Hello Team,
I am facing segmentation fault while reading the OTP memory using pointer in my code. To write the OTP value I have used below command which was successful and also I am able to read OTP section using the read command given below.
$ nrfjprog --memwr 0xFF8108 --val 0xAABBCCDD
$ nrfjprog --memrd 0xFF8108
But when I try to dereference the address using below code it throws me a segmentation fault.
Do I need any special permission to read the OTP section? Because, I could not found any article which talks about how to read the OTP memory for nrf9160.
Kindly, support me to overcome this issue asap.
Thanks in advanced.
Chetan
