ok
    [00:00:18.957,458] <inf> peripheral_uart: UART_RX_BUF_RELEASED
    [00:00:18.957,458] <inf> peripheral_uart: UART_RX_BUF_REQUEST
    Above is the log.  It crashes with at "z_arm_usage_fault".
    The custom board is a BL654 and STM32 reading data from temperature and gyroscope sensors.
    Just prototype stage.  I copied the "bl654_dvk" board DTS file and modified for our custom board.
    Some of the DTS fiie:
    chosen {
    zephyr,console = &uart0;
    zephyr,shell-uart = &uart0;
    zephyr,uart-mcumgr = &uart0;
    zephyr,bt-mon-uart = &uart0;
    zephyr,bt-c2h-uart = &uart0;
    zephyr,sram = &sram0;
    zephyr,flash = &flash0;
    zephyr,code-partition = &slot0_partition;
    &uart0 {
    current-speed = <115200>;
    status = "okay";
    tx-pin = <6>;
    rx-pin = <8>;
    rts-pin = <5>;
    cts-pin = <7>;
    peripheral_uart example should suffice, and it looks correct to my understanding of how you have set it up. So i am curious how the STM32 micro is configured, does it have flow controlled? how is it connected? Do you have schematics of how they interface?
    I don's see anything of concern in the setup so it leads me to think that there is something with the interface to the STM32 or how it is configured.
    Jonathan
  • I use the Mac app "CoolTerm" to read the serial port which returns data like this:
    pos: 168 1 255
    temp: 75.53 F
    CTS/DTR/XON flow control are all turned off in CoolTerm.
    I can check with the STM32 developer and see about the flow control.
  • Solved issue with crash.
    CONFIG_BT_NUS_THREAD_STACK_SIZE=4096
    Increased stack size from 1024 to 4096
    Seeing data using BlueLight android app.
